Re: think this may be a problem?
[Re: Thumperdart]
#1503526
09/19/13 08:58 PM
09/19/13 08:58 PM
Posts: 4,179 California
mickm
California
What compression...........that #6 is awfully hot.........
10.25 - 10.4:1, depending on the calculator used. aluminum heads.
[Re: Thumperdart]
#1503528
09/20/13 02:04 AM
09/20/13 02:04 AM
mickm
California
I`d run a #7 myself...............my sig et was w/a #7 and showed a bit of peppering at 12.1.1 compression w/alum. heads.......
can't hurt. new plugs would help eliminate one issue. i'll give it a try.
[Re: Thumperdart]
#1503530
09/20/13 01:51 PM
09/20/13 01:51 PM
mickm
California
I hope you figure it out cos this stuff can drive you crazy...........
yea, it does. in reality is's a relatively mild build, just a lot of cubic inches. i did it that way hoping to just be able to drive it with usual maintenance. but, here we go. sigh...
today we are going to put a points distributor in and eliminate the whole current ignition system and go from there.
i'll post the results.
[Re: mickm]
#1503531
09/20/13 01:56 PM
09/20/13 01:56 PM
Thumperdart
State of confusion
Cool...............good luck. Where abouts in Cally r u?
[Re: Thumperdart]
#1503532
09/20/13 02:50 PM
09/20/13 02:50 PM
mickm
California
bay area, mountain view. 80 miles from the nearest track better than some have it i know, but it makes for a long day...
[Re: mickm]
#1503534
09/20/13 08:31 PM
09/20/13 08:31 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Any results yet>
[Re: Sport440]
#1503535
09/21/13 12:11 AM
09/21/13 12:11 AM
mickm
California
Any results yet>
no, didn't get a chance to get it in.
how do i wire a temporary ballast resistor? i only need this in long enough to get the points distributor in and drive the car for a few minutes. if the problem persists, i need to look elsewhere, but if it is gone, i know it is in the current ignition.
[Re: mickm]
#1503537
09/21/13 12:41 AM
09/21/13 12:41 AM
Sport440
Canton, Ohio
For a test you dont need one. You could use the one you have by disconnecting the electronic ignition feed with a 12 volt positive feed. But I would just feed a direct 12 volt positive to the coil for max performance for the test. The stock ignition setup sends full voltage to the coil on the start up position and then sends reduced voltage to the coil on run position through the ballast for Extended point life. Since your just doing a short test, no ballast resister is needed. Your simple test can be as easy as removing the electronic coil feed and replacing it with a hot positive feed jumper with the "test" points distributer. No need to rewire everything Simply put, with a point distributer all you need is 12 volts pos to the pos side of the coil and run the neg. side of the coil to the distributer that will ground it out when the points contact.
[Re: mickm]
#1503540
09/22/13 10:59 PM
09/22/13 10:59 PM
mickm
California
ok. $20 napa coil, 40 year old accel dual point distributor, and it ran like the proverbial raped ape! feathered into it, hit 6k in first gear and the tires broke loose! ran it through 1st and 2nd a few times, was so happy to have the engine back again! damn that was fun! put the msd coil back on and it stumbled and fell all over the place. tried it through the ballast resistor and straight 12v, and it was even worse. why it wasn't acting that bad with the msd, i don't know, but at least for the moment, that looks like it. so going to order a new coil and see what happens... will post again... so why do we run electoric ignition and these msd boxes?
