Location of VIN on '68 440 hp GTX engine same as 69 GTX #1503266
09/17/13 07:26 PM
09/17/13 07:26 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
is the VIN stamped on the right side bottom on a '68 440 hp engine like the '69 440 or on the driver's side left top on the bellhousing like a '68 383 hp???
I can only remember a '68 383 having the VIN on the left/bellhousing.
Re: Location of VIN on '68 440 hp GTX engine same as 69 GTX [Re: A12] #1503267
09/17/13 07:29 PM
09/17/13 07:29 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Bellhousing, but not all 68's got stamped.
Don't know when in 68, that it started.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Location of VIN on '68 440 hp GTX engine same as 69 GTX [Re: A12] #1503268
09/17/13 07:31 PM
09/17/13 07:31 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
drivers side, left top right by the bell housing. If one is stamped then both should be stamped right next to each other. Auto tranny is stamped. not sure about manual bell housing but I would think not.
Re: Location of VIN on '68 440 hp GTX engine same as 69 GTX [Re: fastmark] #1503269
09/17/13 07:40 PM
09/17/13 07:40 PM
Spokane Washington
ScottSmith_Harms Online content
Mr Wizzard
ScottSmith_Harms  Online Content
Mr Wizzard
Spokane Washington
MOST 68 440HP engines were stamped (many low performance 440's were not for some reason), further more I've never seen or heard of a documented 68 Hemi car that wasn't stamped (Any exceptions? Please come forward with proof)
68 cars (440 & Hemi) had the VIN sequence stamped in the raw cast iron casting (not machined flat first) adjacent to the oil sender hole, the automatic trans VIN Sequence was stamped on the flange right on top, right behind the engine stamping. Manual trans VIN sequence numbers were stamped into the raised pad on the pass side of the trans.
Re: Location of VIN on '68 440 hp GTX engine same as 69 GTX [Re: ScottSmith_Harms] #1503270
09/17/13 08:13 PM
09/17/13 08:13 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
so driver's side top for a GTX 440 engine like this on a '68 383 road runner engine I had?
Bellhousing/driver's side/top
Re: Location of VIN on '68 440 hp GTX engine same as 69 GTX [Re: A12] #1503271
09/17/13 08:29 PM
09/17/13 08:29 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Most 68 Dart GTS 383 cars had the number stamped same as the 440.
JB Rhinehart, Realist
A-Body's RULE!
Re: Location of VIN on '68 440 hp GTX engine same as 69 GTX [Re: Rhinodart] #1503272
09/17/13 08:39 PM
09/17/13 08:39 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
On my '68 road runner the number that was stamped on the radiator support and trunk drip rail was NOT the car's VIN but the number in the lower right corner of the fender tag, so is it the last digits of the VIN that is stamped on the '68 engine and trans or the fender tag number?
Re: Location of VIN on '68 440 hp GTX engine same as 69 GTX [Re: A12] #1503273
09/17/13 09:43 PM
09/17/13 09:43 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The VIN will be stamped on the engine and trans , S.O. number on the body ...
Re: Location of VIN on '68 440 hp GTX engine same as 69 GTX [Re: JohnRR] #1503274
09/17/13 09:46 PM
09/17/13 09:46 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yuuup!
Re: Location of VIN on '68 440 hp GTX engine same as 69 GTX [Re: JohnRR] #1503275
09/17/13 10:05 PM
09/17/13 10:05 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Thanks!
