Re: Header tether rule update.. [Re: Al_Alguire] #1503008
09/17/13 10:13 PM
09/17/13 10:13 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Thanks for sharing the info Al
Re: Header tether rule update.. [Re: Al_Alguire] #1503009
09/17/13 10:38 PM
09/17/13 10:38 PM
fullmetaljacket Offline
I can see welds cracking over time in some applications from vibrations along with hot and cold spells in the system more than a bolt and lock nut failing.
A good 5-point bolt and nut can be better than a metal weak weld from contamination or not enough penetration.
Greasing the palms of those sipping fine brandy under palm trees. Go figure.
Re: Header tether rule update.. [Re: fullmetaljacket] #1503010
09/19/13 09:01 AM
09/19/13 09:01 AM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
This reminds me of all the BS we went through with the window nets. Maybe let the dust settle over the winter and see if NHRA pulls their heads out and make a common sense ruling. I know it's doubtful, but one can hope... right?
Re: Header tether rule update.. [Re: Gearhead383] #1503011
09/19/13 09:47 AM
09/19/13 09:47 AM
Super Scamp Offline
Super Scamp  Offline
I have an A Body that has 8 different pieces to put my headers on. I wonder if I will need to tether all of them lolol.
This is realy getting out of control... Next thing they want you to do is tether the drive shaft...
Just One Man's Opinion Mopar Mafia Racing
Re: Header tether rule update.. [Re: Super Scamp] #1503012
09/19/13 10:29 AM
09/19/13 10:29 AM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
I was just thinking about headers built this way and people changing their current headers to utilize slip tubes a few inches away from a welded collector. The way the rules read, you could weld the ends of the primaries to the collectors and have slip joints a few inches away from there with tabs and bolts. I hope headers companies are considering redesigning some of their current systems to utilize something like that.
Adriel Paradise
Substation Design Engineer III
Re: Header tether rule update.. [Re: Adrielp] #1503013
09/19/13 02:12 PM
09/19/13 02:12 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Alguire and I have debated this a couple times now.. My opinion still stands.. I've used common sense when putting together my collectors/headers/muffler and will make a stink about it when I get told by tech to make a change to them.. until then, I'm not going to worry about it..
Re: Header tether rule update.. [Re: Jeepmon] #1503014
09/19/13 05:01 PM
09/19/13 05:01 PM
Las Vegas
Al_Alguire Offline OP
Las Vegas
I will be asking again this next weekend at the Salt Lake divisional if my stuff still needs the tethers. My guess is the answer will be yes//Oh yeah I got caught up in the whole window net deal as well. Since they had not amended the rule before the Phoenix divisional, first race of the year I was forced to buy a new net. So there went $150..Imagine will get hosed in this deal too since I doubt they will have clarity before Pomona again.
Re: Header tether rule update.. [Re: Adrielp] #1503015
09/19/13 05:21 PM
09/19/13 05:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Weather you have a short piece welded to the primary
and then have a bolt on extension its all considered
collector...... my way of thinking... DONT GO TO ANY
NHRA RACES... let them see what happens over 1 year..
they WILL be crying the blues... this is getting WAY
out of hand... I havent seen it in the IHRA rules
Re: Header tether rule update.. [Re: roadhazard] #1503016
09/19/13 05:34 PM
09/19/13 05:34 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
And a jar of that special NHRA approved petroleum jelly
Fixed
Re: Header tether rule update.. [Re: Al_Alguire] #1503017
09/19/13 05:42 PM
09/19/13 05:42 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I have seen collector extensions come off, but never saw the actual collector it's self come off,,if it was bolted properly with tabs etc.
If welding is not acceptable at the collector, why is welding OK at the flange area at the head?? Maybe NHRA should tell the header manufactures to tether them there too. I have bolt on header extensions on my TTI headers. I will put tapered loc nuts on them with loc-tite, lock washers and drill the bolt for a cotter pin. Suppose that will pass??
If you like drag racing, support your local track.
Re: Header tether rule update.. [Re: CHAPPER] #1503018
09/19/13 06:51 PM
09/19/13 06:51 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Well i have 2 single pipes & 2 welded to 1 flange, if i weld my collectors on, i will never get my headers out of the car. They are custom built. I guess i'll have to cut welds everytime i have to take them off. That's bullsh-t. Maybe i won't go to the races anymore.
Re: Header tether rule update.. [Re: Al_Alguire] #1503019
09/19/13 08:11 PM
09/19/13 08:11 PM
Minn
SportF Offline
SportF  Offline
Minn
I find this whole rule stupid. Its ok if the collector falls off, just make sure you catch it. How about don't let it fall off in the first place. Lock wire your bolts, lock wire your tabs, use a cotter key to secure nuts, something, just don't let it fall off in the first place. I don't think anybody is debating the danger, so inspect, not for a tether, but for a sure method of securing in the first place, eh?
Re: Header tether rule update.. [Re: SportF] #1503020
09/19/13 09:32 PM
09/19/13 09:32 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Bingo -
However that makes too much sense ------
Russ
