Re: Header tether rule update..
[Re: Jeepmon]
#1503014
09/19/13 05:01 PM
09/19/13 05:01 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
I will be asking again this next weekend at the Salt Lake divisional if my stuff still needs the tethers. My guess is the answer will be yes//Oh yeah I got caught up in the whole window net deal as well. Since they had not amended the rule before the Phoenix divisional, first race of the year I was forced to buy a new net. So there went $150..Imagine will get hosed in this deal too since I doubt they will have clarity before Pomona again.
[Re: Adrielp]
#1503015
09/19/13 05:21 PM
09/19/13 05:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have an A Body that has 8 different pieces to put my headers on. I wonder if I will need to tether all of them lolol.
This is realy getting out of control... Next thing they want you to do is tether the drive shaft...
I was just thinking about headers built this way and people changing their current headers to utilize slip tubes a few inches away from a welded collector. The way the rules read, you could weld the ends of the primaries to the collectors and have slip joints a few inches away from there with tabs and bolts. I hope headers companies are considering redesigning some of their current systems to utilize something like that.
Weather you have a short piece welded to the primary and then have a bolt on extension its all considered collector...... my way of thinking... DONT GO TO ANY NHRA RACES... let them see what happens over 1 year.. they WILL be crying the blues... this is getting WAY out of hand... I havent seen it in the IHRA rules
[Re: roadhazard]
#1503016
09/19/13 05:34 PM
09/19/13 05:34 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
And a jar of that special NHRA approved petroleum jelly
Fixed
[Re: Al_Alguire]
#1503017
09/19/13 05:42 PM
09/19/13 05:42 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
I have seen collector extensions come off, but never saw the actual collector it's self come off,,if it was bolted properly with tabs etc. If welding is not acceptable at the collector, why is welding OK at the flange area at the head?? Maybe NHRA should tell the header manufactures to tether them there too. I have bolt on header extensions on my TTI headers. I will put tapered loc nuts on them with loc-tite, lock washers and drill the bolt for a cotter pin. Suppose that will pass??
If you like drag racing, support your local track.
[Re: Al_Alguire]
#1503019
09/19/13 08:11 PM
09/19/13 08:11 PM
Posts: 1,213 Minn
SportF
Minn
I find this whole rule stupid. Its ok if the collector falls off, just make sure you catch it. How about don't let it fall off in the first place. Lock wire your bolts, lock wire your tabs, use a cotter key to secure nuts, something, just don't let it fall off in the first place. I don't think anybody is debating the danger, so inspect, not for a tether, but for a sure method of securing in the first place, eh?
[Re: SportF]
#1503020
09/19/13 09:32 PM
09/19/13 09:32 PM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
Bingo -
However that makes too much sense ------
Russ
