Re: WoW...Installed HIDs on the 69....AMAZING [Re: babarracuda] #1502509
09/24/13 06:41 PM
09/24/13 06:41 PM
Surface of the Sun, AZ
Hotwheelsjr Offline
Hotwheelsjr  Offline
LOL...look at all the haters. I'm with Pyper on this one. You all hate HIDs because YOU don't have them. as someone else has already pointed out, they are only annoying to other drivers if they are not adjusted correctly. We're in 2013 folks -- halogen bulbs with a 20 foot reach don't cut it any more. Get with the times...
Re: WoW...Installed HIDs on the 69....AMAZING [Re: Hotwheelsjr] #1502510
09/24/13 06:53 PM
09/24/13 06:53 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
We hate them because they are blinding to on coming drivers. It has nothing to do with not having the import wannabe junk blue lights. I have no trouble at all seeing with my sylvania silver stars and they don't bother other drivers. Of course some people don't give a crap about how what they do affects others.
Re: WoW...Installed HIDs on the 69....AMAZING [Re: Hotwheelsjr] #1502511
09/24/13 07:46 PM
09/24/13 07:46 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I deal with HIDs all day long. When they're OEM installations they are tolerable at best. They have improved over the years and the 2014 Mercedes seem to be a bit easier on other drivers. Naturally, the vehicle buyers love the vision at night.
Aftermarket installations are quite different. I have yet to see an installation with properly designed reflectors and lenses. There are tons of bulb kits that stuff HIDs in halogen housings. They are horrible. The reflectors need to be totally different for the HID bulbs. Drivers with these cars enjoy the light because it's scattering all over the place and lighting up the whole neighborhood.
Properly designed, they're okay. Sadly, few cars have properly designed lights. Nobody remembers seeing the good ones because they're not memorable.
Everybody remembers the bad ones because it generates negative emotions.
- Stu Harmon
Re: WoW...Installed HIDs on the 69....AMAZING [Re: Pyper70] #1502512
09/24/13 08:40 PM
09/24/13 08:40 PM
N.W. Florida
Fat_Mike Online work
Fat_Mike  Online Work
N.W. Florida
she isn't a daily driver...I want all the safety for ME on the road...so i can dodge the lookie loo's
If you're blinding oncoming traffic, YOU are NOT really all that SAFE. Obviously they're installed and you're convinced that all is well...and maybe it is. But that aforementioned "brake check" was for a reason. I sincerely hope that it doesn't take a blinded driver meeting you in a head-on collision to change your way of thinking.
Re: WoW...Installed HIDs on the 69....AMAZING [Re: Pyper70] #1502513
09/24/13 09:24 PM
09/24/13 09:24 PM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
I drove home last week from the exhaust shop...I lit up the road...but no rear views...The guy hit his hazards...I dunno what he wanted from me...he stepped on his brakes to get my attention...i backed off a little bit and then I hit all four headlights to show up that my lows here on...then I pulled up along side him quickly and rumbled him up with my exhaust...if anything...they need to be adjusted higher honestly..
O my.
Re: WoW...Installed HIDs on the 69....AMAZING [Re: Mebsuta] #1502514
10/13/13 03:50 AM
10/13/13 03:50 AM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
Feets covered it best. Generally, HID conversion bulbs do not sit in the same position within the housing as the halogens the housings were designed for. This causes light to be reflected in directions not originally intended (think of how a Maglight flashlight adjusts the beam from pinpoint to flood). Add in some cheaply made housings and a lack of any attempt to re-aim the lights afterwards and you've got a scattered mess.
I have projector housings (with HIDs) in place of the stock driving lights on my lifted truck. The beam cutoff is such that it does not go above the door handle of most cars crossing in front of me at an intersection. I run these and no headlights while in town because although my headlights are still legal height, they are annoying to other drivers when I am behind them.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: WoW...Installed HIDs on the 69....AMAZING [Re: Cheeto] #1502515
10/13/13 07:36 AM
10/13/13 07:36 AM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Trust me...I don't have cheap headlamps...I bought some of the most expensive Hella's out on the market. The light spread is exactly what its supposed to be. The lenses are ribbed and frosted. The HIDs have the block off plate on the bulb so as to not hit the others drivers in the eyes. When there are Lexus SUVs, Land Rovers, Hummers with HIDs and blinding everyone on the road...no one says anything....I drive around other cars which are low to the ground...buckets...
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: WoW...Installed HIDs on the 69....AMAZING [Re: Pyper70] #1502516
10/13/13 06:44 PM
10/13/13 06:44 PM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
I was referring to aftermarket assemblies in general, not your Hellas specifically.
Having said that, your comments regarding "Mr Brakecheck" and "aimed at my knees at 20 feet" could very easily place you in the category I was talking about.
Put a stock headlight back in one side, face off to a wall at about 25' and 50' and compare where the light is hitting the wall between the two sides. Not exactly a technical solution but it will give you a good idea of what's going on.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: WoW...Installed HIDs on the 69....AMAZING [Re: Pyper70] #1502517
10/13/13 09:27 PM
10/13/13 09:27 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
You're still not getting it (or you're just in denial). HID and incandescent lamps are completely different. The reflectors are not compatible (regardless of the price or quality of Hella lamp you utilizes...I'm guessing they are the vision plus ECE). It's an optical mismatch.
Take it from someone (me) who designed, tested, and manufactured OEM headlamps for several years (for a Hella subsidiary no less). There is a reason the HID retrofits are labeled "for off-highway use only". They do not meet FMVSS/DOT or ECE standards.
Here's the article that explains it all:
http://www.danielsternlighting.com/tech/bulbs/Hid/conversions/conversions.html
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: WoW...Installed HIDs on the 69....AMAZING [Re: 471Magnum] #1502518
10/14/13 06:56 PM
10/14/13 06:56 PM
IL,USA
bdusted440 Offline
bdusted440  Offline
IL,USA
I must just still be too young as the HIDs don't bother me at night!
I am a tech and Audi and MB gold certified as well as dodge and am trained in them, so they don't surprise me as I'm used to them. But the aftermarket only has one or two that are actually built for hid bulbs. But if they are aimed correctly they pose no problem. Incorrectly adjusted they will blind. And those are the only ones we remember. Kudos on the upgrade. And remember folks live and let live.
currently own
1976 duster deluxe
1974 gold duster
1993 Dakota sport
2000 caravan
2002 Durango
1970 v code superbee
Re: WoW...Installed HIDs on the 69....AMAZING [Re: Pyper70] #1502519
10/14/13 08:59 PM
10/14/13 08:59 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Plates on the bulbs don't help if the light is bouncing off the reflector and scattering through the lens.
What temperature bulb did you get? Something around 6500k is going to be ultra bright to others.
- Stu Harmon
Re: WoW...Installed HIDs on the 69....AMAZING [Re: feets] #1502520
10/15/13 12:35 PM
10/15/13 12:35 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I bought the 35w H4-3 bulbs rated at 6000k for my Hi-Los...I goofed and bought Sylvania H4 4000k which a more yellowy light but I checked it out the other day and the mix provides alot of light down the road....about 350 feet
Re: WoW...Installed HIDs on the 69....AMAZING [Re: Pyper70] #1502521
10/15/13 01:31 PM
10/15/13 01:31 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
I bought used vehicles w/aftermarket HIDs.
Best color is 4300k. Anything higher is stupid.
I have fogs with 3000k. Can actually see better with those.
I don't recommend HIDs on High beams because of the constant on/off nature of high beams will reduce life of the HID bulb.
Re: WoW...Installed HIDs on the 69....AMAZING [Re: Hotwheelsjr] #1502522
10/15/13 02:27 PM
10/15/13 02:27 PM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
No kidding, isn't it great that he puts up a thread about a modification he has done to his car that he drive IN GREECE and all he gets in return is
Re: WoW...Installed HIDs on the 69....AMAZING [Re: JohnRR] #1502523
10/15/13 03:22 PM
10/15/13 03:22 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Got all the stuff to throw HIDs in the dart.
They wont be a blueish color but theyll be bright white just dont recall the number off the top of my head. If im not happy ill go back to the dim sealed beams.
Re: WoW...Installed HIDs on the 69....AMAZING [Re: 2fast4yourBrain] #1502524
10/15/13 06:32 PM
10/15/13 06:32 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
I just have the HIDs in the HiLo...the Hi Beams are just H4s with a relay harness feeding straight off the battery
I drive the car...mainly in the day time....I get about 750 miles per year on my car. Every now and then i will have to do a midnight run or taking a lady out for a night on the town...so i am sorry if my HIDs are blinding you from Eastern Europe.. hahahaha
