Re: WoW...Installed HIDs on the 69....AMAZING
[Re: Pyper70]
#1502512
09/24/13 08:40 PM
09/24/13 08:40 PM
Posts: 3,058 N.W. Florida
Fat_Mike
N.W. Florida
she isn't a daily driver...I want all the safety for ME on the road...so i can dodge the lookie loo's
If you're blinding oncoming traffic, YOU are NOT really all that SAFE. Obviously they're installed and you're convinced that all is well...and maybe it is. But that aforementioned "brake check" was for a reason. I sincerely hope that it doesn't take a blinded driver meeting you in a head-on collision to change your way of thinking.
[Re: Pyper70]
#1502513
09/24/13 09:24 PM
09/24/13 09:24 PM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
I drove home last week from the exhaust shop...I lit up the road...but no rear views...The guy hit his hazards...I dunno what he wanted from me...he stepped on his brakes to get my attention...i backed off a little bit and then I hit all four headlights to show up that my lows here on...then I pulled up along side him quickly and rumbled him up with my exhaust...if anything...they need to be adjusted higher honestly..
O my.
[Re: Mebsuta]
#1502514
10/13/13 03:50 AM
10/13/13 03:50 AM
Posts: 1,965 ID/MT
Cheeto
ID/MT
Feets covered it best. Generally, HID conversion bulbs do not sit in the same position within the housing as the halogens the housings were designed for. This causes light to be reflected in directions not originally intended (think of how a Maglight flashlight adjusts the beam from pinpoint to flood). Add in some cheaply made housings and a lack of any attempt to re-aim the lights afterwards and you've got a scattered mess.
I have projector housings (with HIDs) in place of the stock driving lights on my lifted truck. The beam cutoff is such that it does not go above the door handle of most cars crossing in front of me at an intersection. I run these and no headlights while in town because although my headlights are still legal height, they are annoying to other drivers when I am behind them.
Cheeto It's not perfect. It's not correct. It's not yours!
[Re: Cheeto]
#1502515
10/13/13 07:36 AM
10/13/13 07:36 AM
Posts: 5,902 Athens, Greece
Pyper70
Athens, Greece
Trust me...I don't have cheap headlamps...I bought some of the most expensive Hella's out on the market. The light spread is exactly what its supposed to be. The lenses are ribbed and frosted. The HIDs have the block off plate on the bulb so as to not hit the others drivers in the eyes. When there are Lexus SUVs, Land Rovers, Hummers with HIDs and blinding everyone on the road...no one says anything....I drive around other cars which are low to the ground...buckets...
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#1502516
10/13/13 06:44 PM
10/13/13 06:44 PM
Posts: 1,965 ID/MT
Cheeto
ID/MT
I was referring to aftermarket assemblies in general, not your Hellas specifically.
Having said that, your comments regarding "Mr Brakecheck" and "aimed at my knees at 20 feet" could very easily place you in the category I was talking about.
Put a stock headlight back in one side, face off to a wall at about 25' and 50' and compare where the light is hitting the wall between the two sides. Not exactly a technical solution but it will give you a good idea of what's going on.
[Re: Pyper70]
#1502517
10/13/13 09:27 PM
10/13/13 09:27 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
You're still not getting it (or you're just in denial). HID and incandescent lamps are completely different. The reflectors are not compatible (regardless of the price or quality of Hella lamp you utilizes...I'm guessing they are the vision plus ECE). It's an optical mismatch. Take it from someone (me) who designed, tested, and manufactured OEM headlamps for several years (for a Hella subsidiary no less). There is a reason the HID retrofits are labeled "for off-highway use only". They do not meet FMVSS/DOT or ECE standards. Here's the article that explains it all: http://www.danielsternlighting.com/tech/bulbs/Hid/conversions/conversions.html
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: 471Magnum]
#1502518
10/14/13 06:56 PM
10/14/13 06:56 PM
Posts: 172 IL,USA
bdusted440
IL,USA
I must just still be too young as the HIDs don't bother me at night! I am a tech and Audi and MB gold certified as well as dodge and am trained in them, so they don't surprise me as I'm used to them. But the aftermarket only has one or two that are actually built for hid bulbs. But if they are aimed correctly they pose no problem. Incorrectly adjusted they will blind. And those are the only ones we remember. Kudos on the upgrade. And remember folks live and let live.
currently own 1976 duster deluxe 1974 gold duster 1993 Dakota sport 2000 caravan 2002 Durango 1970 v code superbee
[Re: feets]
#1502520
10/15/13 12:35 PM
10/15/13 12:35 PM
Pyper70
Athens, Greece
I bought the 35w H4-3 bulbs rated at 6000k for my Hi-Los...I goofed and bought Sylvania H4 4000k which a more yellowy light but I checked it out the other day and the mix provides alot of light down the road....about 350 feet
[Re: Pyper70]
#1502521
10/15/13 01:31 PM
10/15/13 01:31 PM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
I bought used vehicles w/aftermarket HIDs. Best color is 4300k. Anything higher is stupid. I have fogs with 3000k. Can actually see better with those. I don't recommend HIDs on High beams because of the constant on/off nature of high beams will reduce life of the HID bulb.
