Re: 750 carbs on 700hp motors
[Re: rt66jim]
#1501042
09/15/13 12:09 AM
09/15/13 12:09 AM
Posts: 8,045 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I should be at a 1.44 in relation to my best 10.39@131. so,what do you think needs attention, vert, rear gear or trans gear or is the car just too damn heavy?
[Re: mopar dave]
#1501043
09/15/13 12:41 AM
09/15/13 12:41 AM
Posts: 11,730 Portage,michigan
B3422W5
Portage,michigan
Car isn't to heavy to not 60 foot better. I went 1.43 on leafs running Eddie heads and a flat tappet when it weighed 3450 and ran 10.70's. Just didn't have enough steam past 1100 feet or so. That combo was 11.8 compression. You have about a tenth in 60 foot that is possible to be picked up, IMO.
[Re: mopar dave]
#1501045
09/15/13 09:38 AM
09/15/13 09:38 AM
BradH
I should be at a 1.44 in relation to my best [Email]10.39@131.[/Email] so,what do you think needs attention, vert, rear gear or trans gear or is the car just too damn heavy?
I know it's an apples-to-oranges comparison, but my 440 Challenger @ 3750#s pulls 1.45-1.46 60s on 275R6015 DOT drag radials w/ 4.10s and a 4500-stall 'vert.
I'm not sure if you're under-geared for your torque curve or the converter hits "soft" or ???, but I'd expect you should be able to pull better 60s than my street/strip ride. You've got 5 MPH on top end over mine, yet mine has run solidly in the 10.5s w/ that much less MPH.
Simply trying to offer more food for thought...
