Re: How to install this external Milodon Oil Pump??? HELP
[Re: domingo]
#1500580
09/15/13 11:57 AM
09/15/13 11:57 AM
Posts: 9,672 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
[Re: domingo]
#1500581
09/15/13 11:58 PM
09/15/13 11:58 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
You can get the new gerotor set. That is not a new pump. Even I wouldn't run that with that gear set in there... and I've been known to run some real scrap at times.
[Re: TRENDZ]
#1500582
09/16/13 12:19 AM
09/16/13 12:19 AM
domingo
EL Master
EL Master
Lima, Peru
So i can buy thenew rotos from milodon and keep the pump body? Does that nick on the plate look like it can cause some trouble or it shouldnt really matter?
Im asking because I have lots of parts like this, that I got as part of a package deal when I bought a car, and Im trying to put a motor together with all of that: stage V fully ported heads, tunnel am with dual 750 carbs, new aluminum rods, new venolia pistons, milodon gear drive, milodon oil pump, stock stroke crank 440 engine, COMP ROLLER cam, etc.
[Re: Stanton]
#1500584
09/16/13 11:44 AM
09/16/13 11:44 AM
TRENDZ
Milwaukee WI
Let me start by saying, I've had my share of milodon pump issues. If you want a pump that is trouble free, what you need to do is get a new gear set, and have the cover resurfaced and re-coated. I see rotational marks in the cover. That is how I can say this is not a new pump. Those minor scratches combined with the rounded edges of the gear set will have you losing the pump prime. If you don't do these things, Than I would suggest teflon coated main and rod bearings. That way, on cold start the motor can run for a few minutes without oil pressure while you are waiting for the pump to come back to life.
