Page 2 of 3 1 2 3
Re: Cam and roller Lifter suggestions [Re: relax383] #1499529
09/11/13 03:36 PM
09/11/13 03:36 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Let me start of whit that im no expert !
I tested a 1970 Challenger 440 5 speed trans 4.10 and that car had a Comp Cams 23-711-9 roller cam that ran realy strong.
My car have a 505 stroker roller hyd cam that i rev on the street to 5500 rpm whit a 4 speed trans and that works fine on Hughes Engine parts but i do have some noise that come and go at sertain rpm´s and that has been that way since i started that engine up the first time and i gues that if a cam lifts around 0,600 on rockers some noise sould be expected even how tight everything is !?
Re: Cam and roller Lifter suggestions [Re: relax383] #1499530
09/11/13 04:02 PM
09/11/13 04:02 PM
AndyF Offline
AndyF  Offline
My 70 RR is almost finished. have a 440 engine topped with edelbrock heads and a six pack setup. I want to swap in a hyd roller cam. I want torque to be about 475-500. Any suggestions? Also what roller lifters do you guys recommend?
Here is an article from the Tech Archives (always a good place to look first) This engine is a big block with Edelbrock heads and a Comp hyd roller cam. It should answer most of your questions.
http://www.popularhotrodding.com/tech/1007phr_big_block_mopar_engines/
Re: Cam and roller Lifter suggestions [Re: 1967Valiant] #1499531
09/11/13 04:09 PM
09/11/13 04:09 PM
Guitar Jones Online laugh2
Other than I tune on some of the fastest grudge cars around guess nothing.
Man reading comprehension on the net has not gotten any better has it?
Re: Cam and roller Lifter suggestions [Re: Mopar Guy] #1499532
09/11/13 04:29 PM
09/11/13 04:29 PM
NC
1967Valiant Offline
1967Valiant  Offline
NC
Morel high rpm short travel
Re: Cam and roller Lifter suggestions [Re: 1967Valiant] #1499533
09/11/13 04:32 PM
09/11/13 04:32 PM
NC
1967Valiant Offline
1967Valiant  Offline
NC
Oh I am sorry. Bob builds Race Cars I think, never have seen one that is faster than ten so guess he builds street cars.
Re: Cam and roller Lifter suggestions [Re: AndyF] #1499534
09/11/13 04:32 PM
09/11/13 04:32 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
Andy i dont like to brag but my engine is at least as powerfull as that one on 11,6 comp ratio and six pack set up !
Re: Cam and roller Lifter suggestions [Re: Mopar Guy] #1499535
09/11/13 05:34 PM
09/11/13 05:34 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Patrick unless your engine and the engine in the article were on the same dyno , on the same day you really don't know if you are making more power. I don't think Andy was trying to one up you, just giving you some comparative information.
Getting old just means you were smarter than some and luckier than others.
Re: Cam and roller Lifter suggestions [Re: 1967Valiant] #1499536
09/11/13 06:18 PM
09/11/13 06:18 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Josh I googled you and Bob. There is quite a bit of I info on Bob. But I could not find a single thing on you or your endeavors as a world class grudge race tuner. Guess you work under an assumed name like a wrestler. That is probably a good idea. Possibly a mask too. Keep some of your fans from bothering you when your out in the public. That's the thing about old Bob he has been in the public eye for quite sometime and has passed the test of time. So most that know Bob hear him say Sundays Easter we start coloring our eggs.
Re: Cam and roller Lifter suggestions [Re: dannysbee] #1499537
09/11/13 06:21 PM
09/11/13 06:21 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
So, is the issue with hydraulic lifters, when run on too aggressive a lobe, they self destruct? The internals get damaged in some way? Is this cause by the lifter, more likely with a roller lobe, bouncing out of control to the pushrod location. So, "bottoming out" the plunger for lack of a better description and damaging the lifter.
Could something like a rev kit aid with a hydraulic roller setup? Make sure the lifter is well controlled while allowing the valve spring to better handle the push rod, rocker, valve, etc.?
How much does oil pressure affect the life of a hydraulic lifter? Low(er) oil pressure combined with an out of control lifter, bad combo?
Just thinking out loud.
383, Hemi 4-Speed, AlterKtion, D60
Re: Cam and roller Lifter suggestions [Re: B G Racing] #1499538
09/11/13 06:31 PM
09/11/13 06:31 PM
NC
1967Valiant Offline
1967Valiant  Offline
NC
And the nut huggers come to top!
Re: Cam and roller Lifter suggestions [Re: skrews] #1499539
09/11/13 06:32 PM
09/11/13 06:32 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Who's making good hyd roller lifters that go 7500 ? Seems like everyone I know, that goes down the hyd roller road has issues with them.
340 Rick buzzes his new gen hemi 7500 every pass with a hy roller...but he modify's them to do so....basically makes a solid out of them
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Cam and roller Lifter suggestions [Re: 1967Valiant] #1499540
09/11/13 06:42 PM
09/11/13 06:42 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
I just flushed the toilet..............say bye.
Re: Cam and roller Lifter suggestions [Re: relax383] #1499541
09/11/13 07:07 PM
09/11/13 07:07 PM
Delray beach, Florida
P
Performance Only Offline
P
I've used most of the different brands of hydraulic roller lifters on the market and have pretty good success with all of them. I think you need to pay close attention to cleanliness first off. Any debris no matter how small will keep the lifters from working properly. After that a lot depends on the weight of the valve train and the rpm you feel you want to run at. With that being said, spring pressures and spring rates need to be looked at very closely. Not enough spring and you will damage the lifter, too much spring and you'll damage the lifter. too much pre-load and the lifters try to pump up, causing the valves to stay open at higher rpm's. not enough preload and the pushrods will hammer the plungers and destroy the lifters. If you do your homework, or deal with a reputable shop, you have a far better chance of getting it right the first time. As far as the torque number you listed, you should be able to easily hit that number and more if you want to as long as the rest of the combination is in order.
Okay, back to the Holiday Inn Express I go now.
machine shop owner and engine builder
Re: Cam and roller Lifter suggestions [Re: Guitar Jones] #1499542
09/11/13 07:53 PM
09/11/13 07:53 PM
central, fl
turboduster Offline
turboduster  Offline
central, fl
Are we related? Lmao. I'm pretty sure I've seen him riding in the back of the farm truck. At least the dog rides in the front.
Re: Cam and roller Lifter suggestions [Re: turboduster] #1499543
09/11/13 07:57 PM
09/11/13 07:57 PM
central, fl
turboduster Offline
turboduster  Offline
central, fl
Found a car he tuned
Re: Cam and roller Lifter suggestions [Re: turboduster] #1499544
09/11/13 08:01 PM
09/11/13 08:01 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Another.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cam and roller Lifter suggestions [Re: pittsburghracer] #1499545
09/11/13 08:02 PM
09/11/13 08:02 PM
PA.
"Little"John
"Little"John
PA.
one more.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Cam and roller Lifter suggestions [Re: pittsburghracer] #1499546
09/11/13 08:12 PM
09/11/13 08:12 PM
NC
1967Valiant Offline
1967Valiant  Offline
NC
Yep all those are mine! Thanks for finding them!
Re: Cam and roller Lifter suggestions [Re: 1967Valiant] #1499547
09/11/13 08:29 PM
09/11/13 08:29 PM
central, fl
turboduster Offline
turboduster  Offline
central, fl
Lol. You're a good sport.
Re: Cam and roller Lifter suggestions [Re: turboduster] #1499548
09/11/13 09:39 PM
09/11/13 09:39 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The Cranes MUST be good since they cost about $750. Biggest problem I think is just most Mopars have a heavy valvetrain. Whatever you do stay away from Comps HR lifters. Morel has 2 grades of them, find a dealer for them and get the better of the 2. Use 11/32 valves and titanium retainers. There was a guy I read that basically set lash on the Morels by bottoming the plunger out completely then backing off like a 1/4 turn and claimed 7500 rpm on a BB Mopar. Whatever, it would be a potentially expensive experiment.
Mopar to the bone!!!
Page 2 of 3 1 2 3
