Re: 37 Plymouth PU Ressurection.
[Re: AZ_A12_BEE]
#1499172
09/05/14 01:38 AM
09/05/14 01:38 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Removing old abandoned motor mounts, here you can see the crappy mounts that hold the 302 in
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#1499175
09/05/14 01:42 AM
09/05/14 01:42 AM
AZ_A12_BEE
Dreaming of the 808
Boxes of parts came today
Power window kit 20,000 BTU heater Engine and trans mount kits
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499183
09/05/14 03:17 PM
09/05/14 03:17 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Think it's time to vacuum.
[Re: AZ_A12_BEE]
#1499186
09/05/14 03:54 PM
09/05/14 03:54 PM
OzHemi
Garden Grove, CA
That was a stuffed animal that met it's demise at the hands of this beast
I thought along those lines..
[Re: AZ_A12_BEE]
#1499187
09/05/14 11:45 PM
09/05/14 11:45 PM
AZ_A12_BEE
Dreaming of the 808
Power window kit, all this for $149. Looks pretty easy to install
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499188
09/05/14 11:58 PM
09/05/14 11:58 PM
OzHemi
Garden Grove, CA
Did you get some rubber boots/thingys to run the wires between the door and jamb area ? I got and tried a few different styles when I was putting power windows in the my Torana. I might still have some of the smaller diameter ones around as I needed room for the power window wires as well as power locks as well.
