Page 2 of 13 1 2 3 4 12 13
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499029
09/10/13 11:29 AM
09/10/13 11:29 AM
AZ
Mike P Online content
Mike P  Online Content
AZ
I have the original fuel tank from my 37 Dodge PU that should be the same as what was original to your truck. I believe it is still solid. You are welcome to it.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
Re: 37 Plymouth PU Ressurection. [Re: Mike P] #1499030
09/10/13 03:09 PM
09/10/13 03:09 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
Mike,I might take you up on that offer, I'm not sure if a stock tank will work with the 302/auto and maybe that's why it's missing.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499031
09/10/13 04:06 PM
09/10/13 04:06 PM
Dreaming of the 808
Dreaming of the 808
Cardboard template to cut a 1 inch piece of particle board to mount seat on.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499032
09/10/13 07:31 PM
09/10/13 07:31 PM
AZ
AZ
It won't be going anywhere. I am going the old beer keg in the bed route. The stock location for the tank can be problematic for dual exhaust (somewhat the same layout as the under bed tanks on the 70s D100s).
Re: 37 Plymouth PU Ressurection. [Re: Mike P] #1499033
09/10/13 09:53 PM
09/10/13 09:53 PM
Dreaming of the 808
Dreaming of the 808
I figured that was the case, if I end up making a tank that fits under the bed behind the axle, we might want to make one for you at the same time if you want to go that route, I calculated I can make a 16 gallon tank yet still leave room for airbag/4 link suspension
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499034
09/10/13 09:57 PM
09/10/13 09:57 PM
Dreaming of the 808
Dreaming of the 808
Particle board seat base finished, ready for seat back that is bolted on and hinged so I can access the rear seat area for my battery,
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499035
09/10/13 09:58 PM
09/10/13 09:58 PM
Dreaming of the 808
Dreaming of the 808
Seat back bolted down
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499036
09/10/13 10:00 PM
09/10/13 10:00 PM
Dreaming of the 808
Dreaming of the 808
I hinged the particle board base so I can access the area under the seat for storage
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499037
09/10/13 10:08 PM
09/10/13 10:08 PM
Dreaming of the 808
Dreaming of the 808
Seat complete, back folds forward to access area behind seat for battery
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499038
09/12/13 05:34 PM
09/12/13 05:34 PM
Dreaming of the 808
Dreaming of the 808
Found a donor truck for the rear leaf springs, made the deal and will pull them next week, $45 per side, a great deal
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499039
09/12/13 06:06 PM
09/12/13 06:06 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I was thinking this would be a good opportunity to update the rear leafs. Not sure on trucks, but pass cars of that era have some honking thick spring packs that are 2" wide. That donor being a tow truck of some sort probably had even stouter spring packs.
But the price is good.
Don't be the exception.
Re: 37 Plymouth PU Ressurection. [Re: Supercuda] #1499040
09/12/13 07:36 PM
09/12/13 07:36 PM
Dreaming of the 808
Dreaming of the 808
Theses springs in these years are only 1 3/4 inch wide, the ones on this tow truck have as many leafs as mine, I will post a side by side pic when I do the swap
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499041
09/13/13 09:27 PM
09/13/13 09:27 PM
Dreaming of the 808
Dreaming of the 808
Looks like I'm going to use the gas tank out of a 93 Geo tracker, a little small at 11 gallons but it will fit with very little fabrication
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499042
09/17/13 10:51 PM
09/17/13 10:51 PM
Dreaming of the 808
Dreaming of the 808
Got my fuel tank today, it's out of a 93 Geo Sidekick, mounting it will be a breeze.
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499043
09/18/13 05:51 PM
09/18/13 05:51 PM
Dreaming of the 808
Dreaming of the 808
Pulled my replacement springs this morning, took about 3 hours
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499044
09/18/13 05:52 PM
09/18/13 05:52 PM
Dreaming of the 808
Dreaming of the 808
All this for $120
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499045
09/20/13 05:56 PM
09/20/13 05:56 PM
Dreaming of the 808
Dreaming of the 808
Got her to crank over today, hopefully get her started/running tomorrow
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499046
09/20/13 09:57 PM
09/20/13 09:57 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Making progress! Make sure it has oil pressure before starting. I dislike those hex drives in SBFs, but the make it easy to prime!
Type F only in the trans!
Re: 37 Plymouth PU Ressurection. [Re: RodStRace] #1499047
09/20/13 10:21 PM
09/20/13 10:21 PM
Dreaming of the 808
Dreaming of the 808
How do I prime it?
Re: 37 Plymouth PU Ressurection. [Re: AZ_A12_BEE] #1499048
09/21/13 12:01 PM
09/21/13 12:01 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
http://www.fordstrokers.com/break-in/
BUT you MUST ALWAYS prime the oil pump mechanically before starting your new engine for the first time. If you do not own an oil pump shaft priming tool, you can easily use a 1/4 inch extension with a 1/4 inch socket taped to the extension and chucked in your drill. Proceed to spin the drill counterclockwise for 15-20 seconds, rotate the engine 1/4 turn, continue to run the drill again for another 15-20 seconds and turn the engine over by hand another 1/4 turn. Do this until you have turned the engine over a full revolution AND you have oil at all pushrods.
