Re: 37 Plymouth PU Ressurection.
[Re: AZ_A12_BEE]
#1499070
09/26/13 05:13 PM
09/26/13 05:13 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Got the rear end back together, just need shocks and weld the spring perches to the axle tube which I will do when I weld a bracket in to support the front of the fuel tank
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#1499071
09/26/13 05:15 PM
09/26/13 05:15 PM
AZ_A12_BEE
Dreaming of the 808
Another pic of axle and springs
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499074
09/26/13 11:48 PM
09/26/13 11:48 PM
Posts: 10,559 Freeport IL USA
poorboy
Freeport IL USA
Excellent Dave!
Hows the ride height?
Jim, it's perfect after I had the new springs de-arched 3 inches, driveshaft is a straight shot to the tranny now.
Its best to have a few degrees of drive shaft angles, in opposite directions, or the u-joints will lock up from not moving. Gene
[Re: AZ_A12_BEE]
#1499075
09/27/13 10:35 PM
09/27/13 10:35 PM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
Excellent Dave!
Sweet! Your knocking off items on the "before I can safely drive it list" in record fashion. You've got to be jazzed
[Re: AZ_A12_BEE]
#1499077
09/29/13 08:07 PM
09/29/13 08:07 PM
AZ_A12_BEE
Dreaming of the 808
Tail lights/license plate brackets arrive, very nice product
37 Plymouth PU
[Re: Hotwheelsjr]
#1499080
09/30/13 10:43 PM
09/30/13 10:43 PM
AZ_A12_BEE
Dreaming of the 808
The front brakes were a mess. Getting the brakes fixed, had 2 new hoses made today and a local company is re-shoeing the front brake shoes. I got 2 new wheel cylinders and front inner seals coming from back east.
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499081
10/01/13 12:23 AM
10/01/13 12:23 AM
Posts: 10,693 Surface of the Sun, AZ
Hotwheelsjr
I have to work on mine either tonight or tomorrow morning. Weather is finally BEAUTIFUL at night and early morning!
[Re: 36dodge]
#1499083
10/02/13 10:58 PM
10/02/13 10:58 PM
AZ_A12_BEE
Dreaming of the 808
New gas tank off of eBay arrived today, $107.00 shipped to my door, it's 11 gallons out of a mid 90s Suzuki Sidekick, fits perfect behind the rear axle. Since the tank is now behind the axle I got a fuel door off of a 1996 Buick Riviera which I will mount and weld into the drivers side rear fender
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499084
10/02/13 11:03 PM
10/02/13 11:03 PM
AZ_A12_BEE
Dreaming of the 808
Front brake shoe relined, waiting on inner seals and new wheel cylinders to be delivered
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499086
10/03/13 07:29 AM
10/03/13 07:29 AM
Posts: 1,511 AZ
Mike P
AZ
Are you going to leave the original pipe and gas cap on the cab or weld the hole closed?
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
[Re: AZ_A12_BEE]
#1499088
10/03/13 11:57 PM
10/03/13 11:57 PM
AZ_A12_BEE
Dreaming of the 808
Box full of brake parts arrived today, now I can get the front axle back together
37 Plymouth PU
[Re: AZ_A12_BEE]
#1499089
10/03/13 11:58 PM
10/03/13 11:58 PM
AZ_A12_BEE
Dreaming of the 808
Fuel door is trimmed and ready for install
37 Plymouth PU
