Re: which epoxy? JB weld or ?
[Re: BB65Barracuda]
#1497095
09/10/13 06:21 PM
09/10/13 06:21 PM
RapidRobert
I have a pic of what I am working with but my home computer died a week ago & I'm on a borrowed office computer & I ain't figured how to upload pics onto it so I can post em but I'll get some help & post em later
[Re: RapidRobert]
#1497096
09/10/13 07:03 PM
09/10/13 07:03 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Robert, Ive raced for several years and have never done anymore than screw the pickup in on any of my BB motors leaving an 1/8th inch space I might add. My 66 dart consistently went into the low 9's. If it makes you feel more secure you can put a tack weld on it. If your not romping at the track 450 times a season don't worry about it. ![](/ubbthreads/images/graemlins/Twocents.gif) Just the advice of a lowly BSEE! ![](/ubbthreads/images/graemlins/laugh2.gif)
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: RapidRobert]
#1497098
09/10/13 09:03 PM
09/10/13 09:03 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
WoW! You might have mentioned the circle track part. I would think welding would be mandatory on your pictured set up. Did you make a pan? I wounder if you might have an issue with Cavitation because of the extreme 90's? Perhaps Challenger1 has a great idea for your application. Go drysump. I hope it works out for you ![](/ubbthreads/images/graemlins/beer.gif)
[Re: ek3]
#1497102
09/13/13 12:16 AM
09/13/13 12:16 AM
RapidRobert
Yeah I'm not real comfortable with that thick wall stuff either. If you have a brand/part # for some thin wall material I'm all ears! The pump is tapped for 1/2 NPT so it'd have to work with that size
[Re: BDW]
#1497103
09/13/13 01:03 AM
09/13/13 01:03 AM
Posts: 654 MN
astrobuf
MN
OMG - my concerns re vibration just quadrupled. You need to build this using 1/2 inch flex copper brazed to a pickup on one end, and a compression fitting to a male adapter on the other end. If rug up a bracket of some kind to the pump body to lock the compression fitting down and provide support tool. Astrobuf ![](/ubbthreads/images/graemlins/luck.gif)
So, are you really a Rocket Scientist?
[Re: RapidRobert]
#1497104
09/14/13 01:50 AM
09/14/13 01:50 AM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
canton or champ ,steffs is a great custom mfg check with them for tubing.. which/what pan do you have. you should be able to get a matching pickup for it. if the pump is drilled for 1/2 " , you should be able to get one in 1/2" or you will have to adapt it down to fit the matching pickup. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: ek3]
#1497105
09/14/13 10:31 AM
09/14/13 10:31 AM
RapidRobert
The pump is tapped for 1/2 pipe. I do not want to neck it down. I'm using a 392 pan which is a common "center" sump but more toward the front. I do have a std vol pump/matching pickup (for that pan) but I want (need) the hi vol pump tapped for 1/2 along with the other oiling mods. I will see what Steffs has. Thank you!
