Re: which epoxy? JB weld or ? [Re: BDW] #1497094
09/10/13 02:37 PM
09/10/13 02:37 PM
MICHIGAN
BB65Barracuda Offline
MICHIGAN
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
Re: which epoxy? JB weld or ? [Re: BB65Barracuda] #1497095
09/10/13 06:21 PM
09/10/13 06:21 PM
RapidRobert Offline OP
I have a pic of what I am working with but my home computer died a week ago & I'm on a borrowed office computer & I ain't figured how to upload pics onto it so I can post em but I'll get some help & post em later
Re: which epoxy? JB weld or ? [Re: RapidRobert] #1497096
09/10/13 07:03 PM
09/10/13 07:03 PM
MICHIGAN
MICHIGAN
Robert,
Ive raced for several years and have never done anymore than screw the pickup in on any of my BB motors leaving an 1/8th inch space I might add.
My 66 dart consistently went into the low 9's.
If it makes you feel more secure you can put a tack weld on it.
If your not romping at the track 450 times a season don't worry about it.
Just the advice of a lowly BSEE!
Re: which epoxy? JB weld or ? [Re: BB65Barracuda] #1497097
09/10/13 07:19 PM
09/10/13 07:19 PM
It's a high rpm circle track 360. when you see the pic I am committed to where I am at. I am going to set the depth (probable 1/8") & weld it then reinstall the screen into the circular slit & tamp it down to crimp it in place. Thank you for (most ) of the replies. I'd like to weld 3 or 4 nuts of the right thickness on the bottom of the pickup to set the clearance exactly where I want it plus have everything supported.
Re: which epoxy? JB weld or ? [Re: RapidRobert] #1497098
09/10/13 09:03 PM
09/10/13 09:03 PM
MICHIGAN
MICHIGAN
WoW!
You might have mentioned the circle track part.
I would think welding would be mandatory on your pictured set up.
Did you make a pan?
I wounder if you might have an issue with Cavitation because of the extreme 90's?
Perhaps Challenger1 has a great idea for your application.
Go drysump.
I hope it works out for you
Re: which epoxy? JB weld or ? [Re: BB65Barracuda] #1497099
09/10/13 09:20 PM
09/10/13 09:20 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I don't know anything about circle track 360s. Do they use pipe fittings like that?
They seem awfully heavy and weak, especially that closed nipple.
You can run a external belt driven pump with a wet sump pan, that what I did with a 572 BBC I used to run. It broke pickups off, it broke entire oil pumps off even with the brace installed. Tire shake in a dragster is brutal. I can't imagine a dirt track is any smoother?
Re: which epoxy? JB weld or ? [Re: RapidRobert] #1497100
09/10/13 10:54 PM
09/10/13 10:54 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
If you are going to go with the set up you have pictured at least change to iron 90"s instead of galvanized. And if I was to do that that pick up ,I would get some tubing bent up , that iron pipe is just to heavy and will crack at the threads. I've welded up pickups similar to yours using 3 different pick ups to get the bends needed. never broke. Just my opinion.
Re: which epoxy? JB weld or ? [Re: rowin4] #1497101
09/12/13 11:10 PM
09/12/13 11:10 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
the main cause for oil pump fractures is due to solid motor mounts . [ you are using solids yes?] as far as the pick up tube goes, a thin wall tube would be much better and easier to support . I would braze a thin wall pickup to the pump and scrap the heavy wall pipe pictured . install the pump and the correct pickup so the pickup is slightly " above " the pan height , then with a 1/4" shim placed completely across the screen section of the pickup ,place the pan onto the engine and bolt it down . now remove the pan and braze the pickup and your clearance is set exactly where you want it. .............from one circle track racer to another !!
Re: which epoxy? JB weld or ? [Re: ek3] #1497102
09/13/13 12:16 AM
09/13/13 12:16 AM
Yeah I'm not real comfortable with that thick wall stuff either. If you have a brand/part # for some thin wall material I'm all ears! The pump is tapped for 1/2 NPT so it'd have to work with that size
Re: which epoxy? JB weld or ? [Re: BDW] #1497103
09/13/13 01:03 AM
09/13/13 01:03 AM
MN
astrobuf Offline
astrobuf  Offline
MN
OMG - my concerns re vibration just quadrupled. You need to build this using 1/2 inch flex copper brazed to a pickup on one end, and a compression fitting to a male adapter on the other end. If rug up a bracket of some kind to the pump body to lock the compression fitting down and provide support tool.
Astrobuf
So, are you really a Rocket Scientist?
Re: which epoxy? JB weld or ? [Re: RapidRobert] #1497104
09/14/13 01:50 AM
09/14/13 01:50 AM
E
ek3 Offline
ek3  Offline
E
canton or champ ,steffs is a great custom mfg check with them for tubing.. which/what pan do you have. you should be able to get a matching pickup for it. if the pump is drilled for 1/2 " , you should be able to get one in 1/2" or you will have to adapt it down to fit the matching pickup.
Re: which epoxy? JB weld or ? [Re: ek3] #1497105
09/14/13 10:31 AM
09/14/13 10:31 AM
The pump is tapped for 1/2 pipe. I do not want to neck it down. I'm using a 392 pan which is a common "center" sump but more toward the front. I do have a std vol pump/matching pickup (for that pan) but I want (need) the hi vol pump tapped for 1/2 along with the other oiling mods. I will see what Steffs has. Thank you!
