Re: Pick the cam: Monster torque at low RPM [Re: 360view] #1496982
09/09/13 10:20 PM
09/09/13 10:20 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
How about the old Comp cams High energy 260? I used one years ago in a 73 Vette 454 with barely 8-1 and 3.08 gears and a turbo 400. It made ridiculous torque, ran 13.80's and idled like a caddy! Performed all out of proportion for its modest specs. As I recall, I ended up getting about 16 mpg on the hiway and the 73 weighed about 4K with my 220 in it. I expect it would be cost effective also.
Re: Pick the cam: Monster torque at low RPM [Re: Lee446] #1496983
09/10/13 11:13 PM
09/10/13 11:13 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
engle 2316H or 2318H probably, installed with a 106-108 ICL....
bullet's HC267/320 lobe looks interesting, might be a little big....maybe get it ground on a 112 and install at 106....
2017 Grand Cherokee Overland
Re: Pick the cam: Monster torque at low RPM [Re: patrick] #1496984
09/10/13 11:57 PM
09/10/13 11:57 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
It's not a cam, but an intake with narrow/restrictive runners will carry a higher velocity fuel/air charge at a lower RPM. I think that would improve the low RPM efficiency and of course kill off high RPM performance.
One example is the Edelbrock SP2P 4bbl small block Chrysler intake.
Re: Pick the cam: Monster torque at low RPM [Re: feets] #1496985
09/12/13 04:41 PM
09/12/13 04:41 PM
League City, TX
BlueGhost Offline
BlueGhost  Offline
League City, TX
I have nothing to add on cam selection, but would like to know your results once you get it all going.
I plan on building a torque monster efi'ed 440 backed by an overdrive for my 58 Plymouth. Your Imperial has to be close in terms of size, weight, and aerodynamics.
1958 Plymouth Suburban
Re: Pick the cam: Monster torque at low RPM [Re: BlueGhost] #1496986
09/12/13 06:36 PM
09/12/13 06:36 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I'm not sure which Plymouth you've got but I can tell you a Fury is comsiderably smaller and lighter than the Imperial.
Anything I do in the Imperial would pay off nicely in a car 20" shorter and 1500 lbs lighter.
- Stu Harmon
Re: Pick the cam: Monster torque at low RPM [Re: feets] #1496987
09/12/13 08:47 PM
09/12/13 08:47 PM
League City, TX
BlueGhost Offline
BlueGhost  Offline
League City, TX
I have a Suburban. A little bigger and heavier than a Fury, but still "small and light" compared to an Imperial.
I'll likely end up with a more aggressive cam than you. Mainly because my 440 will have around 10:1 compression, so I will need more duration to bleed some compression off. I do plan on loping down the highway at 70mph and 2000rpm.
Re: Pick the cam: Monster torque at low RPM [Re: 360view] #1496988
09/12/13 09:26 PM
09/12/13 09:26 PM
dogdays Offline
dogdays  Offline
Bullet cams will regrind your stock hydraulic cam for $60!!!!!
Look at their HC lobe list.
You could run two different cams and see which you liked best. Or grind one for NA and another for the turbo.
With such a wonderful resource I just don't understand not using it.
Call and ask for Tim.
R.
Re: Pick the cam: Monster torque at low RPM [Re: dogdays] #1496989
09/13/13 12:04 AM
09/13/13 12:04 AM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
feets not to be off topic but what route are you going to put the A518 behind the 440?
Re: Pick the cam: Monster torque at low RPM [Re: 72d100] #1496990
09/13/13 10:30 AM
09/13/13 10:30 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Ultra Bell.
- Stu Harmon
