440 Cam rear plug install #1496158
09/04/13 03:03 PM
09/04/13 03:03 PM
Nashville, TN
MOPARMIKE69 Offline OP
Nashville, TN
Ok I have seen several people say install it like a freeze plug with the cup side out. No I see several people saying the cup side goes toward the engine and you dimple the center of the plug to make it seal?
Which is correct????
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 440 Cam rear plug install [Re: MOPARMIKE69] #1496159
09/04/13 03:30 PM
09/04/13 03:30 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Cup side in and
I am truckless..
Re: 440 Cam rear plug install [Re: 340SHORTY] #1496160
09/04/13 03:44 PM
09/04/13 03:44 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
My friend Bill had installed his self-rebuilt Street Hemi in his Coronet. He was standing alongside it revving it up and playing with the carbs when the cam plug blew out of the block, rattled around inside the TorqueFlite bell and was ejected onto his foot! Stung a little! He managed to shut it down before more damage was done and learned the proper way to install the cam plug was cup side first, just like Larry said. You never forget those lessons!!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 440 Cam rear plug install [Re: Polarapete] #1496161
09/04/13 04:42 PM
09/04/13 04:42 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
How did the factory do it?
Re: 440 Cam rear plug install [Re: GTX MATT] #1496162
09/04/13 05:12 PM
09/04/13 05:12 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
DOH !!!
I am truckless..
Re: 440 Cam rear plug install [Re: MOPARMIKE69] #1496163
09/04/13 06:06 PM
09/04/13 06:06 PM
Cup side in and use some good thread sealer on the block before installing the plug If you don't use sealer on the cup and block buy some five minute expoxy and seal the plug to the block around the cup edges, either way will help prevents leaks and seeping
