Re: stroking whats the benifit of a 340 block vs 360?
[Re: 340dart4spd ]
#149529
11/12/08 02:00 PM
11/12/08 02:00 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
Why all the talk about stroker stuff, ya dont need it to get what he wants. ![](/ubbthreads/images/graemlins/shruggy.gif) I'd go with the pre machined 360 and flip the 340 block if it was me. It is worth way more than your paying for it. On second thought, I do have a brand new set of forged pistons for a .040 over 360/410. ![](/ubbthreads/images/graemlins/whistling.gif)
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: 70dart360]
#149530
11/12/08 02:05 PM
11/12/08 02:05 PM
Posts: 2,826 NY usa
540challenger
NY usa
Why all the talk about stroker stuff, ya dont need it to get what he wants. I'd go with the pre machined 360 and flip the 340 block if it was me. It is worth way more than your paying for it.
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: 540challenger]
#149531
11/12/08 02:16 PM
11/12/08 02:16 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
The stroker will be more streetable.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: Dakota_Don]
#149534
11/12/08 05:10 PM
11/12/08 05:10 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
Sell both blocks and pick up a "free" 318 block that everybody just gives away and use that for your build..... 4" crank gives you 390 cubes and good heads should get you 450HP no problem. Cast crank and lite pistons/rods make it easy to internally balance with no mallory. I used ported EQ magnum heads on my 390 and I figure it should be right at 450HP... TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
[Re: blairboy3]
#149538
11/12/08 06:28 PM
11/12/08 06:28 PM
Posts: 75,125 A Banana Republic near you.
JohnRR
I wish this post had come up before I took a 30 over machined 340 block to scrap last month. Got $40 bucks for it.
what made you think it was scrap in the first place ?
[Re: BrianT]
#149541
11/12/08 08:52 PM
11/12/08 08:52 PM
Posts: 465 Oconomowoc, WI.
Cudahlr
Oconomowoc, WI.
I have a 360 with a stock crank and rods everything balanced and proper clearances and edelbrock heads it will run 11.30 all day long and made 421 rwhp and has seen 7000+ rpms many times and I have never had a single durability issue with it and I built the short block 10 years ago!
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp 1985 Harley Sportster Bobber 2006 Ram 2500 sport - The Cudahlr
[Re: BrianT]
#149542
11/12/08 09:25 PM
11/12/08 09:25 PM
Posts: 2,179 California, USA
blairboy3
California, USA
I agree. Should have been worth more than $40 unless there was something seriously wrong with it.
I have a running 340 (bore unknown) in my dart now, and a 360 shortblock (standard bore) that I bought for $100. My plans are to sell the running 340 to help offset the cost of building a 408.
Couldn't get rid of it. I offered it to a couple guys here for $200 + shipping, offered it for just shipping, then tried giving it away locally.... nobody wanted it. Soooo, I took it & a cracked 383 block to the local scrap place. It was decked & line bored. The cylinders were bored .030 over, but had some rust. So, they would have needed to be cleaned up to probably .040.
1968 Plymouth Fury III 4-Door: 12.79 @ 115, 60'- 1.93 (Hey... it's a Cruise ship... what do you expect?!) Famoso Raceway, 02/08
[Re: AARCONV]
#149545
11/13/08 10:45 AM
11/13/08 10:45 AM
JohnRR
the reason I'm sticking with the 340 is that i have 2much invested in the converter...360 takes a different kind...and don't forget the crank balancer also...
Buy a B+M weighted flexplate , problem solved ... or INTERNAL BALNCE IT ??? Your convertor is NOT an issue .
![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: blairboy3]
#149546
11/13/08 12:25 PM
11/13/08 12:25 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Figures. I offered a guy $500.00 for a 340 core here and didn't get it.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: coronet1966d]
#149547
11/13/08 01:49 PM
11/13/08 01:49 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
340's aren't really that hard to find around here. Just a couple years ago I found my running '68 340 with X heads on Ebay, complete from oil pan to intake for $500.
Then again, just last week we bought a complete '88 360 with 727 trans for $99 off Ebay. Even has a carb, distributor, air cleaner, mini starter, power steering pump, clutch fan, and all the brackets. Maybe we're just lucky. lol
