stroking whats the benifit of a 340 block vs 360? #149509
11/11/08 10:17 PM
11/11/08 10:17 PM
Clinton Twp. Michigan
coronet1966d Offline OP
other than the added few cubes, whats the advantage? i found a 1973 340 short block for $150 and that needs to be gone through and i already have a mid 80's 360 thats machined and ready to go what should i do? im aiming for 450hp streetable aluminum heads ect ect
Re: stroking whats the benifit of a 340 block vs 360? [Re: coronet1966d] #149510
11/11/08 10:20 PM
11/11/08 10:20 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I thin at 450 horses with aluminum heads it wont make much difference, the 340 should hold up for sure not so sure about the 360 but I would think 450 horse wouldnt be a problem. 150 for a 340 is pretty cheap though. With machining costs as long as the durability of the 360 isnt in question Id use that, the difference is going to be what, 8 cubes or so? Not enough to really make a difference IMO.
Re: stroking whats the benifit of a 340 block vs 360? [Re: GTX MATT] #149511
11/11/08 10:53 PM
11/11/08 10:53 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Bore size is bigger on the 340 and bearing bore is larger on the 360
Buy the 340, flip it for more money and use that cash to do the 360... If you are on a budget.
Re: stroking whats the benifit of a 340 block vs 360? [Re: GTX MATT] #149512
11/11/08 11:30 PM
11/11/08 11:30 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
what's the durability issue on a 360
Re: stroking whats the benifit of a 340 block vs 360? [Re: JohnRR] #149513
11/11/08 11:47 PM
11/11/08 11:47 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Re: stroking whats the benifit of a 340 block vs 360? [Re: moparpollack] #149514
11/11/08 11:56 PM
11/11/08 11:56 PM
MI
marklock Offline
I tried too hard for a custom title
marklock  Offline
MI
I like the smaller mains on the 340, less load on the bearings at high rpm. My
Re: stroking whats the benifit of a 340 block vs 360? [Re: marklock] #149515
11/12/08 12:02 AM
11/12/08 12:02 AM
JohnRR Offline
JohnRR  Offline
more bearing will handle a larger load , less FRICTION with the smaller bearing .
I'm still waiting for the DURABILITY issue ...
Re: stroking whats the benifit of a 340 block vs 360? [Re: JohnRR] #149516
11/12/08 12:06 AM
11/12/08 12:06 AM
85086
Lil Herman
Lil Herman
85086
Re: stroking whats the benifit of a 340 block vs 360? [Re: JohnRR] #149517
11/12/08 12:07 AM
11/12/08 12:07 AM
i was under the impression that 340's had thicker webbing in the main bearing area
Re: stroking whats the benifit of a 340 block vs 360? [Re: moparpollack] #149518
11/12/08 12:09 AM
11/12/08 12:09 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Yeah, no kidding. I ran 7800rpm in my race car for 6 years on a stock cast crank 360 with H-beam rods and hypereutectic pistons. Finally took it apart after all that time, and it looked brand new. My vote is for the 360. There is nothing magical about a 340, or the block itself. 8 cubes is 8 cubes!
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: stroking whats the benifit of a 340 block vs 360? [Re: 69L78Nova] #149519
11/12/08 12:18 AM
11/12/08 12:18 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
I don't think the 340 webbing is any thicker (Except for a TA block). The main cap bolts are spaced further apart on a 360 because of the larger bearing. I would think thay are about the same strength. The 8 cubes won't make any difference.
Even if you decide to build the 360, you should still get that 340 for $150. Flip it and put the money toward the build.
Re: stroking whats the benifit of a 340 block vs 360? [Re: JohnRR] #149520
11/12/08 01:06 AM
11/12/08 01:06 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Oh there was none in my opinion, i was saying I wasnt sure if the 360s are known to be reliable to 450 hp or not, not that I wasnt sure Id trust it to 450. Basically I was saying that as long as there isnt a durability issue then thats what Id use.
Re: stroking whats the benifit of a 340 block vs 360? [Re: GTX MATT] #149521
11/12/08 02:28 AM
11/12/08 02:28 AM
RobX4406 Offline
RobX4406  Offline
Lots of 500-600hp 360 based strokers running around.
450hp is a piece of cake for a SB mopar block.
Re: stroking whats the benifit of a 340 block vs 360? [Re: RobX4406] #149522
11/12/08 02:40 AM
11/12/08 02:40 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Well thats enough proof right there
Re: stroking whats the benifit of a 340 block vs 360? [Re: GTX MATT] #149523
11/12/08 04:28 AM
11/12/08 04:28 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
You'll find the durability limits of either block with much over 500HP, most people build what they have or have parts for, 340 blocks usually cost/are worth more and are harder to find so it's pretty much a toss up for you since you already own both, in your shoes I'd shop for stroker parts and see which ones you come up with for the lowest cost for whichever engine.
Personally I like the 340's for nothing more than name only, either is a great base for a street strip 400-500HP stroker build.
Re: stroking whats the benifit of a 340 block vs 360? [Re: ScottSmith_Harms] #149524
11/12/08 10:58 AM
11/12/08 10:58 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
When the 360 was introduced, didn't they use the same casting for both motors, thus leaving the 360 with thicker cylinders, or am I smoking something?
Re: stroking whats the benifit of a 340 block vs 360? [Re: 375inStroke] #149525
11/12/08 11:04 AM
11/12/08 11:04 AM
JohnRR Offline
JohnRR  Offline
No , you are correct , if building a smallblock stroker that's a good base .
Re: stroking whats the benifit of a 340 block vs 360? [Re: JohnRR] #149526
11/12/08 12:15 PM
11/12/08 12:15 PM
MI
marklock Offline
marklock  Offline
MI
I stand corrected
Re: stroking whats the benifit of a 340 block vs 360? [Re: marklock] #149527
11/12/08 01:16 PM
11/12/08 01:16 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
There is very little difference. For 450hp, either one is fine. I second the "buy it, sell it, invest the proceeds" idea. A 408 with a mild hydraulic cam is 450hp. And "mild" in terms of a camshaft in a 4" stroke engine starts at 245°@.050. The 340 has less vlave shrouding, the 360 piston rocks less and can get closer to the head safely in a max effort build. IMO, the mains dont mean squat. In fact, the piston rock and shrouding don't mean a heck of a lot until you max things out anyway.
Re: stroking whats the benifit of a 340 block vs 360? [Re: moper] #149528
11/12/08 01:47 PM
11/12/08 01:47 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
reminds of several articles where I read about 340 pistons in a 360,that was before stroekr kits,, I belive mopar engine manual touches on the subject....
