Re: Vapor Lock/Fuel Boil
[Re: ahy]
#1493652
09/02/13 01:48 AM
09/02/13 01:48 AM
Challenger 1
Cincinnati, Ohio
If you have a clean sound "sock" on the fuel pickup that should protect the pump. It serves the same purpose as the 100 micron filter before the pump. Personally I'd pull the pickup next and have a look see. If the sock is intact and is clean or can be cleaned, simply remove the filter before the pump for a test.
Summit does have the 100 micron filters if you really want or need one. A local speed shop, if there is one near you, should have them also.
Exactly...
But this is a ford panel truck... I bet your sock/strainer in the tank is old/dirty and could be causing the restriction.
[Re: Challenger 1]
#1493653
09/02/13 12:06 PM
09/02/13 12:06 PM
Posts: 102 pensacola, fl
53fopar
pensacola, fl
I am going to try the 100 micron filter before the pump to see if it was a flow restriction there.
The only way to check the sock/pickup is to drop the tank. But, I still don't understand how that could be the problem. The engine runs fine in cool weather (anything under about 80*). This ONLY happens when it's hot outside. I still think it's a vapor lock/fuel boil issue.
[Re: 53fopar]
#1493656
09/03/13 11:57 PM
09/03/13 11:57 PM
Posts: 7,664 IN
ahy
IN
[Re: 53fopar]
#1493657
09/04/13 10:31 AM
09/04/13 10:31 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
Before I go through dropping the tank, I think I'll try a test. I am going to pull the fuel line off the tank and put it in a gas can. I'll also remove the filter ahead of the pump. If it still shuts down running from a gas can, I'll have to re-think. If it runs, I'll drop the tank, clean, seal and new sock. Sound like a reasonable plan?
This is a good test , use a boat fuel tank for max safety and lose the pre pump filter.
One thing you did that made zero sense was removing the filter AFTER the pump , you should have removed the filter before the pump it's too fine for the pump to suck thru.
[Re: JohnRR]
#1493659
09/04/13 10:12 PM
09/04/13 10:12 PM
53fopar
pensacola, fl
I was thinking the in-line Mr Gasket was drawing heat since it was up front by the alt. I've ordered the Holley 100 micron pre pump and 40 micron post pump filters and will mount them by the pump.
[Re: TJP]
#1493660
09/04/13 10:16 PM
09/04/13 10:16 PM
53fopar
pensacola, fl
I wouldn't seal the tank. I have seen all too many sealed tanks fail and create a mess. If your tank is contaminated just put a new one in they are relatively inexpensive
New tank for this truck is $500 plus oversized shipping. I am going to try the KBS clean/seal system. I seen several good reviews. Anyone here used it?
