Re: Cam break in is done!....Now more questions!
[Re: Kern Dog]
#1492988
09/13/13 10:44 AM
09/13/13 10:44 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
I've never had any faith in Don! He likes to use the vacuum advance to hold idle up using manifold vacuum instead of the intended light cruise it was designed for on ported vaccuum. Its not really relivant with todays gas on a performance motor. Guess if you don't know how to make a cammed motor idle that is what you do :-) . I would like to see a looser converter but at this point drive see where you are and go from there. 3800??? recurving a distributor is a 5 minute job so do it yourself and try different things. Your msd should have came with an advance kit different springs and stops http://chucker54.stores.yahoo.net/msdbuspset.htmlhttp://chucker54.stores.yahoo.net/disadweigspr.htmlyou can try the big stop 18 degree?? and stiff springs to slow down the advance to come in later. everything in this game is trial and error to get it best!
[Re: Kern Dog]
#1492989
09/13/13 12:11 PM
09/13/13 12:11 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
I have emailed with Don at FBO. Many members here know him to be a knowledgeable guy with ignition systems. I inquired about having my distributor recurved for my application. He responded, asking all of the various specs and the intended use of the car. In summary, he thinks my whole combo is out of whack! Converter too tight for the car, too tight for the cam, Timing comes in too early. He didn't like that I blocked off the vacuum advance. He thinks my carb jetting is off. He feels If I want an engine that is easier to drive, I'd need a smaller cam. I'm more confused now!
What converter are you running?...I didn't see where you said but I don't have the time to re-read this entire thread ;-)
I would think anything in the 2500+ (ideally 3000+) stall range would at least 'work' in your combo. I am not going to trash talk anybody as I am far from an expert but I don't think a slightly less than ideal converter would cause all this pinging. I run a 2500 stall converter on mine with no issues (although I have the wimpy-ish cam).
Yes, your cam is a bit radical for a street car IMO (although 'street' is subjective) but still should be able to work better than this. I summary, I don't think your converter/cam is the problem here....even if it's not ideal.
FWIW, I don't use the vacuum advance on my distributor at all. My distributor (MP) has a total mechanical advance on 18*. The vacuum advance made it tend to ping unless I pulled back the initial which the engine didn't like as much. The chassis dyno agreed.
[Re: RapidRobert]
#1492990
09/13/13 01:22 PM
09/13/13 01:22 PM
Posts: 4,179 California
mickm
California
& I thought you (we) were making progress here
i don't think you should take all that too literally, at least not yet. i've been following this thread, and there are a lot of knowledgeable people here, and i haven't seen anyone yet say your whole combo is out of whack. may not be perfect, but whose is in everyone's eyes? ok, well, mine is, but hey...
anyway, keep going and see what you get. this is a b!tch, and it is no fun right now, but the knowledge and experience you are accumulating is vast. when you get to the end of this, you will know more about the systems on these cars than you ever imagined, and it will all have been worth it!
[Re: Dodgem]
#1492992
09/13/13 03:37 PM
09/13/13 03:37 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
Of all the things you've tried and learned how to do, this seems like it would be the easiest and least expensive and most likely to help your problems. Hang in there! After all this, I need to hear a sucess story and that you were able to ride off into the sunset and
[Re: Dodgem]
#1492993
09/13/13 03:52 PM
09/13/13 03:52 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I actually have the Mopar Performance distributor that is built with "Mallory" internals, but I would imagine that the theory is the same.
[Re: Dodgem]
#1492995
09/13/13 06:38 PM
09/13/13 06:38 PM
Kern Dog
Granite Bay CA
Thanks, Dodgem. I will look into this no matter what else I decide. I just went for a drive. No leaks anywhere but it is still pinging. I talked to Jim at Racer Brown. After telling him about the issues here, he thinks that my pitiful .056 quench clearance coupled with high compression is a big factor. He thinks that the real solution is to zero deck the block and run the .039 Fel Pro gasket to have proper quench. He is a believer that even with higher compression, the benefits of quench allow higher compression without detonation. It all sounds great in theory. The zero deck would raise the compression from the current 10.73 to 11.13. Thats 4 tenths! Jim also suggested running a thinner head gasket as a test. A Cometic .027 would reduce my quench distance to .44 and raise the compression to 11.03. Another interesting thing from Jim: When I told him that the Lunati cam made more cranking compression than the MP 509, he thinks it could be because of the valve lash! He said the lash acts as a delay in the reaction of the rocker arms. A solid with bigger specs can actually result in less lift and duration than a hydraulic with smaller numbers. In short, my valve lash may be responsible for making the Lunati act smaller than the 509, resulting in MORE cylinder pressure. He thought that I could try tightning the lash on the intake from .020 to .016 and see if that helps. The car detonates worse now than it did with the 509 cam. I think it is partly due to the bump in cylinder pressure. I'm running a 50/50 mix of 91 and 100 now and it knocks. I think that several months back I wrote that on a 50/50 mix of 91 and 110 it ran great with the 509. The numbers are not an exact comparison though, so I may dump the 5 gallons of 110 I have in and drive it again.
Thinking back to June or July before I bought any parts, I talked to Dwayne Porter. He thought that a zero deck engine would be the best route, but also spoke of having the pistons milled on the valve side maybe .040 to lower compression some. If I ever decide to pull the engine, this may be the way to go. I'd have quench while being around 10.25 to one.
[Re: RapidRobert]
#1492999
09/13/13 07:56 PM
09/13/13 07:56 PM
Kern Dog
Granite Bay CA
I am following this thread closely also & we will get resolution. I'm thinking it's gonna take MORE octane or a piston change & all that goes with that. when you build a monster it needs to be fed properly, no other way around it
I just poured in about 3 1/2 gallons of 110 leaded and drove the car. This sucker is scary fast! Not a hint of detonation and it pulls harder than ever. This is with the 17 initial, 30 total timing. I was so giddy when driving it I didn't stop to bump the timing to 20/33. So it has been determined that the engine in this state will run without detonation as long as I'm using high octane fuel. Even with a carb that may be jetted wrong or a distributor that may not have an optimal advance curve, the high compression engine can run strong.
While I am happy that the knock is gone, I still want to get it to run on 91 octane.
Head gasket thickness is a hot topic, but it is one way to eliminate the detonation. There are many smart guys that tell me that using a thinner gasket will close up the quench distance and cut down on the detonation even with the higher compression. These same guys are often against using a thicker gasket because they feel the wider quench distance removes any benefit that quench was giving. Being at .056 right now, I have asked numerous times if I was even getting any effects of quench. Very few of these smart guys chimed in. I even asked builders point blank about this and do not remember anyone giving me a clear cut "Yes you have quench" or even a "Heck no you don't". The arguement for going with a thicker head gasket has been discussed by many. I recall many saying that if all quench is gone at .056, I have no quench to lose by going to a thicker gasket. The gain , however is a reduction in compression which in theory, helps against detonation. Thinner head gasket or thicker to stop the knock? Maybe in my case, both are possible. I tried the thicker gasket route before and it worked. Maybe I'll consider trying the thinner gaskets this time. For about $220 I can have a pair of the Cometic .027 gaskets.
[Re: Kern Dog]
#1493000
09/13/13 09:49 PM
09/13/13 09:49 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: RSNOMO]
#1493001
09/13/13 10:22 PM
09/13/13 10:22 PM
Kern Dog
Granite Bay CA
I've been looking at the options for head gaskets at SummitRacing. Fel Pro # 1105 has a 4.590 bore, .051 thickness and a 13.7 cc. It moves my compression to 10.36. Cometic # .051 has a 4.380 bore, a .051 thickness and a 12.59 cc. I get a 10.47 CR there. http://www.summitracing.com/parts/cgt-c5464-075/overview/make/dodgeCometic # 5464-075 has a 4.5 bore, is .075 thick and a 19.55 cc. It drops the compression to 9.89! That would surely allow some wiggle room for even running 89 octane gas! When I ran the .060 Cometics before, I was told I'd have intake gasket alignment issues. Luckily, I did not. These .075 Cometics are .015 thicker. If I decide to go this route again, WHO makes a thicker paper intake gasket? The Fel Pro ones are pretty thin.
[Re: Kern Dog]
#1493002
09/13/13 11:41 PM
09/13/13 11:41 PM
RapidRobert
What is the compressed thicknes of the current gaskets? You have .056" quench now (which is actually no or very little quench). I am a quench proponent but I think the SCR is too high for quench to take care of you on this. I'd go with that .075" gasket you mentioned. I dont see a problem doubling up on the intake paper gaskets as they are smooth with no beaded/raised edges. Permatex spray "high tack" part #99MA the red stuff is extremely tacky/seals well/goes on light/even would work well for gluing 2 of em together & even some super glue on some areas not near the ports to aid in keeping them connected as you go together. I would vastly lower the SCR which'll give you some wiggle room & also select the cam you want rather than putting up with a compromise choice cam which the vastly lower SCR will let you run a good curve & give you more power than a higher SCR with the compromised curve which you have now even if you get under the pinging point. In other words with the correct cam then if for example if 9.5 will just stop the pinging I'd go a bit lower then optimize the curve. A bit too low is better than too high. It's all in the curve
