Re: Advantages of T56 over Passion 5 speed?
[Re: 67autocross]
#1492585
09/09/13 11:02 PM
09/09/13 11:02 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
More like comparing apples to unicorns, one is a real transmission that has been around for years and the other is not in the hands of the public. Plus this is the corning section were most guys don't mind a bit of cutting or fender rolling. Not many here have big dollar original number matching cars that they are road racing.
So I guess a guy who road races AND enjoys original cars isn't welcome in your little club?
Why then was a transmission that's "not yet in the hands of the public" even being asked about? If you want to compare transmissions why not compare products that have been around a while in racing? Why drag a Passon into it?
[Re: PHJ426]
#1492586
09/09/13 11:17 PM
09/09/13 11:17 PM
Posts: 7,664 IN
ahy
IN
If a car has a 5 speed installed does that make it "not original"?
I do understand your point on the cutting the floor and trans/torsion bar mount cross member.
There has to be a point where an all original car is 100% original things like Detroit Air in the spare and so on.
My question should have probably been more specific like is it really necessary to have 6 speeds instead of 5 in a car that gets driven on the street to get to the track or high speed driving event .......not for a concourse show car.
Necessary... no. Beneficial, yes. I run a Keisler TKO 5 speed (and like it). The choice of OD ratio was a compromise. The .82 or "close" ratio was an ideal top speed gear with my setup. The steeper .64 (from memory) was a better cruise gear for best economy and least noise and wear. I went with the .82. It cruises at 75 mph/2700 RPM. No problem. That said, the 496 would be happy cruising in the lower 2000's and get better mileage with less noise and wear. A six speed could do both.
[Re: 67autocross]
#1492589
09/10/13 12:08 AM
09/10/13 12:08 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I did not drag the Passon into anything, the original poster asked about it and you jumped in to tell us all the advantages it has, even though I can't buy one.
The Passon transmissions are currently being built, the way to buy one is to call him and get your name put on the waiting list as he has a good number of customers already in line, 300 or more from what I last heard. I got on the list way back when he first started it and based on recent phone calls I'll have mine very soon, I'll post pics when it arrives.
[Re: ScottSmith_Harms]
#1492591
09/10/13 03:02 AM
09/10/13 03:02 AM
Posts: 1,491 Lethbridge, AB, Canada
dangina
curious, saw this a long time ago, I think they have said available soon for the past year or two, did they give you a set date yet? would like to see a few guys running them before i pull the plug
[Re: Supercuda]
#1492598
09/10/13 08:27 PM
09/10/13 08:27 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
People that would spend 4-5k on a Keisler or equivalent will be all over Jamie's trans. I'm just not one of those people. T56's have there place and so does a true bolt in 5 spd. I always wanted gearing that would allow my car to run like a SS car at the strip and cruise down the interstate at 2000 rpm at 80 mph. I have that now.
Mopar to the bone!!!
[Re: DoctorDiff]
#1492600
09/10/13 09:49 PM
09/10/13 09:49 PM
Posts: 3,456 Fly Over States
PHJ426
Fly Over States
I don't understand your point.
Passon did debut the prototype at the PRI show in 2010.
The original question is and always was what is better a new Passion 5 speed or a T56 6 speed in a real street car/track car.
Certain contributors to this thread kept on saying the Passion 5 speed is not available....yada yada yada. Yes the Passion 5 speed was at the show in 2010, but its really not readily available.
All of this is just an aside to the deal of the real question what is better Passion 5 speed or T56 6 speed in a real street car.
[Re: jcc]
#1492602
09/11/13 12:06 PM
09/11/13 12:06 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
From a "competition" point of view, I'd be interested to know which tranny is the lightest... Passon 4spd od, 5spd, Kslr 5spd, or 6spd?
Too much shifting may not be the best advantage... drive the car without having to worry about shifting... road course racing can allow some time to shift, but pylon autocrossing doesn't favor time to shift up/down... too much lost time and upsetting the car's balance while manuevering through the cones... fractions of seconds add up quickly.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#1492603
09/11/13 01:28 PM
09/11/13 01:28 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Autocross I typically leave in 1st or 2nd. Road course I'm in mostly in 3rd or 4th, 5th on straightaways. 6th for the drive there and back Stick may be slower but sure is more fun!
