Page 2 of 6 1 2 3 4 5 6
Re: Advantages of T56 over Passion 5 speed? [Re: 72Swinger] #1492564
08/30/13 12:43 AM
08/30/13 12:43 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
T-bar crossmember is 2x1/2x1/4" C-channel that is plated underneath the bends.
Mopar to the bone!!!
Re: Advantages of T56 over Passion 5 speed? [Re: 72Swinger] #1492565
08/30/13 12:44 AM
08/30/13 12:44 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Rear of it
Re: Advantages of T56 over Passion 5 speed? [Re: 72Swinger] #1492566
08/30/13 12:46 AM
08/30/13 12:46 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Underneath
Re: Advantages of T56 over Passion 5 speed? [Re: PHJ426] #1492567
08/30/13 12:47 AM
08/30/13 12:47 AM
Eastern shore, New England
roadrunner69s Offline
I know the Tremec T56's made in Mexico from 1998-2004 are somewhat weak on forks and synchros...at least compared to the T56's that were built in earlier years by Borg-Warner. I don't know if the quality has improved since then. If using one of these I'd insure that all the earlier weak links were taken out on the rebuild. To me, T56's can be a litte rattly with various whines specific to each build. I don't know what quality the factory is putting out on these for new aftermarket builds. Other than for highway cruising at >65 mph the 6th gear (with 3.55 or lower ratio) has limited use. I have 3.42's and 1st through 4th covers about 98% of all my driving. With real stiff rear gears 5th and 6th probably become a lot more handy. I know that having that extra 6th gear slot has lead to occasional missed shifts in either direction. My favorite is going from 3rd to 6th and losing all power. And 6th to 3rd at highway speed to climb a hill can be fun too, though pretty rare. Sometimes I wish 6th weren't there so those 3-4 or 6-5 shifts weren't as "missable."
Re: Advantages of T56 over Passion 5 speed? [Re: 72Swinger] #1492568
08/30/13 12:51 AM
08/30/13 12:51 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
18 gauge sheet for tunnel.
Re: Advantages of T56 over Passion 5 speed? [Re: roadrunner69s] #1492569
08/30/13 01:00 AM
08/30/13 01:00 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The Magnums are made in South America somewhere to this day. I know the GM T56's used lighter duty parts everywhere possible, like the forks in those were pot metal or aluminum and Vipers always used steel. And I agree quality control at BW was probably head and shoulders above Mexico. Im not here to defend T56's, I only own one. But before I bought mine I did a ton of research and got alot of info from a guy who maintained/built the transmissions for the Woodhouse Viper race effort. The biggest thing he kept making a point of is the clearances and setup is crucial to shift quality and the life of them as a whole.
Re: Advantages of T56 over Passion 5 speed? [Re: 72Swinger] #1492570
08/30/13 09:07 AM
08/30/13 09:07 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
ok this is probably a stupid question, but what do you do about carpet after you cut the floor all to bit and stretch to stuff the T56 in? can stock carpet be remolded or do you need something different?
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Advantages of T56 over Passion 5 speed? [Re: Jerry] #1492571
08/30/13 10:29 AM
08/30/13 10:29 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Has the richmond 5 spd lost all favor in this discussion?
Re: Advantages of T56 over Passion 5 speed? [Re: Jerry] #1492572
08/30/13 10:37 AM
08/30/13 10:37 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I re-used the carpet that was already in the car. It had to re-mold itself back in the footwells a little but its good to go. My cross member was made like it was for this reason, to keep the tunnel height at a minimum.
Re: Advantages of T56 over Passion 5 speed? [Re: jcc] #1492573
08/30/13 03:57 PM
08/30/13 03:57 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
isn't the richmond a 1:1 5th gear, making it an ideal "race only" transmission? the question here is about the Passion OD trans vs the T56, an OD trans.
anyway, I love the T56. I have one in my Dakota and don't have any complaints. Now, for the 3rd generation Dakota, it truely is a "bolt in" transmission, no sheetmetal modification required.
that said, I spent $1500 in the transmission off Ebay (used Viper spec T56) the quicktime bell was about $500, and then I got a custom flywheel made that had the tone ring for the factory EFI, cost me about $500. (non EFI motors can use a much cheaper flywheel option) and I have about $250 in my clutch.
the hydraulics are a hybrid of the SRT-10 truck hydrualic bearing (yes, slightly different than the viper part) and the stock Dakota master cylinder.
it was a pretty simple swap that if I had a factory 5-spd truck and the parts, I could knock it out in a day. If I had to start with an auto truck that needed a hole cut, and pedals added, then I would venture to say that it might take me a day and a half to 2 days.
**Photobucket sucks**
Re: Advantages of T56 over Passion 5 speed? [Re: 70Cuda383] #1492574
08/30/13 04:15 PM
08/30/13 04:15 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
No, not necessarily. It simply allows you to reduce rear end ratios and use "economy" gear sets like 2:94, 3:08, and 3:23, which a lot of guys have kicking around as throw aways.
Re: Advantages of T56 over Passion 5 speed? [Re: TC@HP2] #1492575
08/30/13 07:07 PM
08/30/13 07:07 PM
AndyF Online content
AndyF  Online Content
I have a Doug Nash 4+1 in my '65 Coronet. I was probably one of the first guys to do a 5 speed swap into a Mopar. I put the Doug Nash in my car about 30 years ago. I don't recall the serial number on the trans put it was an early one. It was more work than I could handle at the time but it was fairly simple for a local street rod guy. He moved the shifter box in the tunnel and made some mods to the crossmember. The linkage had to be custom built and there were a few other odds and ends.
Re: Advantages of T56 over Passion 5 speed? [Re: AndyF] #1492576
09/09/13 04:55 PM
09/09/13 04:55 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
New A-855 AVAILABLE SOON!
When?
Re: Advantages of T56 over Passion 5 speed? [Re: 375inStroke] #1492577
09/09/13 05:35 PM
09/09/13 05:35 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
The biggest advantage for the T56 is the fact that it exists.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Advantages of T56 over Passion 5 speed? [Re: AlexP] #1492578
09/09/13 07:16 PM
09/09/13 07:16 PM
mass
K
kotacars Offline
kotacars  Offline
K
mass
price I got a 2005 viper t56 6spd with 3,000 miles on it I know because I took it out of the car for 1,700 dollars then I put it behind my 600 hp small block now I have miles of smiles lol
Re: Advantages of T56 over Passion 5 speed? [Re: PHJ426] #1492579
09/09/13 08:48 PM
09/09/13 08:48 PM
Detroit boy in Saugerties, NY
BrianShaughnessy Offline
I put a T56 in my old 89 Firebird after taking out a T5... so much happier. It was from a 95 TA / 2.66 1st, .5 6th.
3.70 gears in the car... it's awesome. If anything tho a .62 6th gear would be better. .5 is just too much.
The TKO600 made me so much happier than rowing the 833 in the Charger... the only perceivable problem is the big drop from 4th to 5th with the .64 5th and 3.73 gears. Somewhere between 45 to 50 mph I start thinking about upshifting but I really need to wait till 55ish.
If you got the guts I'd do the T56... I sorta wish I did myself.
If you got a friend with a T56 equipped car I'd recommend taking one for a ride just to try it out.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana.
Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart.
El Grande: '98 Grand Cherokee 5.9 Limited.
Re: Advantages of T56 over Passion 5 speed? [Re: BrianShaughnessy] #1492580
09/09/13 09:21 PM
09/09/13 09:21 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
None that I can see, that's comparing apples to oranges IMO.
The Passon is a bolt in 5 speed with ZERO hacking required to install it (The Passon is all alone in this niche, there is no competition) plus the Passon uses the stock bell housing, clutch, drive shaft, shifter location, etc. For an original car I don't see that there are any other good choices.
Re: Advantages of T56 over Passion 5 speed? [Re: ScottSmith_Harms] #1492581
09/09/13 10:05 PM
09/09/13 10:05 PM
Fly Over States
P
PHJ426 Offline OP
PHJ426  Offline OP
P
Fly Over States
If a car has a 5 speed installed does that make it "not original"?
I do understand your point on the cutting the floor and trans/torsion bar mount cross member.
There has to be a point where an all original car is 100% original things like Detroit Air in the spare and so on.
My question should have probably been more specific like is it really necessary to have 6 speeds instead of 5 in a car that gets driven on the street to get to the track or high speed driving event .......not for a concourse show car.
Re: Advantages of T56 over Passion 5 speed? [Re: PHJ426] #1492582
09/09/13 10:49 PM
09/09/13 10:49 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
No, it is not NEEDED to have a 6 speed but I had one installed because I have always WANTED one in my car. My other car is a 6 speed and I would not have been happy with any less gears. I saved up my money for a long time and went ahead with the install before I got to spend it on anything else. Believe me I was on the fence about the install but I figured you only live once and said screw it what do I got to lose?!
I did notice that my gas mileage went up though!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Advantages of T56 over Passion 5 speed? [Re: PHJ426] #1492583
09/09/13 10:53 PM
09/09/13 10:53 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
You just answered your own question.
Not sure what your question is on that one?
In my experience a 6 speed won't offer much real world advantage over 5 speed for a driver or occasional track car.
What I like about the Passon 5 speed is simply this; If someone has a stock car with a body that hasn't been modified in any way and who wants to install a transmission which will allow the car to be more fun to drive he can do so with no worries about originality, and that's because it's a simple bolt in to swap back the stock original without worrying about body work on the floors and tunnel. The rarer and more desirable the car, the more this matters to some.
