Re: 62-63 b-body 8 3/4 [Re: DoctorDiff] #1492250
09/01/13 11:58 PM
09/01/13 11:58 PM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
if i don't get those axles from you, what axles can be shortened to those lengths?
Re: 62-63 b-body 8 3/4 [Re: DoctorDiff] #1492251
09/02/13 03:18 PM
09/02/13 03:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Doc's info is correct, a pocket calculator needs a brain to work correctly....sorry for the wrong info.
Because of a step down in diameter near the splined end of the axle shaft, 28" is the accepted maximum length for shortening/resplining most axles and a 31" axle with minimum step down is needed but a rare few don't have a long step down and might finish out to 28.4"
Re: 62-63 b-body 8 3/4 [Re: John_Kunkel] #1492252
09/03/13 12:00 AM
09/03/13 12:00 AM
las vegas,nv
las vegas,nv
its cool thanks for the photo which ones can be cut down.
Re: 62-63 b-body 8 3/4 [Re: topside] #1492253
09/05/13 03:08 PM
09/05/13 03:08 PM
las vegas,nv
las vegas,nv
all i have to is take the bearings out put in the 65 and newer bearings in it.
Re: 62-63 b-body 8 3/4 [Re: mopar muscle7271] #1492254
09/05/13 07:54 PM
09/05/13 07:54 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IIRC the bearings/axles between the 62/64 rear axle and the bearings/axles from a 65 and newer rear axle are not interchangeable.
I am truckless..
Re: 62-63 b-body 8 3/4 [Re: mopar muscle7271] #1492255
09/06/13 12:31 AM
09/06/13 12:31 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
1965 and newer wheel bearings will not fit your original axles. In addition, you can not reuse your original brakes or inner seals if you convert to 1-piece axles.
Re: 62-63 b-body 8 3/4 [Re: DoctorDiff] #1492256
09/07/13 03:13 AM
09/07/13 03:13 AM
las vegas,nv
las vegas,nv
if i get that rearend i will probably end up gettin the axles from you then dr.diff
