Re: 62-63 b-body 8 3/4
[Re: DoctorDiff]
#1492232
08/29/13 05:53 AM
08/29/13 05:53 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The C body and truck axles wont work in the 62/64 rearends . You would need to cut your ends off and weld on the 65 and newer ends. Theres a difference in the bearings.. Dr Diff is your go to guy in this case.. ![](/ubbthreads/images/graemlins/drive.gif)
I am truckless..
[Re: mopar muscle7271]
#1492237
08/29/13 03:21 PM
08/29/13 03:21 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I put a 65 B-body Plymouth rear in my 63 and it fits and works great. I would either find a 65-70 rear or let Dr Diff set you up. Ron
#1492242
08/31/13 01:58 AM
08/31/13 01:58 AM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
No,,, I used simple math and used the mearurements for the various 8 3/4 rears provided in the Tech Section.. ![](/ubbthreads/images/graemlins/hammer.gif) but if you made a call to Dr Diff he could tell you exactly what tength they are..
I am truckless..
#1492248
09/01/13 05:54 PM
09/01/13 05:54 PM
Posts: 26,037 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If you're looking for the equivalent flanged axle length to fit the '62-'63 B-body housing it would depend on whether or not the center section is original and whether it has Sure-Grip or not (prior to '64 axle lengths changed with Sure-Grip or not).
To replace the tapered axle with a flange axle in a Sure-Grip rear end you'd need an axle length of around 25 7/8" which is well within the range that can be attained using a shortened/resplined factory axle.
