Re: V10 HP PARTS [Re: dogdays] #1491627
08/29/13 08:36 PM
08/29/13 08:36 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
A couple of turbos would increase power by a lot.
R.
You only need one. And a custom PCM.
Re: V10 HP PARTS [Re: V10nacuda] #1491628
08/29/13 08:37 PM
08/29/13 08:37 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
If I remember correctly stock V-10 was 310 HP and 450 lbs, torque new.
Kinda wish I could find a low mileage 4x4 without rust!!
Whatcha got to trade?
Re: V10 HP PARTS [Re: BUBBAZ572] #1491629
08/30/13 09:01 AM
08/30/13 09:01 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
http://dodgeram.org/tech/gas/more_power/V10.htm
has old V10 perf part numbers useful in eBay searches
In the late 1990s ramhack (Christopher J Siano) in Ashland MA bought a kit and ran a supercharged iron V10 Ram with 32 lb/hr fuel injectors that seemed to do quite well
http://web.archive.org/web/20000523104430/http://www.off-road.com/dodge/Features/ramhack.html
In Pompano Beach Florida there is a racing shop that usesstroked Viper V10s in European style endurance racing whose in house crankshaft machining equipment makes long stroke cranks from V10 Chrysler forged blanks.
My memory is fuzzy and a Google search does not bring them up, but i think they go as large as 4.5 inches.
Re: V10 HP PARTS [Re: 360view] #1491630
08/30/13 09:54 AM
08/30/13 09:54 AM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
Another list from another forum I came across posting part numbers/etc for the truck v-10:
Performance computer Mopar 94 95 ALL P5249548
Performance computer Mopar 96 All P4876133
Performance computer Mopar 97 Federal P4876473
Performance computer Mopar 97 Cali P4876471
Performance computer Mopar 99 Federal P5007131
Performance computer Mopar 99 Cali P5007132
Performance computer Mopar 00 Federal P5007211
Performance computer Mopar 00 cali P5007212
Computer Chip Jet Stage 1 97 to 02 90013
Computer Chip Jet Stage 2 97 to 02 90013S
Engine management Roe Racing Roe Racing controller
180 Degree T stat NAPA Weirstat #613080
Offset Camshaft Keys Mopar P5249600
Camshaft Mopar P4876060
Camshaft Crower Idle to 5000K 84565
Camshaft Crower 1000 to 5700 84566
Camshaft Crower custom V10 grind 00060
Camshaft Comp Cams 800 to 5000 98-315-10
Camshaft Comp Cams 1200 to 5200 98-325-10
Camshaft KRC 218/224
Roller Rockers Crower 1.6 ratio 73657K
Roller Rockers Crower 1.7 ratio 73659K
Forged Pistons Ross 94 to 02
Throttle Body Fastman 52mm
Throttle Body Fastman 53mm
Throttle Body KRC
Throttle Body Magnum performance
Air Filter K&N 94-02 #33-2058
Cold Air intake K&N 57-1507
Intake Manifold KRC
Headers PPH
Headers JBA 97-02 #1950S
Headers Mopar 94-95 ALL P5249763
Headers Mopar 96-02 Cali P5249966
Headers Mopar 96-02 Federal P5249967
Headers Gibson ALL GP304
Cat back Gibson 94-02 Side Ext Cab, Short bed 316511
Cat back Gibson 96-02 Side Ext Cab, Long bed 316570
Cat back Gibson 94-02 Side Reg Long bed 316510
Cat back Gibson 96-02 Split Rear 6503
Cat back Mopar 96-97 Cali Long bed P4876276
Cat back Mopar 94-02 Federal Long bed P5249764
Cat back Mopar 98-02 Cali Long Bed P4876849
Cat Back Magnalow 98-02 15616
Supercharger Paxton Novi 2000 94 to 01
Boost/Nittous timing box MSD 94 to 02 # 8962
Nitrous Nitrous Express 100-250 Horse #20234
High perfomance Plug wires Mopar 94-02 P4876434
High perfomance Plug wires Taylor 94-02 74x73
Companies
http://www.truckperformance.com
http://www.Krcperformance.com
http://www.crower.com
http://www.compcams.com
http://www.summitracing.com
from here:
http://www.pavementsucks.com/board/thread-V10-performance-parts--60912
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: V10 HP PARTS [Re: dogdays] #1491631
08/30/13 08:20 PM
08/30/13 08:20 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
and by the time you hunt down all these specialty parts (and obsolete/unobtanium stuff), and get them to work together, you could have easily dropped in a 450+ hp v8 motor, with a pile of cash left over.
Re: V10 HP PARTS [Re: Golden-Arm] #1491632
08/30/13 10:49 PM
08/30/13 10:49 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
A 450 HP V8 wont compare to a tweaked v10 in a 2500 Ram
Re: V10 HP PARTS [Re: WO23Coronet] #1491633
08/31/13 02:56 PM
08/31/13 02:56 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
And it still won't pull like a cummins
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: V10 HP PARTS [Re: BUBBAZ572] #1491634
08/31/13 06:26 PM
08/31/13 06:26 PM
USA
3
360view Offline
360view  Offline
3
USA
the iron 8L V10 is a specialty truck engine for towing
even though it has a reputation as a gasoline hog, back in 1994 Dodge was quite proud of that this 488 ci engine had a better BSFC than the GM 454 V8
there is a SAE paper on the development of the iron V10 that emphasizes its below 3500 rpm towing capabilities
http://papers.sae.org/933033/
Allpar has a pretty good write up on the tech
http://www.allpar.com/mopar/V10.html
sample quote
A Helmholtz resonator intake manifold was tuned to boost torque at 1700 and 3300 rpm. Long primary runners curved over the right cylinder bank to clear the hood. Resonance in the 25-inch primary runners enhanced low speed torque, with peak torque as low as 1200 rpm. Two plenum chambers supplied air to five runners each. Plenum chamber volume was tuned to resonate at 3300 rpm, broadening the torque curve. Passages across the longitudinal center of the manifold fed air from the throttle body to the plenum chambers.
longtime Chrysler engineer Willem Weertman has a section on the V10 in his book "Chrysler Engines"
http://books.sae.org/book-r-365/
Re: V10 HP PARTS [Re: 360view] #1491635
09/02/13 02:56 AM
09/02/13 02:56 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I specifically bought a diesel because of how much towing I had to do to clean out the yard of junk cars. I can say I never even considered a v10. Half I saw for sale over the past few years needed an engine. I'd build an older truck with a 440 before I'd mess with a v10 for towing.
Re: V10 HP PARTS [Re: Silver70] #1491636
09/02/13 07:53 AM
09/02/13 07:53 AM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
my v-10 will roast the 285 75 16 tires and i roast most stock diesels on the road including duramax,cummings ford 6.0.now the turned up diesels will probably smoke my truck.as for building a 440 for towing i have 2 440 trucks they have same power but there is no way i could haul 10000 pounds of load with those without running premium fuel .v-10 87
Re: V10 HP PARTS [Re: d-150] #1491637
09/02/13 09:26 AM
09/02/13 09:26 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Wow! I say we got off track for BUBBAZ. Unless you turbocharge that iron V-10 I think you will end up with truck that gets single digit mileage all the time.
I say trade it on an SRT-10 truck and be done with it. There are plenty of parts for that.
Re: V10 HP PARTS [Re: redraptor] #1491638
09/02/13 09:50 AM
09/02/13 09:50 AM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
all i got on mine headers homebrew cold air intake cat delete.i drove srt10 trucks they are faster then iron v-10 but nowhere near lowend grunt.you cant pull 17000 pounds with srt
Re: V10 HP PARTS [Re: d-150] #1491639
09/02/13 09:58 AM
09/02/13 09:58 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
But he didn't mention towing at the beginning of the thread.
Re: V10 HP PARTS [Re: redraptor] #1491640
09/02/13 10:03 AM
09/02/13 10:03 AM
st.cloud fl
d-150 Offline
d-150  Offline
st.cloud fl
all i am saying is air intake,headers if thats not enough have bullet regrind the cam thats good for 40 horse,40lbs torque old mopar 484 484 use stock springs, lifters.
Re: V10 HP PARTS [Re: d-150] #1491641
09/02/13 01:09 PM
09/02/13 01:09 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I have driven a v10 dump truck before and it had no problem burning the tires off. It also had no problem stopping at the pump often
Re: V10 HP PARTS [Re: Silver70] #1491642
09/03/13 01:54 PM
09/03/13 01:54 PM
Motor City
6PKRTSE Online content
6PKRTSE  Online Content
Motor City
At one time. I bought the Borla headers, cat back dual Borla exhaust, Jet stage 2 chip, 160 T-Stat & K&N Filter for my V10. My Boss at the time just bought a brand new V-10 Ram for himself & paid me cash + some & took all of my stuff & installed on his truck. Complained for months that ever single thing he did & nothing changed. Performance all felt the same. Mileage didn't seem any better. Just sounded louder to me like a UPS delivery truck now. I never re-ordered all of that stuff for mine & to this day is still all 100% stock.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: V10 HP PARTS [Re: 6PKRTSE] #1491643
09/22/13 08:44 AM
09/22/13 08:44 AM
Rochester, NY
dusterdood Offline
dusterdood  Offline
Rochester, NY
I've got the stage II jet chip in the box if you want it. Only had it on the truck for a month. I liked the throttle response when I put it in, but I had to run premium. When I sold the truck off, I forgot I had it in the garage. Now I doubt I'll ever reuse it. I'll send you a PM.
Re: V10 HP PARTS [Re: dusterdood] #1491644
09/22/13 09:04 AM
09/22/13 09:04 AM
Rochester, NY
dusterdood Offline
dusterdood  Offline
Rochester, NY
Thinking about this thread, I wanted to point out that the biggest improvement I got was going to shorty headers. I bought Gibson ceramic coated stainless ones and got 10% better gas mileage (10 to 12 so big whoop. Also, throttle response without even replacing the rest of the exhaust. When I added the Jet chip I needed to run premium gas, but felt the off throttle response even more. Just my $.02 from my experience.
