Page 6 of 6 1 2 3 4 5 6
Re: R3P7 a great bargain for drag racing (long) [Re: OUTLAW565] #1490563
05/16/14 01:47 PM
05/16/14 01:47 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
.016 intake and .018 exhaust cold. This a roller cam.
With the aluminum block I run zero cold with the current cam. Not sure what it will be with the new cam.
Re: R3P7 a great bargain for drag racing (long) [Re: Leon441] #1490564
05/16/14 02:10 PM
05/16/14 02:10 PM
BPE Offline
BPE  Offline
Leon, What is the deck height on your EEI block? I see where you say it is taller than the 358 you had but didn't see what it actually is.
Rod
Re: R3P7 a great bargain for drag racing (long) [Re: Leon441] #1490565
05/16/14 07:38 PM
05/16/14 07:38 PM
Down under
O
OUTLAW565 Offline
OUTLAW565  Offline
O
Down under
Thanks mate
Re: R3P7 a great bargain for drag racing (long) [Re: Leon441] #1490566
05/16/14 08:59 PM
05/16/14 08:59 PM
Down under
O
OUTLAW565 Offline
OUTLAW565  Offline
O
Down under
Hey Leon im in need of some exhaust header gaskets. I know cometic make them but i can't find a part number or anything. Any chance you could help me out?
Re: R3P7 a great bargain for drag racing (long) [Re: OUTLAW565] #1490567
05/16/14 09:01 PM
05/16/14 09:01 PM
Lynchburg, VA
Leon441 Offline OP
Leon441  Offline OP
Lynchburg, VA
9.250. The water channel is much higher into the water jacket. This suuports the cylinders better. The 2.500 main is also a huge benefit in larger stroke cranks.
