R5P7 a great bargain for drag racing (long)
#1490463
08/25/13 05:08 PM
08/25/13 05:08 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I am posting this just as information. I bought one from a drag racer. So a lot of things had already been taken care of or simplified. These engines in 358 form only make around 575 ft lbs of torque. If the cam is big you are going to want a lot of gear and converter. My combination was a lot of gear a 6,800 converter and a powerglide trans. My car has plenty of tire and bite. It's 60 ft pretty weak. The MPH and ET not bad. 5.82@118 at 3,000 lbs in good air. A car with small tires and a torqueflite can really do well with these engines. A stick car would do very well also. There were some 3.5" cranks made for these engines outside of NASCAR. If you are lucky enough to find one with this stroke or buy a crank you have a great engine no matter what you put behind it. Putting a Dominator on these engines is great for top end power. Most like myself would benefit by leaving a 4150 carb on it. A simple change to a front drive distributor like what was done with mine allows the engine to be set back nicely. The adapter plates are expensive as advertised. The one I have is a nicer one from BOBSPROFAB but, I still made some improvements that were allowed with my JW Ultrabell. I would recommend if running an aftermarket bell to check on getting it plugged and redrilled to fit the bolt pattern of the R5. Have not been able to talk Reid into making a run of bells with the bolt pattern different than the standard small block. The material is there for the change. ATI also makes an adapter that allows one of their bells to bolt up. I would not get too caught up in the bolt pattern. The flat bottom dry sump pans do not work in stock style front suspensions without running the engine high in the car. I have a Charlies pan that works nice. If I were to do one of these engines from scratch I would buy a single stage pump and build a wet sump pan. The only changes necessary is to drill oil passages in the cam tunnel for drainage. If you are a novice racer who wants simple oil system. A drysump is not what you want. There is little about this engine that makes it a requirement. From what I see a couple plugs and a few new holes in the block and a belt driven wet sump engine is fairly simple. While changing pans if you were buying a new drysump pump you could get by with a four stage instead of the six. I have yet to see any advertisement for one of these engines that did not claim to make over 800 HP. The one I have has some very big heads and domed pistons. I have talked with many who built these engines for a living and say that there are a lot of happy dynos just like other engine's numbers. I would say 800+ is fairly common but the number 830+ I would say is suspect. All in all you buy one of these engines after getting around the oil pan and mating it with your transmission you will be happy with it. They scream and make lots of power. They are not a torque monster but neither is Mopar's 340. HP wise the R5P7 is light years ahead. You can't be bashful, you have to turn it 8K or better. I believe if the guys trying to get $950 for adapter plates would come down to earth and people realized the potential you would see these things running everywhere. I am looking to go with a taller aluminum block with 340 mains and more stroke. The block is fair priced at $7,500 ready to assemble with the latest .937 keyway bushing and everything, the Bryant crank is $3,200 and custom. A real ring package so it is cold running temperature friendly. 467CID is possible with the aluminum block. Also looking to use some other more common parts that will make something that can stand a lot of power adder. Everyone ran out and bought P7 heads and are all sitting on their hands over the XR2 blocks. EEi was having the aluminum blocks made in R5. It is a proven piece. You spend the extra $$ and get a block ready to use actually saving money if you stop and think about it. The custom crank is expensive but an extremely reputable company. For those who are still waiting on the XR2 I figure a couple thousand in extra cost tops to go the EEI route. Then you have a proven piece for racing. I have heard nothing but good things from those who have ran them. Just something to consider. A local shop has built three SB2 400+ engines. The customers love them and they were not cheap. I talked with the shop about the matter. They said the P7 had more potential. So why are the chevy guys so more willing to build engines like this?
Re: R5P7 a great bargain for drag racing (long)
[Re: Leon441]
#1490465
08/25/13 06:18 PM
08/25/13 06:18 PM
Posts: 1,019 Finland
mafo
Finland
I have tested 2 different heads on my bench, one was in the 370 cfm range and the other was right on par with my CFE w8 s, around 410 on my bench, with even better low lift numbers
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: mafo]
#1490466
08/25/13 08:58 PM
08/25/13 08:58 PM
Posts: 6,151 Melbourne , Australia
LA360
I have some parts sitting on the shelf, and am waiting for the rest to be sent over from the US. These heads have everything the Ford Yates and SB2.2 head have, but I wouldn't be surprised if the Toyota head is better again. There are plenty of raw castings out there for a full effort engine, but I doubt there is really many Mopar folks preparred to build one. Anyone serious enough usually build a P5 engine, or are still running a W8 engine with a cast 4 barrell. The adapters should be cheaper for what is in them, even at a 200% profit I don't think there is $950 in them. For a 1 off, sure. Great post and great info Leon!
Alan Jones
[Re: LA360]
#1490467
08/25/13 09:10 PM
08/25/13 09:10 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
What blocks are the sb2 dudes using?
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1490468
08/25/13 09:44 PM
08/25/13 09:44 PM
Leon441
Lynchburg, VA
About the adapters. Bob came up with the one I have. It needed a couple adjustments. The centering is spot on. The 11/16 bolt that would go in from the engine side into the tranny needs to go into through the adapter and into the Mopar tranny. This hole was drilled and threaded 3/8", I simply drilled it 11/16" and moved on. The hole on the drivers side next to the starter was the same. The block cover this hole preventing an 11/16 bolt from going through. You have to bushing the threaded hole in your bell housing to run a smaller bolt from the back side into the adapter. My Ultrabell has the bolt hole like the clutch bell housing in the 12 O'clock position. So I drilled and tapped the adapter to use this bolt. This eliminated the need to have the overlapping bolts in the 10 and 2 O'clock positions. I simply countersunk a sockethead 3/8 to bolt the adapter to the engine block. No bolts in the bell sense I have the one in the 12 O'clock hole.
I have not had a chance to compare the drawings, but I really believe an adapter to go from a B engine bellhousing to the R5 may work better. Especially sense the dowels in the adapter to the A engine take some machining so they can overlap about .050".
Leon
[Re: 1967dartgt]
#1490469
08/25/13 10:13 PM
08/25/13 10:13 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Dart for sb2....but the sb2.2 works w a stock block..And another thing 1000+ is old news,there makin a bit more now.
Alot of engine builders just either dont have the experience w the stuff .Jeremy aka Extreme engines and ten speed believe and have told me the p7 and sb2 are almost indenticle,however tenspeed believes p7 is a little better and 440ci sb @ 8500 will exceed 1000 hp NO PROBLEM.I also know the p5 will make power also but needs 9500rpm.
[Re: Leon441]
#1490470
08/25/13 10:19 PM
08/25/13 10:19 PM
Posts: 10,563 Rittman Ohio
fourgearsavoy
Rittman Ohio
A friend of mine has one of the Petty engines on the shelf and a tube chassis Shelby Charger sitting in his shop.I would think this combo would really work well with a 5 speed with a 3.20 low gear leaving at 8000 and shifting at 9500 These engines would really work in a high winding stick car with lots of gear and a big carb Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: charger410]
#1490475
08/26/13 06:37 PM
08/26/13 06:37 PM
Leon441
Lynchburg, VA
The swap to R5 in the long run will be good.
The W8 was a really strong engine, but as W8's go CFE claimed my heads were some of the best flowing he had done and for large bores a perfect combination. The oiling system extremely simple.
I dropped 60CID and lost 70HP. The P7 does not eat valve springs and the parts are plentiful. The P7 is not aggressive at all. When the power came in it was smooth. The only negative was the displacement. Get some stroke in it to make some lower RPM torque it should prove a great combo for a powerglide transmission.
I have had a little carnage. Simple a rocker arm broke. $100 to fix. Unfortunately a Ghost came in my shop and moved some stuff around. A titanium valve lock disappeared. All the Kings horses and all the Kings men looked for this missing lock and assured me the King that it was no where to be found. I looked too. Pulled the DS head and looked some more. It was no where to be found. Put Humpty Dumpty back together and set the valves. Bumped the squirters and proceeded to start the engine. Well you hear the rumble and smell the fuel you have to tap the throttle. Tapped and heard a lot of new noise. Long story short the keeper was either in the intake manifold or on top the carburetor's butterfly. It went into #5 breaking the ring land and splitting the cylinder wall. The block and piston are now junk. The head has a minor nick in the deck. Just some really bad luck. Nothing to do with being a R5P7.
Leon
[Re: Leon441]
#1490476
08/27/13 03:32 AM
08/27/13 03:32 AM
mafo
Finland
That is the perfect excuse to build one with 3.8 stroke...
[Re: Leon441]
#1490478
08/27/13 08:02 AM
08/27/13 08:02 AM
Posts: 10,037 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Leon, this does look like a great alternative to the heavy BB stuff, if built right. What kind of Hp potential do you see in a stroked version? How big can they go and what rpm do you think they would have to run to get the most out of them?
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: Leon441]
#1490479
08/27/13 10:58 AM
08/27/13 10:58 AM
Posts: 3,456 Out West
408strokerdart
Out West
Leon
Hi Leon. Did you weigh this engine combo? I bet this would be plenty light with that EEI alum block.
[Re: 408strokerdart]
#1490480
08/27/13 07:14 PM
08/27/13 07:14 PM
Leon441
Lynchburg, VA
They have the cylinder heads to make over 1,000 if you do a max effort with raw castings. The NASCAR stuff was limited to valve size and RPM. If you go to Ernie Elliot's website he says what say you can go ever 400 with a cast iron block. And I know of a 467 CID combo with the aluminum block.
My car with the low deck lightened R3W8 engine with really light internals was 2,950. With the R5P7 cast iron block, dry sump, adapter plate, and alternator the car weighed 3,000. I hope to loose 100 lbs with the aluminum block.
Leon
