Page 2 of 3 1 2 3
Re: Affordable harmonic balancers [Re: ProSport] #1488723
08/22/13 11:55 PM
08/22/13 11:55 PM
Chester, VA
tobnHisglory Offline
Chester, VA
I'm leaning towards the high strength 440Source, I don't really want to go with a fluid type damper.
Just curious - Why don't you want to run a fluid style damper?
-Reggie
tobnHisglory2000@aol.com
Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4
Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
Re: Affordable harmonic balancers [Re: tobnHisglory] #1488724
08/23/13 07:21 AM
08/23/13 07:21 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Lots of people use them with no problems, I've just heard too many bad stories over the years and I've seen too many broken motors with a Fluidampr on the front of it.
For what I'm using my motor for, I'd probably be ok with any kind of damper, just trying to weed out the bad ones such as the BHJ that was mentioned to be junk.
I do like the fact that the 440Source fluid damper is SFI certified in case I were to hit the track sometime down the road when the rearend and suspension are upgraded, way down the road.
http://store.440source.com/Fluid-damper-SFI-Certified-Chrome-New/productinfo/200-1023/
Re: Affordable harmonic balancers [Re: sixpackgut] #1488725
08/23/13 07:39 AM
08/23/13 07:39 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
mine has a CAT fluid style for 10 years now
+1
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: Affordable harmonic balancers [Re: Den300] #1488726
08/23/13 08:06 AM
08/23/13 08:06 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i used the Source Fluid Damper for a few years, thought it was good but my engine had issues with bolts coming loose all the time. an engine builder down here told me it'll be because of my fluid damper. so when money became available i bought a ATI Superdamper. surprisingly i don't have a loose nut n bolt problem anymore. also the Fluid damper was tight as hell to get on & off & yet on the crank snout under the damper i had fret marks. i had the crank polished & these marks removed. 4 seasons later when i stripped the motor for a freshen up, there were no marks under the ATI damper. i'm a firm believer in quality dampers now, nothing but ATI from now on.
Re: Affordable harmonic balancers [Re: ProSport] #1488727
08/23/13 10:53 AM
08/23/13 10:53 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
run a stock one.
Re: Affordable harmonic balancers [Re: J_BODY] #1488728
08/23/13 11:01 AM
08/23/13 11:01 AM
ohio
dbran451 Offline
dbran451  Offline
ohio
run a stock one.
I agree if this IS a street motor save the money and use a stock one
Re: Affordable harmonic balancers [Re: J_BODY] #1488729
08/23/13 02:42 PM
08/23/13 02:42 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Isn't the elastomer usually dry rotted on a stock one?
Re: Affordable harmonic balancers [Re: ProSport] #1488730
08/23/13 05:35 PM
08/23/13 05:35 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Get a Pioneer or Powerbond for what you are doing and be done with it and have some peace of mind.
RIP Monte Smith
Re: Affordable harmonic balancers [Re: CompWedgeEngines] #1488731
08/23/13 05:40 PM
08/23/13 05:40 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... Pioneer or Powerbond...
x2; The SFI-approved versions from either are both manufactured by Powerbond, IIRC.
Re: Affordable harmonic balancers [Re: BradH] #1488732
08/23/13 05:46 PM
08/23/13 05:46 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have a used Fluidampr that I'm using, probably junk.
Mopar to the bone!!!
Re: Affordable harmonic balancers [Re: 72Swinger] #1488733
08/23/13 06:00 PM
08/23/13 06:00 PM
Lehigh Acres, Florida
rickstershemi Offline
Professional Products here great bang for the buck
Rickster
Re: Affordable harmonic balancers [Re: CompWedgeEngines] #1488734
08/23/13 06:08 PM
08/23/13 06:08 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
You mean Powerforce?
Re: Affordable harmonic balancers [Re: ProSport] #1488735
08/23/13 06:43 PM
08/23/13 06:43 PM
Syracuse,NY
Syracuse,NY
No, Powerbond is a different company. Powerforce is a Proffessional Products like Rickster mentions.
RIP Monte Smith
Re: Affordable harmonic balancers [Re: ProSport] #1488736
08/23/13 06:59 PM
08/23/13 06:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Theres still some out there in great shape. The one off my old 440 is in super shape, so its keeper.
You would need to find one off of a nuetral balanced motor though, 71 and before. So that might be a tough one to find, probably easier to just buy new.
But if you found a good one, I wouldnt hesitate to use it for what your doing.
Re: Affordable harmonic balancers [Re: ProSport] #1488737
08/23/13 09:28 PM
08/23/13 09:28 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I'd be curious to what brand balancer the people use that complain about loose torque converter bolts. Always seem to be some people have trouble with flex plates and loose converter bolts.
maybe
Re: Affordable harmonic balancers [Re: CompWedgeEngines] #1488738
08/23/13 10:08 PM
08/23/13 10:08 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Ok thanks I'll look them up.
Re: Affordable harmonic balancers [Re: nss guy] #1488739
08/23/13 10:10 PM
08/23/13 10:10 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
maybe
That is a very good point Jim. I've pitted next to guys that have to retorque their converter bolts after every pass.
Re: Affordable harmonic balancers [Re: ProSport] #1488740
08/25/13 01:43 AM
08/25/13 01:43 AM
Washington
skrews Online content
skrews  Online Content
Washington
I've seen a number of Professional Products dampers fail. Pioneer gets my vote for an economical damper.
Re: Affordable harmonic balancers [Re: skrews] #1488741
08/25/13 11:53 AM
08/25/13 11:53 AM
BradH Offline
BradH  Offline
Same here. I know of a Moparts member's Professional Products that failed during dyno testing and have heard from a friend of one that was sh!t-canned by a machine shop when they found it was the source of their being unable to get a particular rotating assembly to balance properly.
Re: Affordable harmonic balancers [Re: BradH] #1488742
08/25/13 02:00 PM
08/25/13 02:00 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Ok so I'm gonna pass on Professional Products and KMJ. I think I'm gonna go with the $90 440source with the high strength steel and enclosed elastomer.
Page 2 of 3 1 2 3
