Re: Affordable harmonic balancers
[Re: ProSport]
#1488723
08/22/13 11:55 PM
08/22/13 11:55 PM
Posts: 198 Chester, VA
tobnHisglory
Chester, VA
I'm leaning towards the high strength 440Source, I don't really want to go with a fluid type damper.
Just curious - Why don't you want to run a fluid style damper?
-Reggie tobnHisglory2000@aol.com Former Mopars: 73 Charger - 440/727, 68 D200 Camper Special 383/727, 67 Satellite, 71 Superbee, 73 RoadRunner,2009 Ram Quad Cab Hemi 4x4 Current Mopars: 2005 Ram Quad Cab Hemi 4x4, 73 Cuda FE5 318 manual
[Re: tobnHisglory]
#1488724
08/23/13 07:21 AM
08/23/13 07:21 AM
Posts: 17,928 Akron, Ohio
ProSport
Akron, Ohio
Lots of people use them with no problems, I've just heard too many bad stories over the years and I've seen too many broken motors with a Fluidampr on the front of it. For what I'm using my motor for, I'd probably be ok with any kind of damper, just trying to weed out the bad ones such as the BHJ that was mentioned to be junk.
I do like the fact that the 440Source fluid damper is SFI certified in case I were to hit the track sometime down the road when the rearend and suspension are upgraded, way down the road.
http://store.440source.com/Fluid-damper-SFI-Certified-Chrome-New/productinfo/200-1023/
[Re: ProSport]
#1488727
08/23/13 10:53 AM
08/23/13 10:53 AM
Posts: 13,227 aZLiViN
J_BODY
aZLiViN
[Re: J_BODY]
#1488728
08/23/13 11:01 AM
08/23/13 11:01 AM
Posts: 654 ohio
dbran451
ohio
run a stock one.
I agree if this IS a street motor save the money and use a stock one
[Re: ProSport]
#1488730
08/23/13 05:35 PM
08/23/13 05:35 PM
Posts: 3,547 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Get a Pioneer or Powerbond for what you are doing and be done with it and have some peace of mind.
RIP Monte Smith
[Re: BradH]
#1488732
08/23/13 05:46 PM
08/23/13 05:46 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I have a used Fluidampr that I'm using, probably junk.
Mopar to the bone!!!
[Re: CompWedgeEngines]
#1488734
08/23/13 06:08 PM
08/23/13 06:08 PM
ProSport
Akron, Ohio
You mean Powerforce?
[Re: ProSport]
#1488735
08/23/13 06:43 PM
08/23/13 06:43 PM
CompWedgeEngines
Syracuse,NY
No, Powerbond is a different company. Powerforce is a Proffessional Products like Rickster mentions.
RIP Monte Smith
#1488738
08/23/13 10:08 PM
08/23/13 10:08 PM
ProSport
Akron, Ohio
Ok thanks I'll look them up.
[Re: nss guy]
#1488739
08/23/13 10:10 PM
08/23/13 10:10 PM
ProSport
Akron, Ohio
I'd be curious to what brand balancer the people use that complain about loose torque converter bolts. Always seem to be some people have trouble with flex plates and loose converter bolts. maybe
That is a very good point Jim. I've pitted next to guys that have to retorque their converter bolts after every pass.
[Re: ProSport]
#1488740
08/25/13 01:43 AM
08/25/13 01:43 AM
Posts: 430 Washington
skrews
Washington
I've seen a number of Professional Products dampers fail. Pioneer gets my vote for an economical damper.
[Re: skrews]
#1488741
08/25/13 11:53 AM
08/25/13 11:53 AM
BradH
Same here. I know of a Moparts member's Professional Products that failed during dyno testing and have heard from a friend of one that was sh!t-canned by a machine shop when they found it was the source of their being unable to get a particular rotating assembly to balance properly.
[Re: BradH]
#1488742
08/25/13 02:00 PM
08/25/13 02:00 PM
ProSport
Akron, Ohio
Ok so I'm gonna pass on Professional Products and KMJ. I think I'm gonna go with the $90 440source with the high strength steel and enclosed elastomer.
