Re: brake pedal height help [Re: 71birdJ68] #1488313
08/22/13 06:25 PM
08/22/13 06:25 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
I don't recall any of my 4 spd cars having that much offset between the brake and clutch,
I looks a bit excessive to me
Re: brake pedal height help [Re: TJP] #1488314
08/22/13 07:42 PM
08/22/13 07:42 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
It didn't matter if it was a 4 speed or auto. If it had power brakes the peddle was close to the floor compared to manual. And it matter what brand it was either.Mopar, GM, Ford.
Re: brake pedal height help [Re: 71birdJ68] #1488315
08/22/13 11:39 PM
08/22/13 11:39 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Politely Disagree, A little offset, MAYBE!!! That much as shown in the pic is too much IMO. BTW I do restorations for a living (GM, Ford, Mopars etc )and one of my pet peeve's is just this subject. Along with several others.
IMO Either the clutch pedal is too high or the brake pedal is too low. The car would not leave my shop that way,
Re: brake pedal height help [Re: TJP] #1488316
08/23/13 01:20 AM
08/23/13 01:20 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Ok, now this is out of a 71 service manual, but it should have been the same for most all years, it talks about power assisted application of the cars brakes,I quote " This provides lighter pedal effort in combination with reduced pedal travel, bringing the brake pedal height down to the approximate height of the accelerator when at closed throttle conditions." Now you could be right about clutch pedal. Who knows what parts are in that car now.Wrong clutch rod? That brake rod could be wrong,he needs to check everything against part numbers, but the point is, power brake pedals are supposed to be close to the same as the gas pedal. I don't remember if that rod is adjustable or not, if it is it would give a little movement on the pedal.If his brake light switch will adjust out, then he is ok.
Re: brake pedal height help [Re: yellow70charger] #1488317
08/23/13 01:31 PM
08/23/13 01:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's a pic of my old RR and the pedal height that seems typical of those I've seen.
Re: brake pedal height help [Re: John_Kunkel] #1488318
08/23/13 02:21 PM
08/23/13 02:21 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
If it helps you any, a picture of the pedals, in the 71 Hemi GTX 4 speed car that i used to own.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: brake pedal height help [Re: 71birdJ68] #1488319
08/23/13 03:24 PM
08/23/13 03:24 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Could be the angle of the picture as well IE: #3
