Finally IT happened......Monte told me so LOL
#148589
11/10/08 08:33 PM
11/10/08 08:33 PM
Posts: 4,701 On the parachute mount
n20mstr
Well after 193 passes, of which 148 were with nitrous....Running it too fat finally caught up to me...I have leaned it out to the tune of picking up almost 6 mph, and its still a little fat! After running a nice and too fast pass of 8.43 @ 160. (for 8.50 index)I rolled up my chute, put it in the car, purged my line. When i started the car to drive back, i noticed a lot of smoke out the header, Well when i got back i pulled the plugs, sure enough #8 was oiled pretty heavily, but the strap was still there!!! LOL Im sure upon inspection its gonna have a lifted ring... Its served me well, cant complain at all, a shelf piston and moly ring thats seen WAY more nitrous than it was intended to. New parts were already on order before this even happened so
....BAD A$$ STREET CAR.....
Re: Finally IT happened......Monte told me so LOL
[Re: n20mstr]
#148591
11/10/08 08:39 PM
11/10/08 08:39 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Well, if it lasted that much longer than you expected it to I guess you can't really complain.
I just hope it didn't take anything else with it.
[Re: n20mstr]
#148597
11/10/08 09:32 PM
11/10/08 09:32 PM
Posts: 2,611 Elbridge, NY
Dart1031
Elbridge, NY
we had to go over the scales yesterday, it was 3515lbs
What block did you use for the 499?
[Re: ProSport]
#148601
11/10/08 09:52 PM
11/10/08 09:52 PM
Posts: 684 toronto
6PAK70CUDA
toronto
-with Dash 1's and a small roller!
[Re: 70Dustmite440]
#148607
11/11/08 07:23 AM
11/11/08 07:23 AM
Posts: 10,049 MN
JERICOGTX
MN
Still using the column shifter???
Jeff
69 GTX
68 Road Runner
[Re: n20mstr]
#148608
11/11/08 11:19 AM
11/11/08 11:19 AM
Posts: 13,415 Marion, South Carolina [><]
an8sec70cuda
Sorry to hear you hurt it, good luck getting it back together! That thing sure runs good! CHIP
[Re: n20mstr]
#148611
11/11/08 06:31 PM
11/11/08 06:31 PM
That car needs its own class: Scary Stock!
[Re: n20mstr]
#148612
11/11/08 07:43 PM
11/11/08 07:43 PM
Posts: 541 South Carolina
a408swinger
mopar addict
mopar addict
South Carolina
Cool! (well not the damage..) What does it run on the motor, and how much jooos?
last time i ran it on motor it had 4.10 gears, it went 9.85 At 134. Now it has 3.70 gears, i have never run it on motor with the 3.70's
how much nitrous??? well .070 jet in a plate, and .032 in a fogger, jet area adds up to .114 so about 375-400 hp
Did you have the fogger square jetted? How about the plate? I was running a 87n/91f combo in my plate and a 24/24 jet combo in the fogger in a 408" indy headed smallblock. car ran a best of 6.19 @ 111.5 on motor and a 5.50 @ 126 on just the plate. I hit the second kit (fogger) after it spun the tires one time and it went 132mph but still only went a 5.50 because of the bad 60'. Last time at the track I hit the second kit and burned a ground strap on #4 and melted some of the piston too. I was told it was too rich but it appears that to me that it was too lean. Im almost afraid to try to lean it out after burning a piston but Im being told that too fat is what caused the damage. I was running 16* total timing and was told that was too much as well. It needed to be at 12*.
[Re: a408swinger]
#148613
11/11/08 09:56 PM
11/11/08 09:56 PM
n20mstr
i am leary to post my tune up, because as someone told me, they read your post and then burn [Edited by Moparts - Keep it clean] up and blame it on you....LOL
You havene listed any fuel psi with your jetting, i was 5.2 on the plate, and 5.2 on the fogger, fogger was 32n 28f, now you see me, i made 140++ passes, not all with that jetting, but all were with nitrous, Obviously your motor didnt like something, most likely it was timing, like i have been told, it takes a lot to lean the fuel out and hurt it. My problem i think is too fat, (only recently have i leaned it out a lot) and combination of parts that were never intended to see 300+ nitrous oxide ( Moly rings, and a Shelf piston) If you use nitrous, and you want to go fast, you have to expect some carnage, its all part of the learning curve.
All that being said, what fuel psi did you have in your kits?? What fuel were you using??
[Re: n20mstr]
#148614
11/11/08 11:39 PM
11/11/08 11:39 PM
Posts: 633 NY/NJ
DV8
mopar addict
mopar addict
NY/NJ
...so you gonna go gangsta for that 636" B1 & 3 stages now huh?...
~S~
"The function of man is to live, not exist..."
[Re: DV8]
#148615
01/02/09 07:35 PM
01/02/09 07:35 PM
n20mstr
Well upon disassmbly, all i can see is the second ring is pinched on the #8 piston. I measured the top alomst all the way around and the deck ht was still the same, it hasnt lifted the top of the piston at all. But the second ring is TIGHT actually it doesnt move at all LOL LOL. Other than that, the rest of the pistons all look good..
[Re: moparniac]
#148621
01/02/09 10:01 PM
01/02/09 10:01 PM
n20mstr
i didnt ask him to come to me, i said to meet half way for each of us ....AT A MOPAR RACE...Ohio, Rockingham, Etc..... read it for yourself..http://www.yellowbullet.com/forum/showthread.php?t=83493&highlight=1fastmopar
[Re: B1Fish540]
#148623
01/03/09 03:37 AM
01/03/09 03:37 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I am definitely not defending Eddie here. As most know, I think he runs his mouth too much, is full of hot air and I give him grief often...however...when YOU call a man out and then HE won't come 1,000 miles to race you in your backyard, there is not really a whole lot you can say. Eddie lives in south Florida. He has to drive 400 miles, just to get out of his home state. I am a little out of the way, but Englishtown is 1150 miles for me and Moroso is nearly 900 miles from me. So somehwere around the Tennessee area is halfway for Eddie, not Ohio. That would kinda be like Al Alguire calling me out and them claiming I was afraid, because I would not drive to Phoenix to race him. If you are doing the calling out, you should be willing to travel to prove your point. At least that is how I see it.
Monte
[Re: n20mstr]
#148624
01/03/09 03:38 AM
01/03/09 03:38 AM
Posts: 452 Monrovia, So-Cal, USA
racerhog
Fix the ring land and put a new ring on it and throw it back in for somemore good runs...... They run best just before....Well you know....
Bob(Cowboy)Hogan Monrovia So-Cal
[Re: Monte_Smith]
#148625
01/03/09 03:44 AM
01/03/09 03:44 AM
Posts: 6,295 U.S.
moparniac
U.S.
Monte
me too ...
Mopar Performance
[Re: hemi_al588]
#148629
01/03/09 10:40 AM
01/03/09 10:40 AM
Posts: 860 Fort Pierce, FL
Outlaw10_5
Fort Pierce, FL
You might as well not run him, cause if you outrun him you still won't win.
They'll be some nutswinger talking about how it's a streetcar, even tho it broke down every 50 miles or so. How easy it is to forget that when it made it trouble free, it had a different combo.
We outran him with the Dakota. A truck, on a leafspring, a radial, no wheelie bars, a smaller motor with less head, less nitrous, and outweighed him by 400lbs and there were STILL excuses. We have let off the gas, out of gear, and still been faster and quicker than his BEST pass. Yet he is everyone's hero. 7.90's with that combo - for shame.
So, if you race him, be prepared...
"He's on pump gas" - no, he won't be, and NEVER is when it's at the track. "It's a street car" - if my daily driver broke down that often I'd sell it and get something more reliable. Hell never mind Drag Week, it broke down last time out in Daytona. "Your car is purpose built" - Like a dyno tuned 600" Predator headed 4 link car on a big tire is run of the mill. "Blah blah blah" - Followed by some other lame excuse.
I'll keep you guys posted on the top secret race with him and a small block/small tire/stock suspension Malibu coming up...
I'm betting on the 'Bu.
[Re: Monte_Smith]
#148630
01/03/09 12:53 PM
01/03/09 12:53 PM
n20mstr
Monte
I never said Eddie was afraid. He wanted me to go to Orlando, cmon is that halfway??? I never wanted him to come to Englishtown, thats only 90 miles for me.
The only reason i called him out was because at some events people come up to me and tell me that i should race him because they are tired of hearing him talk about how fast his car is when in reality it has all the equipment to run in the 6's when its barely in the 7's. I think Eddie is a very good engine builder. But honestly Monte, if you didnt lay your hands on the car it still would be a 8 sec car . Hes got way better car than me, i have NO business being in the next lane.....BUT if the chance presents itself, and i feel im ready, i will go for it. Other than that, i give Eddie the respect and props he deserves.
