Re: Finally IT happened......Monte told me so LOL
[Re: n20mstr]
#148611
11/11/08 06:31 PM
11/11/08 06:31 PM
That car needs its own class: Scary Stock!
[Re: n20mstr]
#148612
11/11/08 07:43 PM
11/11/08 07:43 PM
Posts: 541 South Carolina
a408swinger
mopar addict
mopar addict
South Carolina
Cool! (well not the damage..) What does it run on the motor, and how much jooos?
last time i ran it on motor it had 4.10 gears, it went 9.85 At 134. Now it has 3.70 gears, i have never run it on motor with the 3.70's
how much nitrous??? well .070 jet in a plate, and .032 in a fogger, jet area adds up to .114 so about 375-400 hp
we had to go over the scales yesterday, it was 3515lbs
Did you have the fogger square jetted? How about the plate? I was running a 87n/91f combo in my plate and a 24/24 jet combo in the fogger in a 408" indy headed smallblock. car ran a best of 6.19 @ 111.5 on motor and a 5.50 @ 126 on just the plate. I hit the second kit (fogger) after it spun the tires one time and it went 132mph but still only went a 5.50 because of the bad 60'. Last time at the track I hit the second kit and burned a ground strap on #4 and melted some of the piston too. I was told it was too rich but it appears that to me that it was too lean. Im almost afraid to try to lean it out after burning a piston but Im being told that too fat is what caused the damage. I was running 16* total timing and was told that was too much as well. It needed to be at 12*.
[Re: a408swinger]
#148613
11/11/08 09:56 PM
11/11/08 09:56 PM
Posts: 4,701 On the parachute mount
n20mstr
i am leary to post my tune up, because as someone told me, they read your post and then burn [Edited by Moparts - Keep it clean] up and blame it on you....LOL
You havene listed any fuel psi with your jetting, i was 5.2 on the plate, and 5.2 on the fogger, fogger was 32n 28f, now you see me, i made 140++ passes, not all with that jetting, but all were with nitrous, Obviously your motor didnt like something, most likely it was timing, like i have been told, it takes a lot to lean the fuel out and hurt it. My problem i think is too fat, (only recently have i leaned it out a lot) and combination of parts that were never intended to see 300+ nitrous oxide ( Moly rings, and a Shelf piston) If you use nitrous, and you want to go fast, you have to expect some carnage, its all part of the learning curve.
All that being said, what fuel psi did you have in your kits?? What fuel were you using??
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#148614
11/11/08 11:39 PM
11/11/08 11:39 PM
Posts: 633 NY/NJ
DV8
mopar addict
mopar addict
NY/NJ
...so you gonna go gangsta for that 636" B1 & 3 stages now huh?...
~S~
"The function of man is to live, not exist..."
[Re: DV8]
#148615
01/02/09 07:35 PM
01/02/09 07:35 PM
n20mstr
Well upon disassmbly, all i can see is the second ring is pinched on the #8 piston. I measured the top alomst all the way around and the deck ht was still the same, it hasnt lifted the top of the piston at all. But the second ring is TIGHT actually it doesnt move at all LOL LOL. Other than that, the rest of the pistons all look good..
[Re: moparniac]
#148621
01/02/09 10:01 PM
01/02/09 10:01 PM
n20mstr
i didnt ask him to come to me, i said to meet half way for each of us ....AT A MOPAR RACE...Ohio, Rockingham, Etc..... read it for yourself..http://www.yellowbullet.com/forum/showthread.php?t=83493&highlight=1fastmopar
[Re: B1Fish540]
#148623
01/03/09 03:37 AM
01/03/09 03:37 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
I am definitely not defending Eddie here. As most know, I think he runs his mouth too much, is full of hot air and I give him grief often...however...when YOU call a man out and then HE won't come 1,000 miles to race you in your backyard, there is not really a whole lot you can say. Eddie lives in south Florida. He has to drive 400 miles, just to get out of his home state. I am a little out of the way, but Englishtown is 1150 miles for me and Moroso is nearly 900 miles from me. So somehwere around the Tennessee area is halfway for Eddie, not Ohio. That would kinda be like Al Alguire calling me out and them claiming I was afraid, because I would not drive to Phoenix to race him. If you are doing the calling out, you should be willing to travel to prove your point. At least that is how I see it.
Monte
[Re: n20mstr]
#148624
01/03/09 03:38 AM
01/03/09 03:38 AM
Posts: 452 Monrovia, So-Cal, USA
racerhog
Fix the ring land and put a new ring on it and throw it back in for somemore good runs...... They run best just before....Well you know....
Bob(Cowboy)Hogan Monrovia So-Cal
[Re: Monte_Smith]
#148625
01/03/09 03:44 AM
01/03/09 03:44 AM
Posts: 6,295 U.S.
moparniac
U.S.
Monte
me too ...
Mopar Performance
