Re: 230 - 260 leaf springs and 1.26" torsion bars
[Re: jcc]
#1485560
08/18/14 05:13 AM
08/18/14 05:13 AM
Posts: 208 Munich, Bavaria
docford
Munich, Bavaria
I assume what I am asking about is just a video or mounting visual distortion artifact, but does it look like the trans tunnel area/rear TB mounting crossmember flops around a lot based on bumps and/or cornering? Nothing else inside the car seems to move much, relative to camera, but this area. If so wow, if not nevermind.
yes, it is an optical distortion due to the camera moving under braking and acceleration. If you look closely, you'll see the top bar of the rollcage move the same. You got sharp eyes, though
[Re: AlexP]
#1485563
08/22/14 10:23 AM
08/22/14 10:23 AM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
Why are you selling it? Dang just when its fast!!!Building another?
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: HUSTLESTUFF]
#1485565
08/30/14 05:27 AM
08/30/14 05:27 AM
docford
Munich, Bavaria
Well, all good things come to an end. I had to make a choice between the Charger and the Cuda, due to $$$ reason
[Re: docford]
#1485567
09/01/14 12:23 AM
09/01/14 12:23 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Thanks to a fellow enthousiast, I got the original broadcast sheet of the car. It rolled off the Hamtrack assembly line as a 383-4 barrel 4 speed Barracuda. Is there a way to tell the torsion bar size and spring rate that is came with originally ?
Probably Yes. The first entries on line five are the codes for the t-bar, followed by the rear springs. Somewhere, someone like Barry Washington knows how these numbers relate to part numbers. Try cross posting under "restoration". - Matt
