Re: 230 - 260 leaf springs and 1.26" torsion bars
[Re: Mopar Mitch]
#1485540
09/08/13 07:03 AM
09/08/13 07:03 AM
Posts: 208 Munich, Bavaria
docford
Munich, Bavaria
One additional concern should be, if the front spring eye location is changed up/down then to use angle shims at the leaf/differential to re-adjust the drive shaft / pinion angle.
Good point! What pinion angle would you dial in on a roadracing HEMI car ?
We used -4° in drag racing, but that might be a lot for the road circuit
[Re: docford]
#1485541
09/09/13 10:56 AM
09/09/13 10:56 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Docford -- I'm uncertain what to advise for the pinion angle for the car you describe. I believe the Mopar Performance Chassis book, etc, advise how to do this.... you'll probably need an angle gage. (I had a racer-pro (Jim McKamey) do mine as I was also having the entire suspension balanced... back in the mid-80s.)
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: docford]
#1485544
11/25/13 03:36 PM
11/25/13 03:36 PM
Posts: 813 Ontario,Canada
brads70
Ontario,Canada
Torsion bars and leaf spring came in this week. They were custom made by FirmFeel
Post up some pictures please!
[Re: docford]
#1485545
11/25/13 06:59 PM
11/25/13 06:59 PM
Mopar Mitch
What were the final specs on the TBs and leafs? This is for a hemi-Cuda? Which body.. E or A? Which gen-Hemi?
Mopar Mitch
[Re: autoxcuda]
#1485548
12/23/13 03:42 AM
12/23/13 03:42 AM
Mopar Mitch
On my T/A, I run the 1.24 TBs and 225 pound/inch with 5" free arch rear leafs (fiberglass mono-leafs from FlexaForm)... compressed to about 1.5" remaining arch,... and have 1.25" solid fron sway bar, 1.0" solid rear sway bar, Red re-valved Konis front/rear... car handles great, very neutral; weight is ~3150 w/o driver and with ~1/8 tank of gas (52% front, 48% rear)... this data is when the car is setup for national SCCA E/SP competition. even on the hi-speed road courses it handles great.. still relatively neutral.
I think the weight% with the 426 Hemi up front is going to be greater than what is indicated...??? I'd use a 1.0" rear sway bar to help offset the front weight.
Mopar Mitch
[Re: TC@HP2]
#1485550
12/23/13 05:52 PM
12/23/13 05:52 PM
Mopar Mitch
Best bet would be removing weight from the car.. that 426 hemi is very heavy. It'd be interesting to see the actual weigh scale results, each respective corner.
Mopar Mitch
[Re: docford]
#1485553
08/17/14 10:35 AM
08/17/14 10:35 AM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Very nice!
It begs the question of what time could it turn on a dry track with more cooperative traffic?
[Re: RylisPro]
#1485555
08/17/14 03:02 PM
08/17/14 03:02 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I've really been kicking around the splined front swaybar idea. Basing it from my existing Hotchkis mounts, it really would'nt be to much of a stretch.
Mopar to the bone!!!
[Re: 72Swinger]
#1485556
08/17/14 07:22 PM
08/17/14 07:22 PM
Posts: 22,698 Bitopia
jcc
Bitopia
I assume what I am asking about is just a video or mounting visual distortion artifact, but does it look like the trans tunnel area/rear TB mounting crossmember flops around a lot based on bumps and/or cornering? Nothing else inside the car seems to move much, relative to camera, but this area. If so wow, if not nevermind.
[Re: RylisPro]
#1485558
08/18/14 04:57 AM
08/18/14 04:57 AM
docford
Munich, Bavaria
That car is awesome! Man you got big balls running hard in the rain! Nice save too! Last time I was in the wet my car spun and had a fender bender.
Your car moves pretty good despite the weight. The leafs and t-bars must be heavy but really make a difference!
Thanks yes , the Cuda now is really fun to drive and one could even let his mom cruise it on the street
