trans cooler #1481885
08/09/13 12:12 AM
08/09/13 12:12 AM
minnesota
P
president61 Offline OP
P
minnesota
pulled this power steering pump cooler off a lincoln. would it be sufficient to cool a O500 trans in a dart? its 11" long and 4" wide. thanks
Re: trans cooler [Re: president61] #1481886
08/09/13 12:36 AM
08/09/13 12:36 AM
Maybe. That's more cooler area than what is in the OE cooler in the bottom of the rad lower tank but I'd want a larger one/the largest one that would fit in the area you have to work with & they're pretty cheap. as you know heat is the #1 factor for an auto trans' demise
