Anyone running a "533" BB Mopar Purple shaft ? #1481583
08/08/13 04:38 PM
08/08/13 04:38 PM
Minnesota, USA
minnesota guy Offline OP
Minnesota, USA
Looking for outcomes of those running a Mopar 533 purple shaft hydraulic cam in a 440. What kind of combo and times as a result.
Thanks. I picked one up for cost of lifters and wonder if worth installing. Might be a hard one to keep idling.
Re: Anyone running a "533" BB Mopar Purple shaft ? [Re: minnesota guy] #1481584
08/08/13 04:54 PM
08/08/13 04:54 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Its probally better than a "509" for driveability...
I am truckless..
Re: Anyone running a "533" BB Mopar Purple shaft ? [Re: 340SHORTY] #1481585
08/08/13 05:51 PM
08/08/13 05:51 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Whats the duration on the .533? It's pretty radical from what I remember. Good for a stroker, maybe.
Re: Anyone running a "533" BB Mopar Purple shaft ? [Re: bobby66] #1481586
08/08/13 06:31 PM
08/08/13 06:31 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
270 @ .050
Tony
70 AARCuda Vitamin C
Re: Anyone running a "533" BB Mopar Purple shaft ? [Re: bobby66] #1481587
08/08/13 06:34 PM
08/08/13 06:34 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I thought it was the same as the 509 just with more lift???? You're going to need good heads, headers, 3800 stall and 3.91's or better to get it up into the "power band"
Coming soon!!!!
Re: Anyone running a "533" BB Mopar Purple shaft ? [Re: Mr.Yuck] #1481588
08/08/13 06:39 PM
08/08/13 06:39 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
Re: Anyone running a "533" BB Mopar Purple shaft ? [Re: minnesota guy] #1481589
08/08/13 07:51 PM
08/08/13 07:51 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Tons of duration and overlap with not much lift. I wouldnt use it in any combo. It will require about a 4800 to 5000 stall vert to get decent times out of it.
Re: Anyone running a "533" BB Mopar Purple shaft ? [Re: Sport440] #1481590
08/09/13 02:10 PM
08/09/13 02:10 PM
Minnesota, USA
Minnesota, USA
I am currently running a Racer Brown STH-42. 254@ .050..and .520 lift. 300 duration...Hydraulic.......Pulling 11.60's with stock rockers, 9.5 Dynamic converter...in 71 Cuda...850 holley, 6 pack anchor pistons, and SD intake..3 inch exhuast....Ported my own heads to 260-270 flow on 906's..(intake flow) 430 gear........Wondering if 533 is worth a test....
Re: Anyone running a "533" BB Mopar Purple shaft ? [Re: minnesota guy] #1481591
08/09/13 10:27 PM
08/09/13 10:27 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Scott has a nice solid grind 548ish if I recall that will work great with what you have, probably get you way into the 11's
Coming soon!!!!
Re: Anyone running a "533" BB Mopar Purple shaft ? [Re: minnesota guy] #1481592
08/09/13 10:39 PM
08/09/13 10:39 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I wouldnt bother, I know you do have it, and if you like testing stuff whether its good or bad , then go ahead. I think its going to slow you down.
You have your combo running pretty good as it is. I like to test things that I think will make it faster.
With your Dynamic 4000 or so vert ????, that 272 duration will hurt your 60 ft. and it probably wont recover at the stripe, even though it could MPH a little better.
If your into testing , have at it.
You did leave out some important variables, like compression, tire diameter, cars weight, actual vert stall,and header primary tube diameter.
Those are all important Combo factors as well, along with the other known info you posted. So I or anybodys info is just a assumption at this point. Even with all the combos info, they will be , just Better assumptions.
Re: Anyone running a "533" BB Mopar Purple shaft ? [Re: minnesota guy] #1481593
08/09/13 10:43 PM
08/09/13 10:43 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I ran one for a few years on my iron head +.060. 440 six pac pistons 0 deck heads were hand ported pretty good 2.14/1.81 and milled about .070 for about 11.5 to 1 team G intake 2" hooker headers 4.1 gears 800 holly SMR 727 with 4000 SMR converter.
Adjustable pushrods for setting preload to .020. (stock rockers)
Car was about 4000 or more with me in at at the time consistant 12.0's and in good air a best of 11.84.
had the cam in at 106 later put in friends car much the same little less compression at 102 it really liked that.
Think it would benefit from 1.6 rokers
Re: Anyone running a "533" BB Mopar Purple shaft ? [Re: minnesota guy] #1481594
08/09/13 11:06 PM
08/09/13 11:06 PM
Central NC
gch Offline
gch  Offline
Central NC
I think some 1.6 roller rockers would be a better move.
Re: Anyone running a "533" BB Mopar Purple shaft ? [Re: gch] #1481595
08/10/13 07:54 AM
08/10/13 07:54 AM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
Can you still find one? I thought they where discontinued. If you find one and run it, post how it's working out for you. I think that cam was ground for stockish heads that don't flow any thing above .500 lift anyway.
