Re: Do torsion bars wear out after time?
[Re: 70satelliteguy]
#1481559
08/08/13 05:51 PM
08/08/13 05:51 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I would think on a Drag car the weaker the better!Was that not the reason we used to replace the torsion bars off all the V8 B body cars with the torsion bars of the 6 cylinder cars,weaker bars?
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: AndyF]
#1481560
08/08/13 09:24 PM
08/08/13 09:24 PM
Posts: 22,837 Bitopia
jcc
Bitopia
Springs only wear out if they are overstressed. If you stay below the fatigue life on spring steel then the life is infinite.
Having said that, drag bars can be overstressed in a 3600 lb car, especially if you have a lot of front end travel. So yeah, I'd replace them every 5 years or so if it was my car.
Since on Mopars, they are inherently limited by design, as to how far they can be maximum loaded/twisted, the difference that matters here is how much preload/twist is dialed in for static ride height, and then adding maximum travel thru bumps/wheelstands, etc, which then approaches the over stressed area. I am surprised there is not a value published/known for maximum degrees of twist allowed for each bar. And I always heard as a rough idea loading typical steel to approx 70% tensile strength gives about 6-10,000,000 cycles of useful life. As you start approaching 100% it starts dropping faster, just to put a number on "infinite". ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 383man]
#1481562
08/08/13 11:29 PM
08/08/13 11:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
All I can say is I have owned 60's and 70's Mopars since 1974 and I have never broken or wore out a torsion bar. I have heard of some people having one break but I have not seen this. In fact the bars in my 63 are still the original stock 383 torsion bars. Ron
Are you running stock bars... stock bars will last for damn near ever if your not pulling wheelies or run on bad roads... when you jounce them more than the normal they start to sag.... I worked on the F-body transvers suspension project and even during the preload I had 4 or 5 bars blow.. when they did blow(they were under a shield) it was like a bomb going off.. and sent a razor sharp chunk flying but was contained in my fixture.. when ever it did blow.. most of the building came to see what happened ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1481563
08/08/13 11:51 PM
08/08/13 11:51 PM
Posts: 903 Saskatchewan, Canada
cudabin
The drivers front torsion bar in my (heavy) 440 six pack Super Bee is sagging as it is cranked all the way up while the passenger side adjusting bolt is only half way in...
Original .920 bars.
I am ordering 2 new ones.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: 383man]
#1481564
08/09/13 12:01 AM
08/09/13 12:01 AM
Posts: 21,092 Niles , Ohio
therocks
Niles , Ohio
Ron I started running Mopars in 65.I only had one bar snap/It was my 67 Plymouth Fury.Parked it and came out the next day to go to work.The one side was snapped.My old man started driving them in the 50s.Thats the only one Ive ever seen snapped.I had one of the trans verse one at the shop that snapped.That was at least 30 years ago.Rocky
Chrysler Firepower
[Re: therocks]
#1481565
08/09/13 09:35 AM
08/09/13 09:35 AM
Posts: 17,939 S.E. Michigan
ZIPPY
S.E. Michigan
The only vehicle I had that broke a torsion bar was my '78 B body. I feel the reason it broke is because the ends of that bar were rusted into the sockets but maybe I am off base. I had just ran an errand, got out of the car and BLAM! Like a gun going off. Instant low rider, but only on one side
Rich H.
Esse Quam Videri
[Re: MR_P_BODY]
#1481570
08/09/13 02:00 PM
08/09/13 02:00 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
[Re: therocks]
#1481571
08/09/13 02:07 PM
08/09/13 02:07 PM
383man
Balt. Md
I guess I have been lucky so far. I wondered how the bars would act if put in on the wrong side since they would twist the oppisite way ? Now watch my luck I will have a bar break this week on me. Ron
[Re: 383man]
#1481574
08/09/13 04:52 PM
08/09/13 04:52 PM
Posts: 19,411 Las Vegas
Al_Alguire
Las Vegas
My old Duster had a torsion bar "wear out". Found it after unloading it at the MATS a number of years ago. Had to use a floor jack to get it out of the trailer and went to the swap area to buy replacements. Curiously enough it had the race/6 torsion bars in it, only replacements I could find were 340 bars and car made its quickest runs ever in Vegas that weekend.
