Re: Lowest gears for 8 3/4?
[Re: Kelob_pie]
#148133
11/10/08 11:10 AM
11/10/08 11:10 AM
RapidRobert
either 2.76 or 2.45 I forget which but probably 2.76 & 5.57 on the other end
[Re: RapidRobert]
#148134
11/10/08 12:39 PM
11/10/08 12:39 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Numericaly high are low gears, and vice versa. I think I've seen as low as 5.57, never really looked hard tho. High gear would be 2.76s, I've never seen higher than that if they exist.
[Re: moper]
#148135
11/10/08 03:52 PM
11/10/08 03:52 PM
Posts: 15,487 Florida
scratchnfotraction
I had a 7 1/4 rear axle with 4" wbp,open dff,in a 170 cu in - /6 68 Dart with stock 13" rims with a 1.76 gear only ones I ever seen ![](/ubbthreads/images/graemlins/scope.gif) dint last long with the 318 though!shure would fly on the open road too,just didnt stop with 9" drums all the way around try dr diff or randy r&p ![](/ubbthreads/images/graemlins/beer.gif)
[Re: scratchnfotraction]
#148136
11/10/08 08:29 PM
11/10/08 08:29 PM
Posts: 8,859 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
i have a 8 3/4 with a set of 6.14,s lowest iv ever found
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#148137
11/10/08 08:58 PM
11/10/08 08:58 PM
RapidRobert
I thought 5.57's were the lowest! What make are these? any pics possible. More details please. I needed a lower set for my circle burner & 5.57 was all I could locate. I ended up using a 9" furd with 6.20's
[Re: moper]
#148139
11/10/08 10:45 PM
11/10/08 10:45 PM
Posts: 30,537 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
No, NO .... ...on ALL counts ! ![](/ubbthreads/images/graemlins/laugh2.gif)
A LOW gear ...is a SHORT gear. A high gear is tall, steep and BIGGER. And the steepest gear ever offered for the 8 3/4 was a 6.17. And the SHORTEST would be either a 2.41 or 2.45.
NEVER seen one of those though.
[Re: dOc !]
#148141
11/11/08 02:09 AM
11/11/08 02:09 AM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
I think you've got it backwards there.
[Re: Kelob_pie]
#148142
11/11/08 03:53 AM
11/11/08 03:53 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
i think the 2.42 oder 2.45 or 2.4x what ever came in the diplomat or cordoba!?
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
[Re: mopowers]
#148144
11/11/08 08:45 AM
11/11/08 08:45 AM
i know he does.
A low gear is a steep gear is a high number (like 4.11's)
a high gear is a tall gear is a low number (like 2.76)
#148145
11/11/08 01:28 PM
11/11/08 01:28 PM
dOc !
Florida STAYcation
i know he does.
Low equals HIGH ?
And HIGH equals LOW ??
I do KNOW that you two are HIGH on something !! ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: dOc !]
#148146
11/11/08 01:32 PM
11/11/08 01:32 PM
when you put it in low, you drop it into 1 which is the highest numerical gear in the tranny. the lower the gear, the more umpf you get.
do a google on 'what is low gear' or low gear ratio
[Re: dOc !]
#148147
11/11/08 08:08 PM
11/11/08 08:08 PM
mopowers
Sac, CA
i know he does.
Low equals HIGH ?
I'm having trouble figuring out if you're serious or not.
[Re: mopowers]
#148148
11/12/08 11:00 AM
11/12/08 11:00 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
i know who made my 6.14,s i bought a old dart race car 340 4 speed it had a narrowed rear and set up for 1/8 mile i devided the gears and laughed and had a couple of buddys do the same thay laughed i got ahold of the guy that done the car he comfirmed i kept then in the car for a summer but never drove it out of town i still got them on the pig but not really looking to sell them
[Re: RapidRobert]
#148150
11/12/08 01:37 PM
11/12/08 01:37 PM
moper
Columbia, CT
Yes 440, you have it backwards... at least in terms of a car. It's easy to get confused by it. In automotive circles, gear ratio and the description are tweaked...lol. The higher the torque multiplication, the lower the gear in terms of transmission gears you're in. First is a "lower" gear than 2nd..etc etc etc. This is carried over to the rear axle too. You're technically right with a lower gear ratio being 3.23:1 vs 5.13:1 because there's less turns of the drive gear vs the driven gear. But in automotive circles, it's not a standard way of describing things.
