Re: Lowest gears for 8 3/4?
[Re: Junky]
#148157
11/12/08 11:59 PM
11/12/08 11:59 PM
Posts: 196 out front
jerrya
Comin to a Labor Day Telethon
out front
Ain't no valley LOW, ain't no mountain HIGH
Man does not plan to fail... he fails to plan
[Re: jerrya]
#148158
11/13/08 12:08 AM
11/13/08 12:08 AM
RapidRobert
It ain't never gonna end. I'll end up running a thermoquad before it's all said & done.
[Re: RapidRobert]
#148159
11/13/08 12:06 PM
11/13/08 12:06 PM
Posts: 8,859 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
its simple...do you take off in low gear or take off in high? in a normal 4 speed 4th is 1-1 but first is way lower and has a higher # ratio
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: DoctorDiff]
#148162
11/13/08 12:40 PM
11/13/08 12:40 PM
Posts: 27,485 So Cal
autoxcuda
So Cal
I have a 742 casting/3.42/Detroit Locker third-member. It is a factory built unit with a 1964 date code. It supposedly came from Petty Enterprises.
Assy, Differential & Carrier (large stem pinion) -Part number PE-342R in the 74 PE catalog.
[Re: autoxcuda]
#148163
11/13/08 04:44 PM
11/13/08 04:44 PM
RapidRobert
I googled them & saw PE but couldn't find a redirect for any parts for sale
[Re: RapidRobert]
#148164
11/13/08 05:41 PM
11/13/08 05:41 PM
autoxcuda
So Cal
The catalog I quoted from was from 1974. I don't think they have or wish to sell any of that stuff. That was 30 years ago.
[Re: RapidRobert]
#148169
11/14/08 09:09 AM
11/14/08 09:09 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
ok how do i tell who made them?
[Re: toplescuda]
#148170
11/14/08 09:39 AM
11/14/08 09:39 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
ok i went and dug the 500 pound chunk out of the shed here is all i found its a 742 case with a big on the side of it has 43 gears on ring and 7 on the penion(sp?) also has like some kind of bright shinny line across the ring with 184 and looks to be a j etched into it then 5010 h then looks like a apple shape then 7 r 8620 what the heck does all that mean? i took these gears out cause the penion nut backed off and thay strated to make a houling sound one night so next day i swaped them out
[Re: toplescuda]
#148171
11/14/08 10:17 AM
11/14/08 10:17 AM
RapidRobert
43 teeth & 7 teeth is certainly 6.14's. The #'s dont ring a bell. A damaged/howling set is no sweat on a circle burner because the open exhausts from 20 cars is deafening.
