Page 3 of 3 1 2 3
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148172
11/14/08 10:22 AM
11/14/08 10:22 AM
scratchnfotraction Offline
wish I had a motor that needed 6.14 gears to get it buzzing
Re: Lowest gears for 8 3/4? [Re: scratchnfotraction] #148173
11/14/08 10:38 AM
11/14/08 10:38 AM
It does take a different mindset because you'd think that'd be WAY too low but it's perfect(.4 mile high banked dirt track) 360 9-1 CR 2bbl by class rules & at the end of the straights it is still pulling strong at over 6400. Those Hughes cams are awesome.
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148174
11/14/08 10:54 AM
11/14/08 10:54 AM
whoohoo with a 2-v
and what hughes cam is that?
Re: Lowest gears for 8 3/4? [Re: scratchnfotraction] #148175
11/14/08 11:04 AM
11/14/08 11:04 AM
yeah I thought it'd be laying down at that point. It's one of Daves oval track grinds I don't know the # right offhand but he definitely has my business
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148176
11/14/08 02:49 PM
11/14/08 02:49 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
I know you want to keep it all mopar but your best bet is to put a 9" under it and then you can get gears all the way to 7.33. I used 7.00 in my SS on a 3/8 mile dirt. about 6500 at the turn in.89-92 in tire. what really works well is a full floater rear from a modified.If u have any swapmeets or auctions in your area now is the time and u can probably pick one up for what the mopar pig would cost.
Re: Lowest gears for 8 3/4? [Re: gearbanger] #148177
11/14/08 04:46 PM
11/14/08 04:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A good fried of mine has a '70 Charger with a 2.45 8.75 gear set from the factory. The car does wharp speed without even reving.
Not likely, as stated earlier 2.76 is the lowest factory numeric ratio in the 8 3/4" but the 2.45 ratio was available in the 8 1/4" rear.
Re: Lowest gears for 8 3/4? [Re: John_Kunkel] #148178
11/15/08 12:26 AM
11/15/08 12:26 AM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
I swear I have a 2.72 gearset in a 742 housing from a very early '60's Chrysler. The older pre '60's cars had some unique gear choices, didn't they? I've seen some odd ratios (example 3.36).
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Lowest gears for 8 3/4? [Re: racealittle] #148179
11/15/08 12:37 AM
11/15/08 12:37 AM
count those teeth
Re: Lowest gears for 8 3/4? [Re: John_Kunkel] #148180
11/15/08 12:43 AM
11/15/08 12:43 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
A 2.4 ratio was also available for 8 3/4" rears.
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148181
11/15/08 12:45 AM
11/15/08 12:45 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
sent you a e mail robert
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Lowest gears for 8 3/4? [Re: toplescuda] #148182
11/15/08 12:54 AM
11/15/08 12:54 AM
got it
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148183
11/15/08 01:24 AM
11/15/08 01:24 AM
racealittle Offline
racealittle  Offline
Robert, I could send you a picture of it, but there are alot of mopar parts in the way, getting to it. Do you really want me to dig it out? The numbers are stamped in the gear set. Every time I've had to dig through that area of the garage, I look at the ratio because I too, find it hard to beleive.
Re: Lowest gears for 8 3/4? [Re: racealittle] #148184
11/15/08 01:31 AM
11/15/08 01:31 AM
No bro please dont & in no way should my ramblings ever be construed as fact or to be taken as motivation to do something that is not absolutely neccessary.
Re: Lowest gears for 8 3/4? [Re: mod5v] #148185
11/15/08 01:51 AM
11/15/08 01:51 AM
I know you want to keep it all mopar but your best bet is to put a 9" under it and then you can get gears all the way to 7.33. what really works well is a full floater rear from a modified.If u have any swapmeets or auctions in your area now is the time and u can probably pick one up for what the mopar pig would cost.
Hobby stock rules prohibit a full floater for safety concerns but I used a car 9" with 6.20's & actually could have gone a bit deeper but I'm old school on this & it didn't feel right have a furd part on the car.
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148186
11/15/08 12:02 PM
11/15/08 12:02 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
Prohibit a floater for safty conserns??? That is one of the reasons for a floater. If a axle brakes the wheel still stays on the car.Have u ever seen a 10bolt chevy lose an axle(C-clip)? I've seen them go over the catch fence wheel tire and axle. Very dangerous. At the last track I raced at the promoter finlly got smart after a near fatal axle loss and made floaters leagle and rear discs manditory in an atempt to reduce the amount of lost wheels and axles.
Good luck with the ear surch. You may have to bite the bullet and run in 2nd gear (3sp) to get the final drive u need.
Re: Lowest gears for 8 3/4? [Re: mod5v] #148187
11/15/08 12:17 PM
11/15/08 12:17 PM
I was thinking that floaters were not allowed but I may have that backwards. One season I did run in 2nd with an A230. Right now I am using a 904 in D with the furd 6.20's & I am hoping that toplescuda will be reasonable with me so that I can get that furd out of there then my next plan is to run a 904 in manual 2 & 4.10 gears in a 7&1/4. Everybody tells me that it wont hold up but I am driven to do it & loosing ~100 lbs of unsprung weight is going to be a killer. the spiders are the weakest part & they will be welded solid(which is std procedure) so I am confident
Page 3 of 3 1 2 3
