Page 2 of 3 1 2 3
Re: Lowest gears for 8 3/4? [Re: toplescuda] #148152
11/12/08 09:58 PM
11/12/08 09:58 PM
I appreciate that. I checked Randy's site & nothing that low(or is it high) sorry couldn't resist
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148153
11/12/08 10:24 PM
11/12/08 10:24 PM
Nova Scotia
gearbanger Offline
gearbanger  Offline
Nova Scotia
A good fried of mine has a '70 Charger with a 2.45 8.75 gear set from the factory. The car does wharp speed without even reving.
Re: Lowest gears for 8 3/4? [Re: gearbanger] #148154
11/12/08 10:49 PM
11/12/08 10:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
But how can that charger have such a high speed with such LOW gears?
Re: Lowest gears for 8 3/4? [Re: mopowers] #148155
11/12/08 10:54 PM
11/12/08 10:54 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
OK, I get it. Low gears are high numbers, with high gears being low numbers, but high gears will make it faster while low gears will make 'em quicker as long as the low gear is not too high.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Lowest gears for 8 3/4? [Re: Junky] #148156
11/12/08 11:55 PM
11/12/08 11:55 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
For those who want to play with gear ratios here's a toy to use. http://vexer.com/68rt/speed.html
Re: Lowest gears for 8 3/4? [Re: Junky] #148157
11/12/08 11:59 PM
11/12/08 11:59 PM
out front
jerrya Offline
Comin to a Labor Day Telethon
jerrya  Offline
out front
Ain't no valley LOW, ain't no mountain HIGH
Man does not plan to fail... he fails to plan
Re: Lowest gears for 8 3/4? [Re: jerrya] #148158
11/13/08 12:08 AM
11/13/08 12:08 AM
It ain't never gonna end. I'll end up running a thermoquad before it's all said & done.
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148159
11/13/08 12:06 PM
11/13/08 12:06 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
its simple...do you take off in low gear or take off in high? in a normal 4 speed 4th is 1-1 but first is way lower and has a higher # ratio
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Lowest gears for 8 3/4? [Re: toplescuda] #148160
11/13/08 12:21 PM
11/13/08 12:21 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The 74 Petty catalog has gears as high as 6.17 and a tons of intermediate gears. Stuff like a 3.07, 3.64, 4.75... Crazy stuff. All Detriot Lockers for them (rachet).
I've seen a picture of a room stuffed full of 8 3/4's at Petty Enterprises. Maybe there's still some floating around down south.
Re: Lowest gears for 8 3/4? [Re: autoxcuda] #148161
11/13/08 12:32 PM
11/13/08 12:32 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I have a 742 casting/3.42/Detroit Locker third-member. It is a factory built unit with a 1964 date code. It supposedly came from Petty Enterprises.
Re: Lowest gears for 8 3/4? [Re: DoctorDiff] #148162
11/13/08 12:40 PM
11/13/08 12:40 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Assy, Differential & Carrier (large stem pinion)
-Part number PE-342R in the 74 PE catalog.
Re: Lowest gears for 8 3/4? [Re: autoxcuda] #148163
11/13/08 04:44 PM
11/13/08 04:44 PM
I googled them & saw PE but couldn't find a redirect for any parts for sale
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148164
11/13/08 05:41 PM
11/13/08 05:41 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The catalog I quoted from was from 1974. I don't think they have or wish to sell any of that stuff. That was 30 years ago.
Re: Lowest gears for 8 3/4? [Re: autoxcuda] #148165
11/13/08 05:59 PM
11/13/08 05:59 PM
that's what I was afraid of. I might just have to offer toplescuda a nice chunk of change to come off of his.
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148166
11/13/08 06:06 PM
11/13/08 06:06 PM
scratchnfotraction Offline
an offer he cant refuse
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148167
11/13/08 06:22 PM
11/13/08 06:22 PM
I thought 5.57's were the lowest! What make are these? any pics possible. More details please. I needed a lower set for my circle burner & 5.57 was all I could locate. I ended up using a 9" furd with 6.20's
With this & my subsequent post I think I kind of destroyed my bargaining position right there. I have 5.57's but they just didn't get my rpm up on my circle track SB challenger where I wanted it.
Re: Lowest gears for 8 3/4? [Re: toplescuda] #148168
11/13/08 06:31 PM
11/13/08 06:31 PM
ding ding ding we have a winner
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148169
11/14/08 09:09 AM
11/14/08 09:09 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
ok how do i tell who made them?
1971 charger
Re: Lowest gears for 8 3/4? [Re: toplescuda] #148170
11/14/08 09:39 AM
11/14/08 09:39 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
ok i went and dug the 500 pound chunk out of the shed here is all i found
its a 742 case with a big on the side of it
has 43 gears on ring and 7 on the penion(sp?)
also has like some kind of bright shinny line across the ring with 184 and looks to be a j etched into it then 5010 h then looks like a apple shape then 7 r 8620 what the heck does all that mean?
i took these gears out cause the penion nut backed off and thay strated to make a houling sound one night so next day i swaped them out
1971 charger
Re: Lowest gears for 8 3/4? [Re: toplescuda] #148171
11/14/08 10:17 AM
11/14/08 10:17 AM
43 teeth & 7 teeth is certainly 6.14's. The #'s dont ring a bell. A damaged/howling set is no sweat on a circle burner because the open exhausts from 20 cars is deafening.
Page 2 of 3 1 2 3
