Re: sprag failure
[Re: THE GLASS MAN]
#1480721
08/08/13 06:11 PM
08/08/13 06:11 PM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
Check the length of your driveshaft.
so what cha think that the driveshaft may be too long and stressing the sprag?
Motor might be moving to the rear a tad when that trans brake button is released. Do you have a strut rod on the motor to keep it from moving to the rear. Have you changed over to s/s springs lately. When you unbolt the rear u joint, how much does your drive shaft slip into the tranny ?
have motor plate and mid plate and two strut rods so maybe its was just stressed from many trans brake launches
