Re: Windage Tray or not
[Re: 340SHORTY]
#1479822
08/05/13 05:11 PM
08/05/13 05:11 PM
Posts: 1,083 SE PA
Yellow Fever
SE PA
Looks almost like a factory tray to me...
No gasket needed! ![](/ubbthreads/images/graemlins/laugh.gif)
[Re: Yellow Fever]
#1479823
08/05/13 05:23 PM
08/05/13 05:23 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
No gasket needed!
And are reusable. ![](/ubbthreads/images/graemlins/boogie.gif)
No more messing with 2 gaskets to make a windage tray sandwich. ![](/ubbthreads/images/graemlins/tsk.gif)
"JEGS Big Block Mopar & Hemi windage tray is made from glass filled nylon and features re-usable silicone gaskets molded on the top & bottom of the tray. This tray is made using the same materials as many modern production engines. This combination windage tray & gasket increases HP, can be hand washed with soap & water and re-used over & over again. Future engine service is simpler since you won't have to scrape off the old gasket and replace it each time the oil pan is removed. Available in two sizes - up to 3.75" stroke or up to 4.15" stroke for all Big Block Mopar (383/400/413/426W/426 Hemi/440) engines"
[Re: 70VERT]
#1479825
08/05/13 06:23 PM
08/05/13 06:23 PM
Posts: 6,516 Santa Cruz, California
Lefty
Thanks for the info. I rarely take it over 5 grand. Sounds like it's not gonna go back in. Any thoughts pon best place to buy a new pan? Prefer to get a chrome one?
I've had the low oil pressure warning come on under 5000 rpm. I pedaled it in front of some motorcycle folks stopped at the country store near my house. My 440 sounds fantastic when it's angry. The problem turned out to be a washboard stretch of tarmac. The rear wheels were picking up speed between washboard humps while in free air. This enabled the high volume oil pump to suck the 5 quart pan dry in 2-3 seconds.
Unless you drive like Grandpa I'd leave it in.
[Re: 340SHORTY]
#1479830
08/05/13 08:35 PM
08/05/13 08:35 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
"A high volume pump pumps no more oil than a standard pump at a given pressure and the notion of a pan being pumped dry due to a high volume pump is a fallacy."
Agreed...
[Re: Lefty]
#1479831
08/05/13 08:43 PM
08/05/13 08:43 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
And where was that 5 qt of oil during that time ? ![](/ubbthreads/images/graemlins/confused.gif)
[Re: dOc …]
#1479833
08/05/13 09:00 PM
08/05/13 09:00 PM
KillerBee
N.E. Ohio
The next time I need a windage tray for my big blocks I'm going to try this one piece tray/oil pan gasket.
They are available for stroker engines too.
http://www.jegs.com/i/JEGS+Performance+P...CFeoWMgodL1AAbg
So ... there are no longer two trays for the B/RB/Hemi ?... just one that fits everything and the 4.15 combo ??
"Available in two sizes - up to 3.75" stroke or up to 4.15" stroke for all Big Block Mopar (383/400/413/426W/426 Hemi/440) engines"
[Re: 70VERT]
#1479834
08/05/13 09:05 PM
08/05/13 09:05 PM
KillerBee
N.E. Ohio
OK---gonna put the tray back in along with my new pan. NOW.......what should I do about the clearance problem. My car has been like this since I've owned it. It's a clone and I never did anything to the engine mounts. Looking at it from underneath, I'm not sure how I can get more clearance ???
Do you know anything about your engine mounts?
Take a look at them...are they rubber?
Do they look like they are smashed down, a cheap $$ rubber mount will sag pretty quick.
Does your engine sit level in the car?
If the car is an automatic, open the hood, put the car in drive and hold the brake and gently give the car gas while watching the engine from the driver's seat, does the engine lift and/or move to the right a whole bunch? Don't get carried away, if the engine starts to move/lift a large amount back off.
Do the same in reverse, does it move to the left?
Post a picture of the mounts and your clearance if you can.
Read this post https://board.moparts.org/ubbthreads/show...rue#Post7792395
[Re: KillerBee]
#1479835
08/05/13 11:41 PM
08/05/13 11:41 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
taking OUT the windage tray, and putting IN a chrome pan...... ![](/ubbthreads/images/graemlins/runaway.gif) Shoulda bought a chevy.
[Re: 70VERT]
#1479837
08/06/13 12:41 AM
08/06/13 12:41 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
Mounts are rubber and appear to be in good shape. Engine sits level and there is no rocking going on between the KFrame and the engine. I'll post some pix tomorrow. It's been like this since I bought it and I just never questioned it---figured the windage tray was chewing up the clearances.
not 3/4" clearance
