Windage Tray or not
#1479800
08/05/13 01:05 AM
08/05/13 01:05 AM
Posts: 495 PA--USA
70VERT
PA--USA
I am replacing the oil pan on my 440 Challenger RT. It has a windage tray installed now and I'm wondering whether or not it is worth reinstalling. It's a street car - stock heads, Edelbrock Performer intake, 850 cfm Holly and mopar performance purple cam. What do you guys think ?? any real benefit? Also where's a good place to get a replacement pan--I'd to go with a chrome one ![](/ubbthreads/images/graemlins/beer.gif)
Re: Windage Tray or not
[Re: 70VERT]
#1479804
08/05/13 02:58 AM
08/05/13 02:58 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
I actually was having a little clearance issue with the steering linkage under the pan (rubbed slightly) and was wondering if it was worth the bother. I'll put it in if there will be some difference in performance. Thanks
Use some motor mount spacers.
[Re: Cab_Burge]
#1479806
08/05/13 04:19 AM
08/05/13 04:19 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
They have proven to be worth 15 HP at and above 5000 RPM on engine dyno tetsts done by Ma Mopra many times, the higher the RPM the higher the gain
But,unless you drag race or street race how often do you see 5000 RPM's ? ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: 62maxwgn]
#1479807
08/05/13 10:34 AM
08/05/13 10:34 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
If you drive on the street with 5.13's in the rear ... ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: 70VERT]
#1479810
08/05/13 10:54 AM
08/05/13 10:54 AM
RapidRobert
It'd give you a slight benefit. It's pretty thin & I wouldn't think you'd gain the steering linkage clearance you are after by tossing it keeping in mind that the eng as you know torques over when you get on it. I'd check what my oil pickup clearance is with or without it if you do pull the pan. If chrome pans are chromed on the gasket flanges I'd for sure sand it off. As said I'd look into spacing the motor up to deal with it that way & not sure if raising the eng would alter the driveshaft angle to where it would need to be checked. Just tossing out thoughts.
[Re: JohnRR]
#1479811
08/05/13 10:56 AM
08/05/13 10:56 AM
62maxwgn
Blair County,PA
How about 6.71's !! ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: 62maxwgn]
#1479814
08/05/13 11:06 AM
08/05/13 11:06 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Chrome may be a sealing nightmare. Gaskets slide and squish. You'll need to rough it up. Good chance if you find a pan it will be Chinese quality.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: 70VERT]
#1479819
08/05/13 02:16 PM
08/05/13 02:16 PM
JohnRR
I have the stock pan on it right now. The linkage rubbed just enough to scratch up the paint. drain plug threads are marginal and I'm gonna be doing some cam work, so I figured I'd straighten out this pan issue finally. Just didn't know if the difference in performance would be worth it (or noticeable)Yeah I was concerned about shimming the engine not knowing what that would mean to driveshaft alignment. Chrome pan is only a thought right now it depends on the bucks thnx
Sounds like you have motor mount issue , there should be 3/4" space between the pan and the centerlink.
