Re: Blew out a freeze plug on the BIG end
[Re: hemi-itis]
#1477540
08/01/13 03:10 PM
08/01/13 03:10 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Glad your ok AL...could have been a real mess. Three things that cause soft plug failures. 1)Shallow type soft plugs. I hate them. I only use deep plugs . Period. 2) Detonation and vibration. Enuff said. 3) Painted or dirty soft plug bores. When people paint blocks, they often dont tape off ( or clean afterwartds) the paint in the soft plug openings. Paint wont help the problem. I lightly clean the bore, a small bead of #2 Permatex, three " stakes" with a chisel, and never an issue.Some circle track builds take a different approach with a more positive lock procedure. I also do use brass plugs, as I believe they conform better to the bores, and have more bite...
RIP Monte Smith
[Re: hemi-itis]
#1477543
08/01/13 03:34 PM
08/01/13 03:34 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Glad that you were able to save it! Getting sideways at that speed must have been a "pucker ride" for sure!! You might want to consider installing a 'chute.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: hemi-itis]
#1477547
08/01/13 03:56 PM
08/01/13 03:56 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
Al it sux for sure but it could have been much worse. Glad your ok.
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: Dap]
#1477548
08/01/13 04:26 PM
08/01/13 04:26 PM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
I blew a FP on my friends FED with a blown/racegas 392 Hemi. Not fun when the engine is in front of you and you get soaked with HOT water on the finish line. I now own the car and it will get a blown KB hemi and methanol and no cooler needed. Hope you get it back together soon
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
[Re: hemi-itis]
#1477551
08/01/13 07:06 PM
08/01/13 07:06 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Ron,you'd better tack the bolts holdin yer left fender on
Dont worry as my 63 will stay locked in my garage for a bit with my two killer guard dogs watching over it. Ron
