Re: 71 B Body Brake Issues
[Re: HemiChallenger]
#1476419
07/30/13 11:45 AM
07/30/13 11:45 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Hey Steve. I've had this problem on a couple 71's and it was the valve not releasing the pressure. Lock up the brakes like it is doing and then pull the little bypass pin on the valve and see if they release.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
#1476422
07/30/13 08:25 PM
07/30/13 08:25 PM
Posts: 6,516 Santa Cruz, California
Lefty
If i crack the bleeders on the front i can then push the car then re bleed them and it works fine for a short time until it does it again. What would you suggest i do?
That tells you the master cylinder or prop valve is not releasing brake line pressure. It's usually caused by incorrect pedal to MC push rod adjustment or MC to booster push rod adjustment.
Make sure you have a little play in the brake pedal before it pushes the piston in the master cylinder. Same for the MC to booster if you have one.
If you have not done anything to the MC or booster that could have changed the gaps, it's probably a bad prop valve ,MC or clogged brake lines. How old are the flex lines to the calipers?
#1476423
07/30/13 08:41 PM
07/30/13 08:41 PM
moparmarks
Mark i tried this and it worked. BUT that being said it does this quite frequently, is there a solution to the problem? Ive heard of this problem with these prop valves and i really dont want to have to do this all the time. Is there a fix or should i just hunt an original?
Steve
If it releases with the bypass pin then its probably the valve. My issues were with original valves, not repros. I just took the valve apart and cleaned it up real good and then they worked fine. Probably have had around 5 71B/E disc brake valves do this.
#1476426
07/31/13 05:34 PM
07/31/13 05:34 PM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
So you used old used hoses?That makes no sense.No matter the mileage they can be swelled inside.Aside from that Id guess PP valve.I run one from a 5th Ave on my 65 disc conversion.Been on at least 12 years and no problems.Rocky
Chrysler Firepower
[Re: therocks]
#1476427
07/31/13 05:44 PM
07/31/13 05:44 PM
Posts: 892 MA
steve70
MA
I'd start with the brake hose. I've seen a few collapse and cause the same issue. They're cheap and easy to change.
1970 Challenger T/A 4 speed
[Re: Lefty]
#1476428
07/31/13 10:20 PM
07/31/13 10:20 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
If you're looking past the prop valve take this posted advice and confirm the pushrod legnth as the second thing to do...If the pressure released at the pin then the hoses are'nt the problem...Would I run the old hoses ??? Absolutely not but the pressure would be from the hoses out {at the caliper} not all the way back to the prop valve... My guess is the prop valve as other have suggested...
