Part throttle downshift not available with 440 and 426 #1476130
07/29/13 08:32 PM
07/29/13 08:32 PM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
Just reading Shift Linkage Adjustment Guide, and I would like to know why Part throttle downshift was not available with 440 and 426 Hemi options...
Re: Part throttle downshift not available with 440 and 426 [Re: STROKIE] #1476131
07/29/13 10:11 PM
07/29/13 10:11 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i don't think chrysler went to part throttle downshift until the early seventies. just put an early seventies valve body in it and your good to go.
Re: Part throttle downshift not available with 440 and 426 [Re: lewtot184] #1476132
07/29/13 10:15 PM
07/29/13 10:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
part throttle downshift was done to compensate for lack of torque.
You think the 440 or Hemi had that problem?
Don't be the exception.
Re: Part throttle downshift not available with 440 and 426 [Re: Supercuda] #1476133
07/30/13 08:33 AM
07/30/13 08:33 AM
Montreal Quebec
STROKIE Offline OP
STROKIE  Offline OP
Montreal Quebec
Thanks...
I'm gone skip the idea to add a PTK on my 451cid.
Re: Part throttle downshift not available with 440 and 426 [Re: lewtot184] #1476134
07/30/13 10:33 AM
07/30/13 10:33 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
This , I'm pretty sure PTK didn't show up till 1971 ...
Re: Part throttle downshift not available with 440 and 426 [Re: JohnRR] #1476135
07/30/13 11:08 AM
07/30/13 11:08 AM
scratchnfotraction Offline
IMHO,with a 451 you will know when you need to manualy pull it to 2nd gear and shift back to 3rd.
Re: Part throttle downshift not available with 440 and 426 [Re: Supercuda] #1476136
07/30/13 11:28 AM
07/30/13 11:28 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Personally I find it very annoying when an engine keeps working against a transmission hanging in 3rd gear when doing 10-15 mph orso.
Re: Part throttle downshift not available with 440 and 426 [Re: BigBlockMopar] #1476137
07/30/13 11:39 AM
07/30/13 11:39 AM
Even more annoying was driving a Hemi Charger back in the day and getting beaten by a small block from a 35 mph roll because your tranny won't go into low gear above 30 mph no matter what you do. Manual/automatic valve body fixed that.
Not sure what years had that problem, but I know the 67's and 68's did.
Re: Part throttle downshift not available with 440 and 426 [Re: JohnRR] #1476138
07/30/13 02:58 PM
07/30/13 02:58 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
'71 for the V8 but the /6 had it as far back as '67. The factory thinking was that the 440HP and Hemi were never geared as high as the standard performance models and didn't need PTK.
When the V8 PTK was introduced, the 440 and Hemi didn't get it but in later years the 440 did get it.
Re: Part throttle downshift not available with 440 and 426 [Re: John_Kunkel] #1476139
07/30/13 03:28 PM
07/30/13 03:28 PM
dogdays Offline
dogdays  Offline
And the valve bodies interchange, right? So a PTK body will fit in any Torqueflite, right? Making it easy to retrofit?
R.
Re: Part throttle downshift not available with 440 and 426 [Re: dogdays] #1476140
07/30/13 04:59 PM
07/30/13 04:59 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
You can add a PTK "module" to your valve body of the same era. I've done it.
Re: Part throttle downshift not available with 440 and 426 [Re: 70Duster440] #1476141
07/30/13 05:18 PM
07/30/13 05:18 PM
JohnRR Offline
JohnRR  Offline
Correct
Re: Part throttle downshift not available with 440 and 426 [Re: dogdays] #1476142
07/30/13 07:07 PM
07/30/13 07:07 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
R.
i've used PTK valve bodies in a '69 tranny with no issues.
Re: Part throttle downshift not available with 440 and 426 [Re: dogdays] #1476143
07/30/13 07:30 PM
07/30/13 07:30 PM
Rio Linda, CA
Rio Linda, CA
Nope, the VB has to be '67 or later. The earlier VB's lack the throttle pressure sense port.
