Re: Part throttle downshift not available with 440 and 426
[Re: lewtot184]
#1476132
07/29/13 10:15 PM
07/29/13 10:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
part throttle downshift was done to compensate for lack of torque.
You think the 440 or Hemi had that problem?
[Re: lewtot184]
#1476134
07/30/13 10:33 AM
07/30/13 10:33 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
i don't think chrysler went to part throttle downshift until the early seventies. just put an early seventies valve body in it and your good to go.
This , I'm pretty sure PTK didn't show up till 1971 ...
[Re: Supercuda]
#1476136
07/30/13 11:28 AM
07/30/13 11:28 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Personally I find it very annoying when an engine keeps working against a transmission hanging in 3rd gear when doing 10-15 mph orso.
[Re: BigBlockMopar]
#1476137
07/30/13 11:39 AM
07/30/13 11:39 AM
Even more annoying was driving a Hemi Charger back in the day and getting beaten by a small block from a 35 mph roll because your tranny won't go into low gear above 30 mph no matter what you do. Manual/automatic valve body fixed that.
Not sure what years had that problem, but I know the 67's and 68's did.
[Re: dogdays]
#1476142
07/30/13 07:07 PM
07/30/13 07:07 PM
Posts: 3,916 usa
lewtot184
usa
And the valve bodies interchange, right? So a PTK body will fit in any Torqueflite, right? Making it easy to retrofit?
R.
i've used PTK valve bodies in a '69 tranny with no issues.
[Re: dogdays]
#1476143
07/30/13 07:30 PM
07/30/13 07:30 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Nope, the VB has to be '67 or later. The earlier VB's lack the throttle pressure sense port.
