Re: 383 cid only running on 4 cylinders, please help?
[Re: GTX MATT]
#1475798
07/29/13 01:49 PM
07/29/13 01:49 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
Are you sure the distributor is in correct.New cam it could be out 180.Easiest thing to check.Just pull it and reinstall 180.That and firing order is counter clock wise.Rocky
Chrysler Firepower
[Re: therocks]
#1475799
07/29/13 01:51 PM
07/29/13 01:51 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
Good God.Im 1/2 blind but those look like SB plugs.Unless it has aluminum heads they are the wrong plug.I believe he didnt say what heads but from the sounds I think iron which uses a short reach plug.Rocky
he said he has RPM's
Engine is 0,60 over with a stock bottom, edelbrock rpm heads 84cc,lunati voodoo hydrulic camshaft, harland sharp rockes and a mighty demon 750 carb.
OP , do you have a friend with a carb you can borrow ?
[Re: JohnRR]
#1475800
07/29/13 02:36 PM
07/29/13 02:36 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Here's an idea, rotate the carb 180 degrees for testing purposes. If the dead cylinders start working and the live ones quit then you know it's your carb.
Years ago, I was working on my girlfriend's mom's Olds, seems the entire passenger's side of that 455 was dead. Pulled the plugs and the pass side ones were totally carboned up, I mean hooded over bad.
Replaced the intake gasket, new plugs and it ran great.
[Re: Supercuda]
#1475801
07/29/13 02:50 PM
07/29/13 02:50 PM
Posts: 87 Norway
cudaerik
Norway
Again thanks for a lot of grate advice, I will do a carb swap and a carb clean now and we will see.
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
[Re: cudaerik]
#1475802
07/29/13 05:43 PM
07/29/13 05:43 PM
Posts: 87 Norway
cudaerik
Norway
did a total clean up of the carb an it runs very nice! thanks for all advice! ![](/ubbthreads/images/graemlins/smile.gif)
[Re: cudaerik]
#1475803
07/29/13 06:31 PM
07/29/13 06:31 PM
RapidRobert
Success ![](/ubbthreads/images/graemlins/thumbs.gif) . What area(s) of the carb did you clean that did the trick?
