Anyone use the Rislone ZZDP additive? #1474620
07/27/13 12:21 AM
07/27/13 12:21 AM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I have been buying Brad Penn oil for sometime and it works well in the roadrunner but it's $8 a quart.
I was given an 11oz bottle of that Rislone ZZDP additive so I was wondering if I just bought the less expensive oil at Costco and tossed that stuff in it might be way cheaper and do the same type of protecting as the Brad Penn.
Anyone use that additive??
Re: Anyone use the Rislone ZZDP additive? [Re: MidPenMopar] #1474621
07/27/13 11:17 AM
07/27/13 11:17 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
i bought 2 bottles last month for 2 of my cars. I think it was $9 at pep boys. its in both of my cars, that's about all I can say about it.
Re: Anyone use the Rislone ZZDP additive? [Re: MidPenMopar] #1474622
07/27/13 11:32 AM
07/27/13 11:32 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
I've been using the Eastwood ZDDP additive.
http://search.eastwood.com/search?w=zddp+
I usually buy it as a 3 pak (@$27.00) when Eastwood runs some king of special (which happens often lol). I believe they are running a free shipping promo now.
I add a bottle to off the shelf 10W-40 at oil change time.
Common sense is a flower that does not grow in everybody's garden
Re: Anyone use the Rislone ZZDP additive? [Re: Ron_M] #1474623
07/27/13 12:34 PM
07/27/13 12:34 PM
SE PA
Yellow Fever Offline
SE PA
I got the ZDDPLUS off Ebag, same stuff at Eastwood but cheaper.
http://www.ebay.com/itm/10-ZDDPlus-ZDDP-...641&vxp=mtr
Re: Anyone use the Rislone ZZDP additive? [Re: Ron_M] #1474624
07/27/13 12:37 PM
07/27/13 12:37 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I haven't tried the Rislone additive, so I'm no help there.
I've been using ZDDPlus along with whatever 5gal jug of 10-30 is cheapest at Wallyworld.
Has anyone had an oil analysis done on any of the Zinc additive products to find out if their claims are true?
Re: Anyone use the Rislone ZZDP additive? [Re: Yellow Fever] #1474625
07/27/13 12:39 PM
07/27/13 12:39 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
That's cheaper than buying off one of the distributors on the ZDDPlus web site!
Re: Anyone use the Rislone ZZDP additive? [Re: B5 Bee] #1474626
07/27/13 12:46 PM
07/27/13 12:46 PM
SE PA
SE PA
Yeah I bought the 10 pack a while ago. Good to have on hand.
Re: Anyone use the Rislone ZZDP additive? [Re: Yellow Fever] #1474627
07/27/13 12:55 PM
07/27/13 12:55 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
we've been using it here. Rislone has been around a while ands they are one of the few companies addressing the need.
Re: Anyone use the Rislone ZZDP additive? [Re: MidPenMopar] #1474628
07/27/13 01:12 PM
07/27/13 01:12 PM
Kirkland, Washington
Pacnorthcuda Offline
Stu....yes, I'm using it right now. I contacted Rislone about 6 months ago to verify my math and they confirmed that its about 15,500 ppm zinc. That's a great ratio given the volume of the bottle.
You can use any oil you want (I'm using regular Valvoline 10/30), I calculated IIRC that my crankcase ppm is now right about 1600ppm assuming the valvoline is about 800 to start with.
I believe the Rislone product to be a great solution (pun intended) and I like the fact it's an off the shelf item at a good price.
Re: Anyone use the Rislone ZZDP additive? [Re: MidPenMopar] #1474629
07/27/13 01:32 PM
07/27/13 01:32 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
I have not used the Rislone but am doing the same thing using the Lucas Oil Break-In Additive. Adding 4oz to 4-5 qts of regular oil brings the zinc to 1200-1500 ppm (which I think is in the recommended level).
http://www.lucasoil.com/products/display_products.sd?iid=82&catid=9&loc=show&headTitle= - Engine Break-In Oil Additive - TB Zinc Plus
Re: Anyone use the Rislone ZZDP additive? [Re: moparfan53] #1474630
07/27/13 04:52 PM
07/27/13 04:52 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have been using the Risoline ZINC additive for almost 2 years. Been working good as I add a bottle every time I change my oil. In fact I have 2 bottle's right now in my garage sitting in the top of my tool box. My buddy works at Pep Boys and thats how I found it as they carry it in stock. I have also used the Comp ZINC additive but this was a bit cheaper and has worked very good for me with my flat tappet solid cam. Ron
Re: Anyone use the Rislone ZZDP additive? [Re: 383man] #1474631
07/27/13 09:25 PM
07/27/13 09:25 PM
Ohio
dobie Offline
dobie  Offline
Ohio
I use Comp Cams break in additive at every oil change. For oil I use Mobil 1 15w-50.
1968 Plymouth Road Runner 383 4 speed
Re: Anyone use the Rislone ZZDP additive? [Re: dobie] #1474632
07/27/13 10:21 PM
07/27/13 10:21 PM
BDW Offline
BDW  Offline
1 bottle of the Lucas break-in is around $12 at Advanced Auto and is enough for 3 oil changes.
Re: Anyone use the Rislone ZZDP additive? [Re: BDW] #1474633
07/28/13 12:41 AM
07/28/13 12:41 AM
Thank you all for the great advice!!!
Re: Anyone use the Rislone ZZDP additive? [Re: MidPenMopar] #1474634
07/28/13 12:24 PM
07/28/13 12:24 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
Good stuff, thanks !
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Anyone use the Rislone ZZDP additive? [Re: Dixie] #1474635
07/28/13 04:47 PM
07/28/13 04:47 PM
Uranus
strokerchall Offline
Uranus
Recently I went oil shopping at NAPA, the guy asked what I was buying the oil for.I explained a hyd lifter 512 stroker,he told me to put the VR1 oil back and handed me JOE GIBBS HOT ROD OIL,I said ...can't I just put zinc additive in the VR1,he explained most syn. oils have high detergents that destroy zinc,hands down JOE GIBBS is the best for my motor.He went on to say a customer he has bought an 80k dual 454 boat and cheaped out on oil and wiped out both cams.
I don't know if he was FOS or not but seemed to really know his stuff,infact when I approched the counter about oils they called him from the back
Re: Anyone use the Rislone ZZDP additive? [Re: strokerchall] #1474636
07/28/13 06:55 PM
07/28/13 06:55 PM
BDW Offline
BDW  Offline
Zinc is a metal, not sure how a detergent would "destroy" it.
Re: Anyone use the Rislone ZZDP additive? [Re: strokerchall] #1474637
07/28/13 10:13 PM
07/28/13 10:13 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
Don't know which one you picked up but VR1 oil is available as synthetic (black bottle) and non-synthetic (silver bottle). According to Valvoline, both have high zinc for flat tappet applications, so no need to add any more.
http://www.valvoline.com/products/consumer-products/motor-oil/racing-motor-oil/6
http://www.valvoline.com/products/consumer-products/motor-oil/racing-motor-oil/8
Re: Anyone use the Rislone ZZDP additive? [Re: moparfan53] #1474638
07/28/13 10:24 PM
07/28/13 10:24 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
NAPA blow hole. lol
Re: Anyone use the Rislone ZZDP additive? [Re: moparfan53] #1474639
07/29/13 09:20 AM
07/29/13 09:20 AM
BDW Offline
BDW  Offline
Be careful, the 20-50W has 1400ppm, all other weights are only 1100ppm.
Still need to be around 1600 so why waste money on the VR?
